2nd order Differential Equation
In summary, the conversation discusses solving a differential equation involving the variable x by using a series solution or Frobenius' method. It is mentioned that for initial value problems, the series method can be used, while for problems with given values at x=0 or x=1, Frobenius' method must be used. The conversation also notes that the equation may have singular points at x=0 or x=1, which may affect the solution.
jhon
I can not how define way to solve these equation
x(l-x)y''+4y'+2y=o
If anyone can help
That looks like a pretty standard kind of equation. If you are given an initial value problem with y(a), y'(a) given and a is neither 0 nor 1, a standard series solution will work:
[tex]y= \sum_{n=0}^\infty a_nx^n[/tex].
Differentiate term by term and put into the equation to get a recursive equation for [itex]a_n[/itex].
If you are given y(0) and y'(0) you will need to use Frobenius' method with
[tex]y= \sum_{n=0}^\infty a_n x^{n+ c}[/tex]
for some number c (not necessarily a positive integer). Put that into the d.e. and look at the n=0 term to determine c.
If you are given y(l) and y'(l), similarly you will need to use Frobenius' method with
[tex]y= \sum_{n=0}^\infty a_n (x- l)^{n+ c}[/itex]
thnks HallsofIvy
but the question doesn't give me the initial value
I could be wrong (Still just a student) but even w/o initial conditions the series method should work. Just you won't know a0 and a1
Yes, but x= 0 and x= l are "singular" points. You may find that for some [itex]a_0[/itex] and [itex]a_1[/itex] your solution cannot be extended to x= 0 or x= 1.
Related to 2nd order Differential Equation
1. What is a 2nd order differential equation?
A 2nd order differential equation is a mathematical equation that involves the second derivative of a function. It is used to describe the behavior of physical systems in terms of their changing variables over time.
2. What are some examples of 2nd order differential equations?
Some examples of 2nd order differential equations include the harmonic oscillator equation, the wave equation, and the damped oscillator equation. These equations are commonly used in physics and engineering to model various phenomena.
3. How do you solve a 2nd order differential equation?
There are several methods for solving a 2nd order differential equation, including separation of variables, substitution, and the method of undetermined coefficients. The specific method used will depend on the form of the equation and any initial conditions given.
4. What is the significance of the initial conditions in a 2nd order differential equation?
The initial conditions in a 2nd order differential equation represent the starting values of the variables involved in the equation. These conditions are used to find the particular solution to the equation and can greatly affect the behavior and outcome of the system being modeled.
5. How are 2nd order differential equations used in real-life applications?
2nd order differential equations are used in a wide range of real-life applications, including modeling the motion of particles, predicting the spread of diseases, and designing electrical and mechanical systems. They are also commonly used in fields such as economics, biology, and chemistry to analyze and understand complex systems.
  • Differential Equations
