A particle in a spherical symmetric potential
In summary, the conversation discusses a particle trapped in a deep spherically symmetric potential, with a ground state wave function that satisfies the 1-dimensional Schrodinger energy eigenvalue equation with a boundary condition of u(0)=0. The conversation then goes on to explain why the wave function must vanish at r=r0 where the potential jumps to infinity, and how this affects the solution for the ground state energy of the particle. The conversation also discusses the types of wavefunctions that can satisfy the boundary conditions, and how these can be used to find the ground state energy in terms of known quantities.
noblegas
268
A particle that moves in three dimensions is trapped in a deep spherically symmetric potential V(r):
V(r)=0 at r<r_0
infinity at r>= r_0
where r_0 is a positive constant. The ground state wave function is spherically symmetric , so the radial wave function u(r) satistifies the 1-dimensional schrodinger energy eigenvalue equation (-[tex]\hbar[/tex]2/2m)*d^2/dr^2*u(r)+V(r)*u(r)=Eu(r) with the boundary condition u(0)=0 (eqn u(r)=r*phi(r)
a) Explain why, in the potential well in the equation V(r)=0 at r<r_0
infinity at r>= r_0, the wave function is forced to vanish at r=r_0
b) Using the known boundary conditions on the radial wave function u(r) at r=0 and r=r_0 , find the ground state energy of the particle of this potential well
u(r)=r*phi(r)
a)I don't exactly know what they mean by vanish in this context. Does V vanish when V=0? I know in a classically allowed region, when a particle just sits in a well and there is no external energy being transferred to the particle, then V=0.
b) To begin this problem, I should probably plug u(r) into (-[tex]\hbar[/tex]2/2m)*d^2/dr^2*u(r)+V(r)*u(r)=Eu(r). Not sure how following this procedure will help me find the value for the ground state energy.
For A), the question is why the wavefunction must vanish (the angular parts are irrelevant; only u(r) really need vanish) at r=r0 where the potential jumps to be unboundedly large. The wavefunction does not "seep into" the region of infinite potential. The reason this must be can be seen in Schroedinger's equation: What happens when we try to put in V=infinity? What would d^2/dr^2*u or E have to be to satisfy the equation, and why would this be physically ruled out? On the other hand, if we just demand u=0 starting at r0, then the equation does not even need to be solved in a non-trivial way...it is trivially solved already.
For B), this kind of reasoning is similar in many 1-dimensional problems. First think of just the well region where V=0. Then in that region you'd get free particle plane waves as solutions to the equation. But of course the particle isn't free because the V=0 region is not all there is to this particle's world; it sees the V=infinity jump. But we know that the conditions on the function u(r) are: u(r=0)=0=u(r=r0). So that just restricts the types of wavefunctions u(r) can be: Not just any exp(ikr) type plane wave, but a subset of them...what type of waveforms? Remember that the waveform you write down must be chosen so that the boundary conditions u(r=0)=0=u(r=r0) could be satisfied. You will also have to write down conditions on k such that the conditions are satisfied, just like in other 1-dimensional problems.
What is the ground state function, u(r), then? (Hint: note that we can write k in terms of known quantities). Putting u(r) in the Schr. eqn for the region r=[0,r0] will give you an eqn for E in terms of the mass, r0 and h-bar (Hint: What is V for this region?).
If V is at infinity, then C= (2m/h-bar^2)*(V(x)-E)=(1/phi)*(d^2/dx^2) approaches infinity as well which means that wave function bends far away from the axis and the ground state function approaches zero.=> u=0, since u=r*phi_0
wouldn't u=sin(k*pi) , k being an integer; so now I would be able to put u in my schrodinger equation to find V?
er... bump! DId I apply the correct line of reasoning and appproach to the problem?
Related to A particle in a spherical symmetric potential
1. What is a particle in a spherical symmetric potential?
A particle in a spherical symmetric potential is a theoretical model used in quantum mechanics to describe the behavior of a single particle in a potential that is symmetric around a central point, such as a nucleus or a planet.
2. How is the behavior of a particle in a spherical symmetric potential described?
The behavior of a particle in a spherical symmetric potential is described by the Schrödinger equation, which is a fundamental equation in quantum mechanics that determines the probability of finding the particle at a certain position and time.
3. What are some examples of spherical symmetric potentials?
Some examples of spherical symmetric potentials include the gravitational potential of a planet, the electrostatic potential of a charged nucleus, and the potential of a harmonic oscillator.
4. What is the significance of studying a particle in a spherical symmetric potential?
Studying a particle in a spherical symmetric potential allows us to understand the behavior of quantum particles in a wide range of systems, from atoms and molecules to planets and stars. It also helps us to develop advanced technologies, such as semiconductors and quantum computing.
5. What are some real-world applications of the concept of a particle in a spherical symmetric potential?
The concept of a particle in a spherical symmetric potential has many real-world applications, such as in quantum chemistry, where it is used to study the electronic structure of molecules, and in astrophysics, where it is used to model the behavior of stars and galaxies. It is also used in engineering fields, such as in the design of electronic devices and materials.
