- #36
A.T.
- 3,492
If that's how your shoulder joints work then you should have them checked. Most people can certainly swing their arms 360° in the sagittal plane continuously, without introducing torsion that needs untwisting. If you do this while floating in space, the rest of the body will counter rotate in the sagittal plane. For other rotation axes see the video of the astronaut here at 25:00:georgir said:your arm can not do a complete 360 degree turn unless it is detached or it twists and winds up more and more at your shoulder. you do a rotation, but you undo it as you untwist your shoulder.
http://techtv.mit.edu/collections/l...cle-smarts-stability-translation-and-rotation
Here is a video of a cat flipping around in only ~0.3sec. It should be obvious that this cannot be achieved with aerodynamic forces, unless you have vary large surface area limbs (like a bird wing).
https://www.youtube.com/watch?v=RHhXbOhK_hs
