Biophysics Q: Impact of stiffness (Young's modulus) on stress failure
In summary, the conversation discusses the micromechanics of lung injury due to overdistension, where overstretching of the lung epithelial cell's plasma membrane can cause stress failure and cell death. The concepts of stress, strain, and Young's modulus are used to study this, with stress being the main determinant of cell death. The conversation also mentions the use of ventilators in relation to lung injury and the importance of not forcing a high tidal volume to prevent overdistension and potential failure of the alveoli.
DNA105
TL;DR Summary
I'm trying to determine the impact of stiffness (Young's modulus) on the tendency of 'stress failure' with a given strain.
Hi. I'm a physician trying to understand the micromechanics of lung injury due to overdistension. The basic idea is that overstretching of the plasma membrane of the lung epithelial cell causes "stress failure" --> i.e. plasma membrane rupture --> cell death. The concepts of stress, strain, and Young's modulus (E) are utilized to study this: Stress = E x Strain, or Strain = Stress/E
Say object 1 has a stress = x, strain = y
Say object 2 has Young's modulus twice that of object 1, and the same stress (x) is applied
hence for stress = x, strain = y/2
So object 2 sees same stress (x) but half the strain (y/2) compared to object 1. What can be said about its chances/tendency for 'stress failure' compared to object 1: same or half?!
Would appreciate any insight.
Best.
One way to look at it:
Stress breaks things.
Strain is how far it stretches before it breaks.
That would imply that stress is the sole determinant of cell death.
But you have to be careful. Do the less flexible cells (higher Young's modulus) die at the same stress as the more flexible cells?
Side question: Is this related to the operation of ventilators?
Likes DNA105, Tom.G and berkeman
Thank you for the response. So the stress at which failure occurs may vary if alteration/remodeling occurs in an object. Makes sense!
And yes, this is in relation to ventilation induced lung injury (specifically overdistension injury due to large tidal volumes)
Likes jrmichler
The failure criterion of an object (or membrane) is somewhat separate from the stiffness behavior of the material. The failure is usually characterized by a critical stress level (expressed 3 dimensionally in terms of the principal stresses of the material). Google failure criteria.
Likes DNA105
This is just an information point for those interested. The following has been gleened from various on-line and off-line sources by an amateur and is not guaranteed 100% accurate. I'm sure @DNA105 can correct and expand on this!
A critical parameter during ventilator use is to not force a high tidal volume. During severe lung impairment, in COVID-19 for instance, some of the air sacs (alveoli) in the lung swell and the inner walls stick together; these are said to have 'collapsed'.
Just like a wet balloon or a wet plastic bag, the walls of the alveoli are then stuck together. It is sometimes possible to re-inflate them with a higher pressure from the ventilator (forcing a higher tidal volume), however the higher pressure can over-extend the non-collapsed alveoli, causing them to fail. A slight positive pressure is still used during exhalation though to help keep the functioning alveoli open and functioning.
Likes DNA105
Related to Biophysics Q: Impact of stiffness (Young's modulus) on stress failure
1. How does Young's modulus affect stress failure in biophysics?
The Young's modulus, also known as the stiffness or elastic modulus, is a measure of a material's resistance to deformation under stress. In biophysics, this is important because it determines how much stress a biomaterial can withstand before it fails. A higher Young's modulus means the material is stiffer and can withstand more stress before failing.
2. What is the relationship between Young's modulus and stress failure in biophysics?
The relationship between Young's modulus and stress failure is directly proportional. This means that as the Young's modulus increases, the stress failure also increases. In other words, the stiffer the material, the more stress it can withstand before failing.
3. How does the stiffness of biomaterials affect their performance in biophysics applications?
The stiffness of biomaterials plays a crucial role in their performance in biophysics applications. In many cases, a certain level of stiffness is required for the biomaterial to function properly. For example, in bone tissue engineering, a biomaterial with a similar stiffness to natural bone is needed to support bone growth and regeneration.
4. Can altering the Young's modulus of a biomaterial improve its resistance to stress failure?
Yes, altering the Young's modulus of a biomaterial can improve its resistance to stress failure. This can be achieved through various methods such as changing the composition of the material, adjusting the processing techniques, or using different additives. However, it is important to note that altering the Young's modulus may also affect other properties of the biomaterial, so a balance must be struck.
5. Are there any drawbacks to increasing the Young's modulus of a biomaterial in biophysics?
While increasing the Young's modulus of a biomaterial can improve its resistance to stress failure, it can also have some drawbacks. A higher Young's modulus can make the material more brittle and less flexible, which may not be suitable for certain biophysics applications. Additionally, altering the Young's modulus may also affect the biocompatibility of the biomaterial, so careful consideration is needed before making any changes.
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Other Physics Topics
