Calculating force between atoms
In summary: The average energy of the crystal. The whole crystal has just 8 atoms? This is not sufficient to use the usual approximations of thermodynamics (large number of particles), you would need different concepts to analyze this cube.The average energy of the crystal. The whole crystal has just 8 atoms? This is not sufficient to use the usual approximations of thermodynamics (large number of particles), you would need different concepts to analyze this cube.
casmir
Hi, can someone please tell me how to calculate force which is acting on one atom. Let's look at the crystal of manganese for example, manganese crystal is simple cube (as far I remember) so how can I calculate force acting on one of 8 atom in that crystal?
And one more question, it's often said that temperature is average kinetic energy of some object. So if It's known to me that some object have temperature of 300K and I know the mass of that object is it possible from this data to calculate kinetic energy of this object?
English isn't my native language so it might be that I'm bit unclear to you, so just warn me and I would try to be more clear.
Force from what, and on which parts?
The total average force is 0, as the atom does not accelerate away from its position.
Temperature is related to the average unordered kinetic energy. If you put an object on a moving train, it gains kinetic energy, but not temperature.
You need to know the internal degrees of freedom of that material.
OK, I've set the question wrong, I want to know how to calculate each component of force acting upon each atom.
Yeah i know that, but didn't know that term.
Oh, and manganese is not simple cubic. The only element that is simple cubic is polonium.
Thanks, but for this example let's take it is :)
Simple coulomb force. As approximation, you could consider both electrons and nuclei at the same position. The distance between atoms depends on the material and lattice structure.
It depends on the material. For a simple cubic lattice, you have vibrations in 3 dimensions, with 6 degrees of freedom per atom and therefore an average of 3kT of energy per atom with the Boltzmann constant k. Electrons are more complicated and depend on the band structure - for an isolator, you can neglect them.
So for calculation I'm using just electrons from last orbital or all electrons?
OK, and if we are looking at just one crystal cube with 8 atoms and we know the temperature and mass of this cube how can we calculate energy of this crystal?
Thanks for your answers.
You are looking for all particles you want to consider.
I thought it would be more simple with just 8 atoms, but OK, let's say that this material has 16000000 atoms and we know the temperature and mass of this material, what is the average energy than?
~3kT per atom, with k=1.38*10-23 J/K and T=300K this corresponds to 1.2*10-20 J per atom. You can multiply that with the number of atoms to get a rough estimate of the total energy. You can divide it by the mass of a single atom to get the specific heat (J/kg).
Usually, this is an overestimation of the total thermal energy, a better calculation would use the Debye model.
Related to Calculating force between atoms
What is the formula for calculating the force between two atoms?
The formula for calculating the force between two atoms is given by the Coulomb's Law, which states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
How do you determine the distance between two atoms?
The distance between two atoms can be determined by measuring the distance between their nuclei. This can be done using techniques such as X-ray crystallography or electron microscopy.
What factors affect the force between two atoms?
The force between two atoms is affected by the charges of the atoms, the distance between them, and the medium in which they are interacting. The presence of other atoms or molecules in the vicinity can also affect the force between two atoms.
Can the force between two atoms be attractive or repulsive?
Yes, the force between two atoms can be either attractive or repulsive. If the two atoms have opposite charges, the force between them will be attractive. However, if they have the same charge, the force will be repulsive.
How is the force between two atoms related to their bond strength?
The force between two atoms is directly related to their bond strength. A stronger force between two atoms indicates a stronger bond between them, while a weaker force indicates a weaker bond. This force can be used to predict the stability of a molecule and its likelihood of forming bonds with other atoms.
  • Atomic and Condensed Matter
