Calculating the divergence of r(arrow)/r^a and finding charge density
In summary, the conversation discusses a three-part problem involving calculating the divergence and curl of a given field and finding the charge density that would produce the field. The attempt at a solution involves using the divergence theorem to calculate the surface integral and finding the divergence in spherical coordinates. However, the correct way to express the divergence in spherical coordinates is not just the derivative with respect to r, but also involves a Dirac delta function. Therefore, the final expression for the charge density is incorrect. The conversation ends with the expert providing guidance on how to correctly calculate the divergence and use the divergence theorem.
mjordan2nd
177
This is a three part problem. My first task is to calculate the divergence of [tex]\vec{r}/r^{a}[/tex]. Next, I am to calculate its curl. Then I'm supposed to find the charge density that would produce the field
[tex]\vec{E}=\frac{q\vec{r}}{4\pi\epsilon_{0}r^{a}}[/tex]
I calculated the curl by first calculating the surface integral through a sphere of r/r^a:
[tex]\oint\frac{\vec{r}}{r^{a}}r^{2}d\phi sin\theta d\theta \hat{r}=\frac{4\pi\left|\vec{r}\right|}{r^{a-2}}[/tex]
By the divergence theorem [tex]\frac{4\pi\left|\vec{r}\right|}{r^{a-2}}=\int_{v}\nabla\bullet\frac{\vec{r}}{r^{a}}d\tau=\int_{v}\frac{4\pi\left|\vec{r}\right|}{r^{a-2}}\delta^{3}(\vec{r})d\tau[/tex]
Which implies that the divergence of r/r^a is [tex]\frac{4\pi\delta^{3}(\vec{r})}{r^{a-3}}[/tex].
This would eventually give me the charge density as [tex]\frac{q\delta^{3}(r)}{r^{a-3}}[/tex]
Does this look correct? Any help would be appreciated. Thanks in advance.
Look at the expression of the curl in spherical coordinates. What happens if you calculate the curl of a field that has only a radial component?
I don't see how you get what you get "by the divergence theorem". Use the divergence in spherical coordinates to take the divergence of your field correctly. You don't get a Dirac delta function for all values of a.
Sorry, I didn't post that earlier. I calculated the curl of the field to be 0.
As for the dirac-delta function, I only learned about that a few days ago and I have a very un-intuitive, elementary understanding of it. That said, I don't see why the dirac-delta function isn't applicable for all values of 'a' since the divergence outside of the origin should be 0 for a field directed radially outward. I didn't have any test to check my answer except plugging 3 into the value for 'a', which reduces to the normal electric field, and my answer checks out at that point.
According to my understanding of the divergence theorem the surface integral of a field through a surface, which I chose to be a sphere, become the volume integral of the divergence of that field. In the following equation:
[tex]\int_{v}\nabla\bullet\frac{\vec{r}}{r^{a}}d\tau=\int_{v}\frac{4\pi\left|\vec{r}\right|}{r^{a-2}}\delta^{3}(\vec{r})d\tau[/tex]
The integral on the right hand side when evaluated has the same value as the surface integral for my field. Since the volumes of both integrals are the same I reasoned that the integrands must be the same.
Could you please point me in the right direction as to what I may be doing wrong.
Thanks for the response.
The divergence theorem is not what you say it is. It relates a volume integral to a surface integral. Please look it up.
Also look up how to express the divergence in spherical coordinates. In spherical coordinates the radial piece of the divergence is not just the derivative with respect to r. So look it up and take the correct divergence. Then you will see that if a = 2, you get something that is zero everywhere except at r = 0. That's where the Dirac delta function comes in.
Related to Calculating the divergence of r(arrow)/r^a and finding charge density
What is the equation for calculating the divergence of r(arrow)/r^a?
The equation for calculating the divergence of r(arrow)/r^a is div(r(arrow)/r^a) = 1/r^a * (a + n). This equation represents the change in density of a vector field as it moves away from a given point.
What does the divergence of a vector field tell us?
The divergence of a vector field tells us about the sources and sinks of the field. A positive divergence indicates a source, while a negative divergence indicates a sink. A divergence of zero indicates a uniform flow.
What is the significance of finding the charge density when calculating the divergence of a vector field?
Finding the charge density is important when calculating the divergence of a vector field because it allows us to determine the strength and direction of the electric field at a given point. This is useful in understanding the behavior of electrically charged particles in a given field.
Can the divergence of a vector field be negative?
Yes, the divergence of a vector field can be negative. This indicates that the field is converging at a given point, rather than diverging. This can occur when there is a sink or a negative charge present in the field.
How can the divergence of a vector field be used in practical applications?
The divergence of a vector field has many practical applications, such as in fluid dynamics, electromagnetism, and meteorology. It can be used to understand the flow of fluids, the behavior of electric and magnetic fields, and the movement of air in weather patterns.
