Can a differential equatio have NO solution ?
In summary, the conversation discusses the possibility of a differential equation having no solution. It is mentioned that there are many boundary value problems that have no solution, and that it is possible for a differential equation to be so complicated that it has no solution. The Navier-Stokes equation is given as an example, which is a complicated partial differential equation that is extremely difficult to solve. It is also mentioned that some equations, such as the non-linear equations used in GPS satellites, have no exact solution but can be approximated using other methods, such as the Taylor expansion. Overall, the conversation highlights the complexity and difficulty of finding solutions for certain differential equations.
mhill
189
Can a differential equatio have NO solution ??
I mean in many cases as mathematician you must recall to an existence theorem for PDE or ODE but my question is can be a differential equation so complicated that has NO solution at all ? , i mean that for example there is no function f(x,y) or h(x) that satisfy a certain linear or nonlinear differential equation.
I'm not sure why you say "so complicated". It is (fairly) easy to prove that if f is differentiable, then its derivative satisfies the "intermediate value theorem" (If f(a)= A, f(b)= B and C is some number between A and B then there exist c between a and b such that f(c)= C).
If f(x) is a function that does not have that property (f(x)= 0 if x is irrational, 1 if x is rational is an example), then there cannot be a function y that satisfies dy/dx= f(x).
More simply there exist many "boundary value problems" that have no solution. There is no function satisfying d2y/dx2+ y= 0, and y(0)= 0, y([itex]\pi[/itex])= 1.
it also depends on domain
(y')^2+1=0
has no real solutions
contradictory equations like
y'=y'+1
have no solution
yea but that's given an initial value. and even if the function does not have a solution on a given interval, it CAN have solutions on other intervals and those are still considered solutions. Lurflurf has the more correct explanation although (y')^2+1=0 may have a solution in the complex plane? (i don't know i haven't taken complex variables).
Try the Navier Stokes equation, I believe if you can prove that in three dimensions solutions always exist (existence), or that if they do exist they do not contain any infinities, singularities or discontinuities (smoothness) you get a nice amount of cash. It's a complicated partial differential.
And no I wouldn't dream of trying it myself. :smile:
http://en.wikipedia.org/wiki/Navier-Stokes_equations
Even though turbulence is an everyday experience, it is extremely difficult to find solutions, quantify, or in general characterize. A US$1,000,000 prize was offered in May 2000 by the Clay Mathematics Institute to whoever makes preliminary progress toward a mathematical theory which will help in the understanding of this phenomenon.
The numerical solution of the Navier–Stokes equations for turbulent flow is extremely difficult, and due to the significantly different mixing-length scales that are involved in turbulent flow, the stable solution of this requires such a fine mesh resolution that the computational time becomes significantly infeasible for calculation (see Direct numerical simulation). Attempts to solve turbulent flow using a laminar solver typically result in a time-unsteady solution, which fails to converge appropriately. To counter this, time-averaged equations such as the Reynolds-averaged Navier-Stokes equations (RANS), supplemented with turbulence models (such as the k-ε model), are used in practical computational fluid dynamics (CFD) applications when modeling turbulent flows. Another technique for solving numerically the Navier–Stokes equation is the Large-eddy simulation (LES). This approach is computationally more expensive than the RANS method (in time and computer memory), but produces better results since the larger turbulent scales are explicitly resolved.
Many differentials have no exact solution and other methods have to be used to approximate them, a good example is the non-linear equations that regulate the position systems on GPS Satellites, taking account of signal time at c.
peace upon u all
i was wondering about this point exactly .. why shall differential equation have NO solution .. and supos a physical case described with a differential equation that have no solution .. what does that mean ?
does it have relation to chaotic analysis for some cases ??
It just means that there is no precise solution. You could still find a solution that was close to it so as to make no difference by other means. In the same way some integrals have no solution but can be approximated with infinite slices of the graph. This is where the idea of the Taylor expansion comes in.
erm ... do u mean that we can use a solution of a similar differential equation ??
or u mean trying to solve it numerically ??
No you couldn't solve it numerically but you could approximate it as x approaches infinity say. Like the satellite example they use a more advanced form of triangulation to map the positions, that is accurate enough so as to not make much difference. Essentially that is a method that doesn't even require differentiation as such. Even the relativistic concerns are handled separately.
peace upon u dear
mmmm
i'm thankful a lot for this hint nut do u have more illustration for this method u metioned ??
or what is it mathematically based on ??
my best wishes
peace upon u dear
mmmm
my best wishes
ALYAZAN said:
peace upon u dear
mmmm
my best wishes
http://en.wikipedia.org/wiki/Taylor_series
[tex]1 + \frac{x^1}{1!} + \frac{x^2}{2!} + \frac{x^3}{3!} + \frac{x^4}{4!} + \frac{x^5}{5!}+ \cdots \qquad = \qquad 1 + x + \frac{x^2}{2} + \frac{x^3}{6} + \frac{x^4}{24} + \frac{x^5}{120} + \cdots.\![/tex]
Taylor expansion for ex.
In sum form:
[tex]e^x = \sum_{n=0}^\infty \frac{x^n}{n!} = 1 + x + \frac{x^2}{2!} + \frac{x^3}{3!} + \cdots\text{ for all } x\![/tex]
Sin function:
[tex]\sin x = \sum_{n=0}^{\infty} \frac{(-1)^n}{(2n+1)!} x^{2n+1}\quad = x - \frac{x^3}{3!} + \frac{x^5}{5!} - \cdots\text{ for all } x\![/tex]
Note as you add more terms ex and sin(x) the approximation becomes more accurate.
You forgot to add [tex] \infty [/tex] on top and do you mean that as you add more terms, the approximation for [tex] e^x [/tex] and sin(x) become more accurate maybe? This is done a lot when you solve the DE using power series / method of Frobenius. Sometimes you are lucky to recognize a pattern and the appropriate function and sometimes you are not and just have to leave the answer in terms of an infinite sum.
Considering I lazily cut and pasted that out of wiki, huh? Thanks. :smile:
I did indeed mean that too.
Always check your work even if you cut and paste. :redface:
Related to Can a differential equatio have NO solution ?
1. Can a differential equation have no solution?
Yes, it is possible for a differential equation to have no solution. This can happen when the equation is not well-defined or when the initial conditions do not satisfy the equation.
2. What does it mean for a differential equation to have no solution?
If a differential equation has no solution, it means that there is no function that satisfies the equation and its initial conditions. In other words, there is no solution that can be found using standard methods of solving differential equations.
3. What causes a differential equation to have no solution?
There are various reasons why a differential equation may have no solution. Some common causes include incorrect formulation or simplification of the equation, missing initial conditions, or the equation being mathematically impossible to solve.
4. Can a differential equation have multiple solutions?
Yes, a differential equation can have multiple solutions. This can happen when the equation has more than one set of initial conditions that satisfy the equation. It can also happen when the equation is non-unique, meaning there are multiple functions that satisfy the equation.
5. How do you know if a differential equation has no solution?
To determine if a differential equation has no solution, you can try to solve the equation using standard methods. If you are unable to find a solution or if the solution does not satisfy the initial conditions, then the equation has no solution. Additionally, you can also check for any mathematical inconsistencies or errors in the formulation of the equation.
  • Differential Equations
