Classical longitudinal wave on taut String
In summary, The problem in question involves a string with uniform mass density mu_0 and equilibrium tension T_0, stretched between x = 0 and x = a. The question asks for the equation governing small longitudinal oscillations of the string and the velocity of the waves. The method used involves calculating the general form of T(L) and finding the force on an infinitesimal stretch of the string, then equating it to the acceleration using Newton's second law. However, there are difficulties with longitudinal waves where the tension varies across the string.
Gianni2k
Hi guys, this is Barton Zwiebach's Introduction to String theory question 4.2 on the longitudinal wave on a taut string. The problem is purely classical and I seem to obtain a solution which seems far too complicated for me. If anyone has the answers it would be great, if not just your help would be amazing. For people that don't have the book this is how the question goes.
"Consider a string with uniform mass density mu_0 stretched between x = 0 and x = a. Let the equilibrium tension be T_0. Longitudinal waves are possible if the string tension varies at it stretches or compresses. For a piece of this string with equilibrium length L, a small change in its length deltaL is accompaigned by a change in the tension deltaT where:
1/t_0 = (1/L)(deltaL/detaT)
where t_0 is a tension coefficient with units of tension. Find the equation governing small longitudinal oscillations of the string. Give the velocity of the waves."
many thanks.
Just so you know what I did is calculate the general form of T(L):
T(L) = t_0 ln(L/a) + T_0
Then find the force on an infinitesimal stretch of the string then finally equate this to the acceleration via Newton's second law. The method is consistent for tangential waves but I have problems with longitudinal ones where the tension varies across the string.
I would like to first clarify that the solution to this problem may not be "too complicated," but rather it may require a deeper understanding of the concepts and principles involved. It is important to approach the problem with a clear and logical thought process.
To begin, let us first define the variables in the problem. The string has a uniform mass density of mu_0 and is stretched between x = 0 and x = a with an equilibrium tension of T_0. The equilibrium length of a piece of the string is L, and any small change in its length is denoted by deltaL. This change in length is accompanied by a change in tension, deltaT, which is related to a tension coefficient t_0.
To find the equation governing small longitudinal oscillations of the string, we can use the general wave equation:
d^2u/dt^2 = v^2 * d^2u/dx^2
where u is the displacement of the string, t is time, and x is position along the string. The velocity of the wave is denoted by v.
In this case, the tension of the string is not constant, but varies with the stretching or compressing of the string. This means that the tension coefficient t_0 is also a function of position, and can be expressed as:
t_0 = t_0(x)
Substituting this into the wave equation, we get:
d^2u/dt^2 = v^2 * (1/t_0) * d^2u/dx^2
We can rearrange this equation to get:
d^2u/dt^2 = (v^2/t_0) * d^2u/dx^2
Now, using the given relationship between deltaL and deltaT, we can substitute for t_0 and get:
d^2u/dt^2 = (v^2/L) * (deltaL/deltaT) * d^2u/dx^2
Simplifying further, we get:
d^2u/dt^2 = (v^2 * deltaT/L) * d^2u/dx^2
This is the equation governing small longitudinal oscillations of the string. We can also see that the velocity of the wave is given by:
v = sqrt(T_0/mu_0)
where T_0 is the equilibrium tension and mu_
Related to Classical longitudinal wave on taut String
1. What is a classical longitudinal wave on a taut string?
A classical longitudinal wave on a taut string is a type of mechanical wave that travels along the length of a string or rope. It is characterized by particles in the medium oscillating back and forth in the same direction as the wave is traveling. This type of wave can be seen in guitar strings, telephone wires, and other similar structures.
2. How does a classical longitudinal wave on a taut string differ from a transverse wave?
A classical longitudinal wave on a taut string differs from a transverse wave in the direction of particle oscillation. In a transverse wave, particles oscillate perpendicular to the direction of wave travel, while in a longitudinal wave, particles oscillate parallel to the direction of wave travel.
3. What factors affect the speed of a classical longitudinal wave on a taut string?
The speed of a classical longitudinal wave on a taut string is affected by the tension in the string, the density of the string material, and the length of the string. An increase in tension or density will result in a higher wave speed, while a longer string will have a slower wave speed.
4. What happens to the amplitude of a classical longitudinal wave on a taut string as it travels?
The amplitude of a classical longitudinal wave on a taut string remains constant as it travels through the medium, as long as there are no external forces acting on the string. This means that the maximum displacement of particles from their equilibrium position remains the same throughout the wave's journey.
5. How does the frequency of a classical longitudinal wave on a taut string affect its wavelength?
The frequency of a classical longitudinal wave on a taut string is directly proportional to its wavelength. This means that as the frequency increases, the wavelength decreases, and vice versa. This relationship is described by the wave equation, v = fλ, where v is the wave speed, f is the frequency, and λ is the wavelength.
