Confused about Feynman diagrams
In summary: But ultimately the answer to "why does this happen" is something that you'll need to find from the physics books.
dyn
773
61
Hi. I'm self-studying particle physics.Just been looking at some questions where a reaction is listed and the questions asks to draw a Feynman diagram for the reaction and state which force is involved. I have the answers but they all seem so random and I would like to know how to decide which force is involved. If possible I would like any explanation for the following examples -
1 - an electron and positron annihilate forming a photon which then decays to a muon and an antimuon
This is an EM interaction but I have read that only the Weak Interaction changes particle flavour. But hasn't the flavour changed here from electron to muon ?
2- an electron and positron move to the right (time axis) they are joined by a vertical line and 2 photons are emitted at the vertices. Is this electron-positron annihilation ? Why the vertical line ? Why do the electron and positron just not meet and annihilate to form a photon ?
3 π+ → νμ + μ+ via a W+ boson.
I have read that "the weak force cannot turn quarks into leptons and vice vera". But in this reaction hasn't quarks and antiquarks turned into leptons and antileptons ?
Thanks
PS I have the books by Martin & Shaw , Thompson , Barr & Devenish but none of them really explain how to construct Feynman diagrams just from a given reaction.
No. The total electron and muon numbers before and after the reaction are zero. The anti-particles count as negative.
Also note that the photon is not an on-shell photon and does not "decay". It is just an s-channel interaction with a virtual photon.
Forming a single on-shell photon would violate energy-momentum conservation.
Same answer as for (1). The total baryon and lepton numbers before and after the decay are zero.
Likes dyn
How? Initially your electron number is: [itex] L_e(e^-) + L_e(e^+) = -1 + 1 = 0[/itex], and at the final state is 0+0 =0 (conserved).
Similarily for the muon lepton numbers (0+0 initially , +1-1 finally).
Because you can find a reference frame (by a Lorentz transformation) where the total momentum of the electron+positron system is zero (center of mass frame)... In that frame, conservation of momentum would imply that the single photon would have to have 0 momentum... that's impossible for real photons (since they are massless and have energy E=pc). If you allow two (or more) photons in the final state then you don't have this problem.
It's a [itex]u\bar{d} ( \rightarrow W^+ \rightarrow ) \mu^+ +\nu_\mu [/itex]
What do you have initially and what you have finally? The lepton numbers are conserved, the baryon numbers (mesons have 0 baryon number since they are quark+antiquark pairs) are conserved.
the statement "the weak force cannot turn quarks into leptons and vice vera" means that you cannot have something like:
[itex] u \rightarrow l \nu_l[/itex]
(which I think makes sense even from conservation of charge.)
You can have:
[itex] q \bar{q}' \rightarrow l \nu_l[/itex] (eg B-meson leptonic decays) and [itex] q \rightarrow q' l \nu_l[/itex] (eg top semileptonic decays)
In general Feynman diagrams are like art when you want to construct them in a basic level (like a puzzle). They can give you an idea of conservation laws (just because conservation laws are always applied in them) and things like that in particle physics... the thing is how deep you want to go into them, since afterall they only represent amplitudes for a given process (which allow you to calculate cross-sections/probabilities). That's why you can see mathematical formulas like: [itex] | \text{Feyn.Diag.1} + \text{Feyn.Diag.2} +... |^2[/itex]... With a QFT in particle physics, you are able to construct the Feynman diagram by reading the Lagrangian and using several rules that are there...
Likes dyn
Thanks both of you. That's a great help. But when just given the reaction and without resorting to QFT how do you know the most likely force involved ? eg. for
Δ++ → p + π+ . the given answer was the Strong interaction but the reaction involves quarks so the force involved could be EM , Strong or Weak. What do I look for to know that the most likely force involved is the Strong one ?
Go by interaction strength. If it is possible via the strong interaction, that is dominant. If not, but it is possible by the electromagnetic interaction, it is that. Otherwise it happens via the weak interaction.
There are a few exceptions (e. g. Z bosons can be relevant even when there is a similar electromagnetic process), but they shouldn't be too relevant here.
Likes dyn
Thanks ! That makes a lot of sense but what about
π+ → μ+ + νμ ?
This involves quarks so could happen by the Strong force but the decay is via the Weak force and the W+ boson. How would I be supposed to know this without any QFT calculations ?
Could it happen with just the strong force? What's the difference between leptons and quarks (they are both fermions but...)?
In your reaction you obviously have leptons in the final state (muon and neutrino). That answers your question.
Also strong force (mediated by gluons) cannot change the flavor of the quarks, in the charged pion you have an up-flavor and down-flavor quarks interacting somehow (there is no vertex in which an u-->d by emitting/absorbing a gluon). W bosons can do that (they can be flavor changing), in fact in vertices with quarks they always do that and you can remember that by charge conservation...
I'm not sure which difference you are referring to ? The only reason I can now see that the reaction couldn't proceed by the Strong Interaction is that quark flavours have changed ie. the number of up minus anti-up has gone from 1 to zero which can only happen with the weak force,
leptons are not seen by strong interactions. That's one distinction (even a definition) between leptons and quarks. So, leptons can't interact via strong interaction... So you can't see gluon+leptons vertices.
Likes dyn
Thanks for your help
I would suggest buying Introduction to Elementary Particles by Griffiths. It may not give instructions on how to create diagrams, but it gives excellent instructions on how to find amplitudes, decays, and cross sections, given a diagram.
Related to Confused about Feynman diagrams
What are Feynman diagrams?
Feynman diagrams are a graphical representation of mathematical calculations used to describe interactions between particles in quantum field theory. They were developed by physicist Richard Feynman in the 1940s and have become a standard tool in theoretical physics.
Why are Feynman diagrams useful?
Feynman diagrams allow scientists to visualize and calculate the probability of particle interactions in a much simpler way than traditional mathematical equations. They also provide a way to organize and interpret complex data, making it easier to understand the underlying physics.
How do I read a Feynman diagram?
A Feynman diagram consists of lines representing particles and vertices representing interactions between particles. The direction of the lines indicates the direction of time, and the lines can also have arrows to represent the direction of charge. The vertices show where particles interact and can have mathematical factors associated with them. The overall structure of the diagram is determined by conservation laws, such as energy and momentum conservation.
What is the significance of the different types of Feynman diagrams?
There are several types of Feynman diagrams, including tree diagrams, loop diagrams, and vertex correction diagrams. Each type represents a different type of interaction between particles and can provide valuable insights into the underlying physics. For example, loop diagrams can represent virtual particles that are not directly observable but still have an effect on the interaction.
How are Feynman diagrams used in research?
Feynman diagrams are used extensively in particle physics research to calculate and predict the outcomes of particle interactions. They have also been applied to other fields, such as condensed matter and nuclear physics. The diagrams are also used in education to help students understand complex concepts in quantum field theory.
