Curve fitting and Plane fitting
In summary, if you have a finite set of functions, and you want to find an equation that will satisfy all the points in a level set, it's possible to use a plane to fit the functions and then find the equation that will represent the value at a given point in time.
elegysix
406
If I have a set of n numbers, (n=0,1,2, ... n-1), what is the maximum number coefficients in a series I would need in order to find y=f(n) true on the integers up to n-1? Or is that something I just have to check after fitting it? ( does it need an nth degree polynomial?)
Another question:
If I have a finite set of functions, Ft(x), and these functions may or may not be similar (i.e. Ft(x) = x, x2, x3... xt ), how can I fit a plane to a set of functions such that F(1,x)=F1(x), F(2,x)=F2(x) ... in order to find an equation F(t,x)?
can/how is this done if each function is a summation? (i.e. F1=[itex]\sum[/itex]a1(n)*xn, F2=[itex]\sum[/itex]a2(n)*xn)
can I find an equation like F(t,x) = [itex]\sum[/itex]G(t)*at(n)*xn that will satisfy this?
thanks
For the first question, n points uniquely identifies a degree n-1 polynomial, which will have n coefficients.
As for your second question I'm not sure but it really depends on the inputs ##F_t## if it's possible to write ##F## in a closed form. If I'm reading you correctly, you want to construct a function based on level set information. Interesting question and I'd like to see what others have to say on this.
If anyone is interested, the problem I'm trying to solve is this:
say we have an NxN (3x3 for this example) matrix that changes over time t. say we have 3 different frames, 1 NxN matrix representing the value of each pixel in a screen for each frame. so 3 matrices total
If I count from left to right and down across the matrix, for a 3x3 matrix, the last (bottom right pixel) will be number 9. in mod 3 (or mod N) , the value is 33 or (NN), which is also the coordinates of the pixel (omitting the single values like 01, 02, 03 by adding 3 (N) ).
matrix numbered as:
|1 2 3 | --> | 11 12 13 |
|4 5 6 | --> | 21 22 23 |
|7 8 9 | --> | 31 32 33 |
So I want to take the values in the matrix and make a set {a1,a2,a3...a9}
and fit a function to them, F1(x), which is no problem so far.
And do the same for each frame, so that I have a function for each frame, F1(x), F2(x), F3(x). no problem this far.
Now comes the problem: I want to combine these functions together so that I can find any pixel's value by entering the time, t, and the pixel number, x. So that Ft(x) can be given by F(t,x).
that's where if F1 = [itex]\sum [/itex] a(n)*xn and F2 = [itex]\sum [/itex] b(n)*xn and similarly for F3
can they be combined somehow into a function F(t,x) such as [itex]\sum[/itex] G(t)*Z(n)*xn
so that G(1)*Z(n) gives a(n), and G(2)*Z(n) = b(n) and so forth ?
How can I solve for what G(t) and Z(n) are? or is it possible?
The point is to be able to have an animation or video be in a formula, and not need so much data to transfer. the quality I believe would depend on the expansion of n, taking n out to infinity would produce perfect quality.
thanks
Related to Curve fitting and Plane fitting
1. What is curve fitting?
Curve fitting is a statistical method used to find the best-fit curve or line that can represent a set of data points. It involves finding the mathematical equation that closely fits the data points and can be used to make predictions or analyze the relationship between variables.
2. How is curve fitting different from regression analysis?
Curve fitting and regression analysis are similar techniques used to analyze data, but the main difference is that curve fitting involves finding the best-fit curve for a set of data points, while regression analysis involves finding the best-fit line for a set of data points and predicting the relationship between variables.
3. What are the applications of curve fitting in science?
Curve fitting is widely used in various scientific fields, including physics, chemistry, biology, and engineering. It can be used to analyze experimental data, make predictions, and understand the relationships between variables in complex systems.
4. How does plane fitting work?
Plane fitting is a technique used to find the best-fit plane that can represent a set of 3D data points. It involves finding the equation of the plane that minimizes the distance between the data points and the plane. This method is commonly used in computer graphics, robotics, and 3D modeling.
5. What are the limitations of curve fitting and plane fitting?
Curve fitting and plane fitting are not perfect methods and have certain limitations. They may not accurately represent all data points, especially if the data is noisy or contains outliers. Additionally, these methods may not work well for complex data sets with multiple variables and nonlinear relationships.
