- #36
PeterDonis
Mentor
- 46,080
- 22,868
EPR said:he was saying the 'classical' electromagnetic wave of a single photon was traveling through both slits and causing the interference. If this was the case(assume a 19 century knowledge and setup - prior to qm), one would probably expect interference effects from a single photon on the plate(provided the electromagnetic wave spread is bigger than the distance between the slits).
There is no such thing as "a single photon" in classical EM. In classical EM, as I said in post #34, no matter how faint you make the light source, you never get dots on the detector screen. Also, if you put something that detects the passage of light at the slits, classical EM predicts it will register light passing continuously at both slits, not discrete "photon" events at one slit or the other.
So to say that classical EM would lead you to expect "interference effects from a single photon" is not even wrong. What you say at the end of your post...
EPR said:he seemed intent on using classical electrodynamics to explain single photon interference pattern. Which is impossible.
...is quite correct, and if you had just said that and no more, I would have no objection. But you didn't. You said other things that are not correct because they misrepresent what classical EM says.
