Eigevalues and eigevectors of an Hamiltonian
  • Thread starter 19matthew89
  • Tags
    Hamiltonian
In summary, the student attempted to solve the homework problem by using the basis {|++>; |+->; |-+>; |-->} and {|11>; |10>; |1-1>; |00>} to estimate the action of A(S_{1z} - S_{2z}) and B(S_{1} · S_{2}) and the I've correlated the two bases using Clebcsh-Gordan coefficients. However, this method does not produce a diagonal matrix, so the student attempted to find eigenvalues and eigenvector by diagonalizing the 4x4 matrix.
19matthew89
47
Hi,
I must find eigenvalues and eigenvector of this Hamiltonian, which describes a system of two 1/2-spin particles.
H = A([itex]S_{1z}[/itex] - [itex]S_{2z}[/itex]) + B([itex]S_{1}[/itex] · [itex]S_{2}[/itex])
where [itex]S_{1}[/itex] and [itex]S_{2}[/itex] are the two spins, [itex]S_{1z}[/itex] and [itex]S_{2z}[/itex] are their z-components, and A and B are constants.
Since it's easy finding eigenvalues and eigevectors of ([itex]S_{1}[/itex]· [itex]S_{2}[/itex]) in total spin base (I can write it as (0.5)([itex]S^{2}[/itex]-[itex]{S_{1}}^{2}[/itex]-[itex]{S_{2}}^{2}[/itex]) I've thought I should use this base, but [itex]S_{1z}[/itex] and [itex]S_{2z}[/itex] do not commute.
I've tried to solve this problem in this way. I know you can write this Hamiltonian using the basis {|++>; |+->; |-+>; |-->} and, if I know how H acts on this basis I can write a matrix which represents the action of H. So I computed how H acts using the basis {|++>; |+->; |-+>; |-->} to estimate the action of A([itex]S_{1z}[/itex] - [itex]S_{2z}[/itex]) and the basis {|11>; |10>; |1-1>; |00>} to estimate the action of B([itex]S_{1}[/itex] · [itex]S_{2}[/itex]) and the I've correlated the two bases using Clebcsh-Gordan coefficients. Is this way of proceeding correct?
At the end I've found a matrix in {|++>; |+->; |-+>; |-->} which, obviously, is not diagonal. How can now find eigenvalues and eigenvector? Diagonalizing? Is there a faster way to get a diagonal matrix?
Thanks
Why do you say S1z and S2z don't commute?
What matrix did you end up with? It seems to me it should reduce down to a problem of diagonalizing a 2x2 matrix.
Because in the basis of {[itex]S^{2}[/itex], [itex]S_{z}[/itex], [itex]{S_{1}}^{2}[/itex], [itex]S_{2}^{2}[/itex]} the operator [itex]S_{1z}[/itex] and [itex]S_{2z}[/itex] do not commute with the other elements of the basis. At the end I've found a 4x4 matrix (each basis is made of 4 elemnts). In the basis {|++>; |+->; |-+>, |-->} the matrix is the one shown in pdf file (I don't know how to insert a matrix eheheh:biggrin:).
  • Matrix.pdf
Your terminology is all messed up.
  1. The operators aren't elements of the basis. The simultaneous eigenstates of the operators are the basis, i.e. [itex]\{\vert 1 1 \rangle, \vert 1 0 \rangle, \vert 1 -1 \rangle, \vert 0 0 \rangle \}[/itex] is one of the bases you're referring to.
  2. It doesn't make sense to say the operators don't commute with elements of a basis. Operators commute or don't commute with other operators.
  3. "S1z and S2z don't commute" means [S1z,S2z]≠0, which isn't true. S1z and S2z do commute.
  4. What you meant was that S1z and S2z don't commute with S2. As a consequence, the first term of the Hamiltonian isn't represented by a diagonal matrix in the basis above.
Now on to your matrix. (You can right-click on the matrix and choose "Show Source" to see the LaTeX markup.)
\begin{pmatrix}
B/4 & 0 & 0 & 0 \\
0 & -B/4+A & B/2 & 0 \\
0 & B/2 & -B/4-A & 0 \\
0 & 0 & 0 & B/4
\end{pmatrix}
[strike]Can you show how you calculated the middle block? The B terms I get differ from yours by a factor of [itex]\sqrt{2}[/itex].[/strike]
EDIT: I think your matrix is fine. I missed a factor of [itex]\sqrt{2}[/itex] somewhere.
You should be able to see what two of the eigenvalues and corresponding eigenvectors are by inspection. You just need to diagonalize the submatrix to find the remaining two.
Thank you so much!
Yes, you're right, I'm sorry! I should have written the eigenstates as basis while the list I've put down is a Complete Set of Commuting Observabels to which the basis
corresponds.
Thanks for clarifying my terminology, too! I'm very grateful to you for letting me know that my line of reasoning, despite my lexicon, is correct.:blushing: (I'll go and compute again the matrix to find the missing factor of [itex]\sqrt{2}[/itex]).
Bye
P.S. I thank you also for the hint how to post a matrix
I think your matrix is correct, though I guess it can't hurt to recheck your work.
Related to Eigevalues and eigevectors of an Hamiltonian
1. What are eigenvalues and eigenvectors of an Hamiltonian?
Eigenvalues and eigenvectors are mathematical concepts used to describe the behavior of a physical system, specifically the Hamiltonian. An eigenvalue is a scalar quantity that represents the energy associated with a particular state of the system. An eigenvector is a vector that represents the corresponding state of the system.
2. How are eigenvalues and eigenvectors calculated for a Hamiltonian?
The eigenvalues and eigenvectors of a Hamiltonian are calculated by solving the Schrödinger equation, which describes the time evolution of a quantum system. This equation is a differential equation that can be solved numerically or analytically, depending on the system.
3. What is the significance of eigenvalues and eigenvectors in quantum mechanics?
Eigenvalues and eigenvectors play a crucial role in quantum mechanics as they represent the allowed energy states and corresponding wavefunctions of a physical system. They provide a way to understand and predict the behavior of quantum systems, such as atoms, molecules, and subatomic particles.
4. Can the eigenvalues of a Hamiltonian change?
The eigenvalues of a Hamiltonian can change if the system is subjected to external forces or interactions. For example, in an atom, the energy levels (eigenvalues) can shift when the atom is exposed to an electric or magnetic field.
5. How are eigenvalues and eigenvectors used in practical applications?
Eigenvalues and eigenvectors are used in many practical applications, such as in quantum chemistry, where they are used to calculate the electronic structure of molecules. They are also used in quantum computing, where they form the basis for quantum algorithms and quantum gates. Additionally, in physics, eigenvalues and eigenvectors are used to describe the energy states of particles in quantum field theory.
