Electrode Polarization and Conductivity
In summary, the use of a 4 electrode measurement with an alternating current is recommended to avoid the polarization layer that can interfere with conductivity measurements in solutions. However, there is limited information available on the dynamics of these layers and their relationship to ion mobility. The concept of a double layer, specifically the Helmholtz and Stern layers, may provide some insight but is not explicitly mentioned in electrochemistry literature. Further research is needed to fully understand the evolution of these layers and their impact on conductivity measurements.
fsonnichsen
62
The common mantra is that when measuring conductivity in solutions the electrodes will build up a polarization layer and disturb the measurement, thus a 4 electrode measurement is used and an alternating current impressed up on the outer electrodes, usually around 1000 hz.
I have been trying to learn more about the dynamics of these layers but my search of the journals and my somewhat limited chemistry library reveal nothing on this issue other than a brief mention. I would expect the theory of Kolrausch et. al. for ion mobility would play into this but I cannot find either theoretical information on the evolution of the layer with time, nor any experimental data.
Does anyone here know of a journal or textbook resource that deliberates on this, especially mathematically?
Thanks
Fritz
Chemistry news on Phys.org
The tomes of electrochemistry never seem to state this explicitly, but it makes sense that these develop as double layers--Helmholtz, Stern etc.
thanks
Fritz
Related to Electrode Polarization and Conductivity
What is electrode polarization?
Electrode polarization is a phenomenon that occurs when an electric current is passed through an electrolyte solution with two electrodes. It causes a build-up of charges at the electrode surfaces, resulting in a decrease in conductivity and potential measurements.
How does electrode polarization affect conductivity?
Electrode polarization decreases the overall conductivity of an electrolyte solution by creating a barrier at the electrode surfaces. This barrier hinders the movement of ions and reduces the flow of electric current.
What factors contribute to electrode polarization?
Several factors can contribute to electrode polarization, including the type of electrode material, the concentration and nature of electrolyte solution, and the applied electric potential. These factors can influence the formation and stability of the charge build-up at the electrode surfaces.
How can electrode polarization be minimized?
Electrode polarization can be minimized by choosing the appropriate electrode material and electrolyte solution, as well as applying a sufficient amount of electric potential to overcome the barrier. Stirring the solution can also help reduce the effects of electrode polarization.
What is the relationship between electrode polarization and conductivity measurements?
The presence of electrode polarization can significantly affect the accuracy and reliability of conductivity measurements. It can cause variations in the measured conductivity values, making it essential to consider and minimize its effects during experimentation and data analysis.
  • Beyond the Standard Models
11K
  • Astronomy and Astrophysics
  • Science and Math Textbooks
  • Other Physics Topics
