- #36
Astronuc
Staff Emeritus
2023 Award
- 21,955
- 6,442
The Plasmadynamics & Electric Propulsion Laboratory has webpage that answers most of one's questions.darkdave3000 said:I just found this article:
https://futurism.com/nasas-new-ion-thruster-breaks-records-could-take-humans-to-mars
In comparison to the ESA/Australian Dual Stage 4 grid is this NASA hall thruster higher or lower in specific impulse? What about thrust?
https://pepl.engin.umich.edu/project/x3-nested-channel-hall-thruster/
“Nested-channel Hall thrusters have been identfied as a means to increase Hall thruster power levels above 100 kW while maintaining acceptable device size and mass. In a recent Broad Agency Announcement, NASA identified high-power electric propulsion (up to 300 kW) as enabling for a variety of mission structures, including human space exploration. Additionally, a 2010 NASA team found that high-power electric propulsion was key to allowing affordable travel to asteroids and near-Earth destinations by reducing launch mass up to 50%. NASA hopes to implement a system that has a broad power and specific impulse range for maximum flexibility within a mission. The multiple discharge channels of a nested-channel Hall thruster allows for throttling far beyond that of a single-channel Hall thruster. . . .
“The X3 is designed to operate efficiently on both krypton and xenon propellants from 200–800 V discharge voltage and at total discharge currents up to 250 A. The total power throttling range of the X3 is 2–200 kW. The thruster is approximately 80 cm in diameter and weighs 230 kg. Each of the three discharge channels features an inner and outer electromagnet for a total of six, each of which is controlled separately.”
Some performance characteristics
During high-power tests of the X3, Hall et al. “successfully measured the performance of the X3 for a range of conditions spanning total power levels from 5 to 102 kW. These conditions consisted of discharge voltages from 300 to 500 V and current densities that were 0.63, 1.00, and 1.26 of a reference value. The seven channel combinations of the thruster were throttled across this range of settings. For each test point, [Hall et al.] directly measured thrust using a high-power inverted-pendulum thrust stand, and from those thrust measurements and thrust telemetry, we calculated specific impulse and efficiency values.” The “results demonstrated that a three-channel 100-kW class NHT can offer comparable or even improved performance over high-power single-channel thrusters. The X3 demonstrated total efficiencies ranging from 0.54–0.67 and total specific impulses from 1800–2650 seconds [during this test], experiencing the peak efficiency at 500 V discharge voltage.
https://phys.org/news/2018-02-x3-ion-thruster-propel-mars.html
https://www.nasa.gov/content/characterization-of-a-100-kw-three-channel-nested-hall-thruster/
https://en.wikipedia.org/wiki/Hall-effect_thruster
A Hall-effect thruster is different than the DS4G and a magnetic plasma dynamic (MPD) thruster, which was considered during the mid-1980s. Each technology has it's challenges, which are common, e.g., material erosion/degradation. They all need a power source, which would be nuclear.
