Ginzburg Criterion: Why Choose Volumes of Correlation Length?
  • Thread starter wdlang
In summary, when studying superconductivity, it is important to choose a volume with a size comparable to the correlation length, as this is the natural scale for the order parameter and electromagnetic field. Choosing a larger volume may result in a decrease in fluctuations compared to the average value, but it will also eliminate the effects of these two important scales.
wdlang
307
indeed, the fluctuations should be smaller than the average value of the order parameter
but why choose a volume with size of the correlation length?
why cannot we choose a larger volume? as the volume increases, surely the fluctuations will
decreases relative to the average value
If your question is in the context of superconductivity then:
The coherence length is the "natural scale" set by parameters of GL equation. Likewise the penetration depth sets a "natural scale" for phenomena related to EM field. For example if the size of your system is much less than penetration depth you can forget about the presence of EM field. The same argument for your question.
Related to Ginzburg Criterion: Why Choose Volumes of Correlation Length?
What is the Ginzburg Criterion?
The Ginzburg Criterion is a physical theory that is used to determine the critical behavior of a material undergoing a phase transition. It is named after Soviet physicist Vitaly Ginzburg, who developed the theory in the 1950s.
How does the Ginzburg Criterion work?
The Ginzburg Criterion is based on the concept of correlation length, which is a measure of how far apart two points in a material must be before they are considered statistically independent. When the correlation length reaches a certain threshold, it indicates that a material is undergoing a phase transition.
Why is the Ginzburg Criterion important?
The Ginzburg Criterion is important because it provides a way to predict the critical behavior of a material during a phase transition. This is useful for understanding and studying various physical phenomena, such as superconductivity and magnetic ordering.
What are the volumes of correlation length?
The volumes of correlation length refer to the regions in which the correlation length is relevant. In other words, it is the size of the material that is affected by the phase transition. The Ginzburg Criterion helps to determine the size of these volumes, which can vary depending on the material and the conditions of the phase transition.
Why choose volumes of correlation length in the Ginzburg Criterion?
The choice of volumes of correlation length in the Ginzburg Criterion is important because it allows for a more accurate and precise prediction of the critical behavior of a material. By considering the relevant volumes, scientists can better understand and analyze the phase transition and its effects on the material.
  • Atomic and Condensed Matter
  • Mechanical Engineering
