If a photon's emission is detected is it real or virtual?
In summary, the possibility of measuring a single photon being emitted and absorbed has been discussed. While it is possible in principle, it is very difficult to do in practice due to technological limitations. Additionally, the concept of virtual photons and how they relate to real photons has been brought up and clarified.
johne1618
371
I understand that one can measure a single photon being absorbed using a photomultiplier tube or CCD.
Can one measure a single photon being emitted by monitoring the current through an LED or the recoil of an emitting ion?
Is it therefore possible to detect the same photon both being emitted and later being absorbed?
After the photon's emission has been detected, but before its absorption has been registered, is it real or virtual?
I assume a QED calculation would proceed on the assumption that the photon is virtual but if its emission has been measured then surely it should be treated as real?
Is there a paradox here?
In principle you can. In practice you pretty much never do it. While there is some recoil in the photon emission process, the momentum transferred is tiny. You will only be able to measure it, if it sends the emitter into a quantum state that does not have much overlap with the initial state. Otherwise uncertainty "wins" over the momentum transfer. So for incredibly lightweight emitters or other especially prepared emitters, you might be able to witness the emission process. For pretty much any typical light source you encounter in real life, you will not be able to do that.
That also has some influence on the light field you get. If you can know the amount of momentum transfer, you will also know exactly into which direction the photon will be going. Otherwise, you just get a superposition state and the photon could be going in any direction. You will only find out at the time you detect the photon.
This can -at least in principle- certainly be done in cavity-QED type experiments. It is also -again in principle- possible when working with some types of non-linear cavities where the number of photons in one mode can be detected by montoring another mode.
By "in principle" I mean that this turns out to be tricky in real life, but this is AFAIK mainly due to technological problems (getting a good enough signal-to-noise ratio) and we can be pretty sure this will be possible in a few years (it might even be possible now in other types of experiments, I am not sure).
This is very much a "hot topic" since making good single photon emitters is important for a number of applications and part of that involves being able to monitor/verify what is going on and make sure that only one photon has been emitted.
Why?
jtbell said:
Why?
Well if we assume that the photon emission and absorption are measured then the photon must be virtual as it can not have had a definite momentum and energy like a real photon i.e. it could not have been represented by a plane wave.
Plane wave? You are talking about single photons, here!
The photon is real. That is why we have single-photo sources. Virtual photons do not "live" for very long times or very long distances. One also does not detect virtual photons with such detectors or else all our light detectors would be swamped with overwhelming level of noise!
Zz.
Likes 1 person
"Real" photons are not represented by plane waves. Rather the photon field is represented by a superposition of plane waves (Fourier modes) with creation and annihilation operator coefficients. "Real" photons are really mode excitations of the field i.e. the definite number (energy) eigenstates, but not all states of the field have to be definite energy states.
As Zz stated, you cannot detect virtual photons. We draw internal lines on Feynman diagrams to represent propagators, we don't actually detect the particles labeling the internal lines.
Likes 1 person
Related to If a photon's emission is detected is it real or virtual?
1. Is a photon's emission always considered to be real?
No, a photon's emission can also be considered virtual depending on the situation. In quantum field theory, a virtual photon is a mathematical construct used to describe interactions between particles.
2. How can we determine if a photon's emission is real or virtual?
The determination of whether a photon's emission is real or virtual depends on the experimental setup and the specific interactions involved. In general, real photons are those that can be detected and measured, while virtual photons are those that are not directly observable.
3. What is the significance of distinguishing between real and virtual photons?
Distinguishing between real and virtual photons is important in understanding the fundamental interactions between particles and how they transfer energy and momentum. Real photons play a role in the electromagnetic force, while virtual photons are involved in the strong and weak nuclear forces.
4. Can virtual photons be detected?
No, virtual photons cannot be directly detected. They only exist as mathematical constructs in quantum field theory and are used to explain the interactions between particles.
5. How does the concept of virtual photons relate to the wave-particle duality of light?
The concept of virtual photons is related to the wave-particle duality of light as it shows that particles, such as photons, can exhibit both wave-like and particle-like behaviors. Virtual photons are considered to be the wave aspect of light, while real photons are the particle aspect. This duality is a fundamental aspect of quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
11K
  • Quantum Physics
