- #36
davenn
2023 Award
- 9,599
- 10,342
Jackson Richter said:I do believe strongly that the antenna is the most important part of the communications process.
Baluncore said:You have a lot to learn. Without propagation, communication is impossible. With propagation, just about any antenna will work when tuned.
indeed
Jackson Richter said:There are so many positive aspects about it. 1st, its very broad band. 2nd, its multiband.
There's so many negative ones too, as have been discussed in this thread, It's broad band. NOT multiband as you have already been told. And broadband immediately brings about very low gain compared to any other resonant antenna eg. a dipole. The OCF will never have the gain of a dipole on any given frequency.
Baluncore said:If that flat VSWR is close to 1.0 then it indicates that you do not have a resonant antenna attached, you simply have high losses in your feedline, tuner and/or environment.
A dummy load also has a flat VSWR. It radiates in the IR band as heat. A low SWR may indicate that little energy is returning to the SWR meter because it is lost as heat before it gets back.
again agreed
Jackson Richter said:actually blows the g5rv and others like it, out of the water. I talk to many others that have this same antenna, who sound strong and do much better now since they have changed to this antenna.
really ? ... when being compared to another antenna from the same location and transmitter ? I doubt it has been done
I wouldn't believe that statement till actual side by side tests were done ... hearsay isn't worth diddly squat
Jackson Richter said:It appears to be a very efficient antenna
appears being the operative word
Jackson Richter said:So what I am trying to do is to quantify it and put the data in a form that makes it more predictable.
Jackson Richter said:Seeing is believing and I should have tackled this antenna years ago
that IS the ONLY way and as I said earlier, you cannot compare it to another antenna unless they are being used from the same location and with the same gear
DONT believe till you see actual results
Jackson Richter said:I guess you would have to see for yourself, being from Missouri, lol. All kidding aside,
Ohhh, and I have probably traveled more highways and byways of Missouri and the other mid-western states than you
Storm chasing takes you anywhere and everywhere
Dave
