Is there a common name for protective layer of an organism?
In summary, the outer layer of an organism can be phelloderm, spines, cuticle, trichomes (kind of hair), epidermis, glochids... ad nauseum.
icakeov
379
27
Hello, is there a common name/word/terminology for any protective layers on an organism, for example, skin on humans, bark on a tree, etc?
Biology news on Phys.org
Not really because of the multitude of higher plant and animal structures: ectoderm, dermis, epidermis, cuticle... and so on.
For the best possible guess - I vote for epidermis. This is just a not very useful wild guess.
PS: angiosperm bark is usually called phelloderm. Two names.
The correct answer is: no. You can make a case for some of them being "most common" in certain contexts, maybe. But in the early days of Biology, researchers categorized everything often uniquely. Read: they went overboard naming things. If something has a name then you think you have a handle on it. When you may have no clue. Example: math graduate students will identify a type of problem and then not be able to solve it. Somehow naming something implies knowledge... not really but we often feel that way. It is called the cubbyhole effect. See, it is self-referential, and it has a name, too! It is a disease. :) ...aaahhhh! o0)
So the outermost layer of plants can be phelloderm, spines, cuticle, trichomes (kind of hair), epidermis, glochids... ad nauseum. Same with animals - fur, spines, scales, exoskeleton.
If you follow the development of tissues in the embryo of plants and animals you can see a common source, but in the full grown organism it is not always evident how a tissue is derived from other tissues.
This requires a lot of painstaking work.
Hair and fur are derived from follicles. Some invertebrates have an exoskeleton so the outer layer doubles as a skeletal structure - crabs, insects, bivalves are examples. Exoskeletons are quite varied.
https://en.wikipedia.org/wiki/Exoskeleton#Evolution.
Likes icakeov and Evo
Jim is correct with epidermis in humans. An organism can be considered a container within a container within a container, down to the subatomic level! There are many names for each level. There are waxes, bacteria, oils, etc. that also serve as protective barriers to the epidermis. Even water content in the surrounding atmosphere can be considered a protective 'layer' to the epidermis.
Likes icakeov
Great! Thanks for all the responses. I was having a hard time finding the answer online... And It's so true, everything is wrapped into something else.
I thought, perhaps there would be a word that would describe the main, "final", "solid" layer that outlines an organism. I would be satisfied with "outer layer". :)
Related to Is there a common name for protective layer of an organism?
1. What is the protective layer of an organism called?
The protective layer of an organism is commonly referred to as the "cuticle" or "epidermis".
2. Is the protective layer the same for all organisms?
No, the protective layer can vary in composition and structure depending on the type of organism. For example, plants have a waxy cuticle while animals have a layer of skin cells.
3. What is the purpose of the protective layer?
The protective layer serves as a barrier against external threats such as physical damage, pathogens, and UV radiation. It also helps regulate water and gas exchange for the organism.
4. Can the protective layer be repaired or replaced?
In some organisms, the protective layer can be repaired or replaced if damaged. For example, animals can regenerate skin cells, while plants can produce a new layer of cuticle.
5. How does the protective layer contribute to an organism's survival?
The protective layer is essential for an organism's survival as it provides defense against potential harm and maintains homeostasis. It also plays a role in reproduction and adaptation to the environment.
  • Biology and Medical
  • Electrical Engineering
  • Chemistry
