Launch Eggs Off Balcony To Target 12M away
  • Thread starter jamey_270
  • Tags
    Launch
In summary: V file with 1 row per constraint and 1 column per idea:Constraint, Idea1, Use an inflatable ramp for a controlled slide2, Oversized Crossbow Zipline with weights to hold the line taught and slide our egg device down the line3, Catapult with parachutes.
jamey_270
I need some help brainstorming ideas for an engineering project I am doing. We are supposed to be replicating a skyscraper escape system scaled down. In place of a skyscraper we have a 25 ft balcony. In place of people we have a dozen grade A eggs. I need to design a device that can get the eggs from the balcony to a 3m diameter target 12m away from the balcony on the ground.
Constraints
• Use only unmodified Grade A Large chicken eggs
• Energy must be supplied within the system
• Before activation, must fit within 1m x 1m x 1m box
• System will be weighed before activated
• Eggs are loaded after weighing and before activation
• You only have 3 minutes to do everything!
• The system MUST be safe.
A powerpoint sort of describing the project can be found http://ide20.com/upload/Lecture3-TheDesignProject.pdf"
We have an idea of what our team wants to do, but I would like to get some different perspectives on the project.
Constraints
Welcome to the PF. We don't do your project work for you, but we can sometimes offer hints or insights, after you describe your approach.
What are your thoughts? Which landing zone are you planning on shooting for? Do the eggs have to not break (I couldn't tell from a quick skim of the PPT)?
One hint: pantyhose. Use your imagination.
We are planning on shooting for the far target with a soft landing.
We have several different ideas.
1. We are thinking of making a slide off of the balcony, and creating a remote controlled car that holds the eggs to go down the makeshift slide and drive to the target.
2. Oversized Crossbow Zipline with weights to hold the line taught and slide our egg device down the line.
3. Catapult with parachutes. [seems fun, but maybe a bad idea]
We need wisdom! Help US!
Make the egg slide like emergency stairs in airplanes. Firefighters use the same thing in medium rise buildings. Make an extra large parachute for a cartoon of eggs like emergency boats in big ships.
use your imagination. think if you were tht poor egg. What would McGayver ( that's his nae right?) had done?
Can you use an RC helicopter? It would fit in the initial box...
use an elevator. Thats what we use almost everyday. It sure fits.
Constraints
How about an inflatable ramp for a controlled slide?
CS
Related to Launch Eggs Off Balcony To Target 12M away
1. How does launching eggs off a balcony target 12m away work?
The process involves using a launcher to propel the egg at a specific angle and velocity. By calculating the trajectory of the egg, we can determine where it will land, ideally 12m away.
2. What factors affect the distance the egg will travel?
The angle and velocity of the launcher are the main factors that affect the distance the egg will travel. Other factors include air resistance, wind speed, and the weight of the egg.
3. Can any type of egg be used for this experiment?
Ideally, we recommend using raw chicken eggs as they are more consistent in weight and shape. However, other types of eggs can also be used, but the results may vary.
4. Is this experiment safe?
As with any scientific experiment, safety precautions should be taken. It is important to wear protective gear and ensure that the area is clear of any obstacles or people. Also, make sure to use a sturdy and stable launcher to minimize the risk of accidents.
5. What is the purpose of launching eggs off a balcony to target 12m away?
This experiment can help us understand the principles of projectile motion and how different variables affect the trajectory of an object. It can also be a fun and engaging way to learn about physics and mathematics.
12K
10K
  • Other Physics Topics
