Mass + potential kinetic energy
In summary, DaleSpam strongly disagrees with the idea that the mass of an object-earth system will increase due to the potential energy that has been increased by lifting the mass to the top of a hill. However, the potential energy that's gained is equal to the kinetic energy used to get it there, if looking at the object-earth (including the person who got it there) system as a whole.
thornza
Hi,
I was busy studying for my first year physics exam that's coming up and had a thought on the whole mass = energy thing.
If I carry a mass up a large hill, will it gain mass at the top of the hill due to the potential energy that has been increased?
sorry if this is a stupid question...
later,
thornza
I'd say no. The potential energy is not a property of the object, but of the object-earth system. If you consider the object-earth system as a whole, then increasing its internal energy by lifting the mass to the top of a hill will increase the mass of the system.
but is the potential energy that's gained not equal to the kinetic energy used to get it there, if looking at the object-earth (presume that includes the person who got it there) system?
I agree completely.
This is also correct, but only if the force doing the lifting is external to the object-earth system. If it is internal then there is just a transfer of energy from one form (eg chemical) of potential energy to gravitational potential energy. Such an internal transfer would result in no net change in the mass of the earth-object system.
As DaleSpam explained, the mass of the object-earth system will increase only if the person providing the input is considered to be outside of the system. If you include the person as part of the system, then there will be no net change in mass. The person will use up chemical energy in raising the object (thus reducing his mass) while the rest of the system gains energy (and thus mass).
Strongly disagree. The person's chemical energy did in fact come from outside the system: in particular, the Sun. Normally, that solar radiation would have been returned to space as heat, but in this case is stored on Earth as potential energy. A distant observer would indeed measure the mass (= energy in the Earth's rest frame) of the Earth/ball system to have increased.
This additional energy is not stored locally in the ball. Or in the Earth. The ball will not weigh more at the top of the hill. In fact, it will weigh less as measured by a spring . The energy is stored in the gravitational field; it will only be detected when putting a distant test mass in orbit around the Earth/ball system.
That energy entered the person-Earth-object system (including everything else on the Earth) when the person's food was growing, which was probably months ago. The exact amount of time depends of course on the particular food he eats. On the time scale of the person carrying an object up a hill, this is surely irrrelevant.
We're talking about the extra mass involved in pushing a ball up a hill, and it's the *timescale* that's irrelevant??
It makes no difference how long that particular energy has been on Earth. It is now stored in such a way that it can no longer be thermally radiated to space. Earth/ball on hill in thermal equilibrium with the solar radiation contains more energy than Earth/ball in valley in thermal equilibrium with the solar radiation.
:smile: excellent point! Very funny.
I don't think there is a substantive disagreement here, just a small disagreement on the boundaries of the system. You implicitly exclude the person in the description of the system while jtbell and Doc Al explicitly include him. Earth/ball and exhausted man on hill in thermal equilibrium with the solar radiation contains the same energy as Earth/ball and energized man in valley in thermal equilibrium with the solar radiation. So, if the man (and the chemical energy he contains) is considered part of the system then the energy and mass is unchanged. Otherwise the man is an external force which does work on the system and the system's energy and mass increases.
Related to Mass + potential kinetic energy
1. What is mass?
Mass is a measure of the amount of matter in an object. It is a fundamental property of an object and is usually measured in kilograms (kg).
2. What is potential energy?
Potential energy is the energy an object has due to its position or state. It is stored energy that can be converted into other forms, such as kinetic energy.
3. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is directly proportional to an object's mass and the square of its velocity.
4. How are mass and potential energy related?
Mass and potential energy are related through the gravitational potential energy equation, which states that potential energy is equal to mass multiplied by the acceleration due to gravity (9.8 m/s^2) and the height of the object from a reference point.
5. How does an object's mass affect its kinetic energy?
An object's mass directly impacts its kinetic energy. The greater the mass, the greater the kinetic energy, as long as the velocity remains constant. This is because the kinetic energy formula includes mass as a factor.
