Penrose: Noise in LIGO signal implies CCC
In summary, Penrose says that the apparent noise in the gravitational wave signals may be due to the decay of dark matter particles, an implication of Conformal Cyclic Cosmology. If this is true, it would be a clear indication that the theory is correct.
Auto-Didact
751
562
Roger Penrose, July 2017. Correlated "noise" in LIGO gravitational wave signals: an implication of Conformal Cyclic Cosmology
Abstract said:
It has recently been reported by Cresswell et al. [1] that correlations in the noise surrounding the observed gravitational wave signals, GW150194, GW151226, and GW170194 were found by the two LIGO detectors in Hanford and Livingston with the same time delay as the signals themselves. This raised some issues about the statistical reliability of the signals themselves, which led to much discussion, the current view appearing to support the contention that there is something unexplained that may be of genuine astrophysical interest [2]. In this note, it is pointed out that a resolution of this puzzle may be found in a proposal very recently put forward by the author [3], see also [4], that what seems to be spuriously generated noise may in fact be gravitational events caused by the decay of dark-matter particles (erebons) of mass around 10^-5g, the existence of such events being a clear implication of the cosmological scheme of conformal cyclic cosmology, or CCC [5], [6]. A brief outline of the salient points of CCC is provided here, especially with regard to its prediction of erebons and their impulsive gravitational
Astronomy news on Phys.org
Dark Matter particle around 10^-5g? Are you talking Planck mass?
Penrose sure is. A particular model of DM in Penrose' CCC scheme is proposed to be of the order of the Planck mass meaning oscillations of these particles have Planck frequency order and thus constitute a cosmological noise source when measuring pretty much all gravitational waves.
Yes, a Planck mass, or a simple multiple of that mass. He said.
Yeah, however I'd say that's almost the least interesting aspect of the new paper. Much more interesting is that this erebon theory possibly kills two birds with one stone (noise in gravitational wave signals and DM) and is easily testable without requiring copious amounts of effort, funding or both.
As Penrose says:
To test this, one need merely settle on some prominent galaxy—say the Andromeda galaxy—and look for correlations in the noise that has a time delay between the two detectors that corresponds to sources in the direction of that particular galaxy. The black-hole encounter would be completely unnecessary for this, and one does not have to wait for such occurrences in order to test the proposal. Of course, the dark-matter distribution in our own galaxy would be a major contributor, in this proposed scheme, and thus should be a major contributor to the signals referred to here. Clearly the proposal that I am putting forward here makes many testable predictions, and it should not be hard to disprove it if it is wrong.
Are you so content? I was looking for hints of DM contributions to the universe density, but no direct message was found. Maybe you can help me.
Correct me if I'm wrong, that would be n times Planck masses (DM's) every 10^19 m^3. Also very few in space.
What was the size of the BH's merged? Was supposed to be 49 x Sun's mass, 49 x Sun's Schwartzschild Radius = 72353 km. How many of DM's were within the range affected by the BH merger? Maybe not many.
I agree this is potentially quite significant, Penrose is proposing a simple test that could falsify both CCC and his model for dark matter. A pass of that test would be most interesting indeed! And how ironic would it be if the most important result from LIGO comes not from sources but rather from background noise. It would be akin to the detection of the CMB.
Likes Auto-Didact
Exactly my point. Being a theorist however, Penrose seems to have presented his test as easier than it actually seems to be. For his test to work two things are needed, namely 1) the ability for LIGO to focus on a particular point in the sky and 2) the possibility to rotate LIGO's detectors such that they can focus on any other point in the sky.
The first isn't possible yet, at least not with only two detectors. The regions identified as possible locations for detected BH sources are immense gigaparsec bands of the sky instead of crisp galaxies. With three or more detectors active however the precision should improve alot.
As for the second point, rotating LIGO like a telescope or satellite seems out of the question, given that we are talking about a stationary 4 km Michelson-Morley setup. What would be needed for this to work are LIGO detectors in space, i.e. something akin to the planned LISA experiment.
Penrose knows you can't rotate LIGO, he is saying that the noise, unlike the CMB, would not be isotropic. So even with just two detectors, you could look for a background signal in the data that would always correspond to the time delay associated with Andromeda, where the dark matter will be. I agree this gets to be a more convincing test when more LIGO-type apparatuses are online in the future, or when LISA flies. Indeed, I've always been a little skeptical that we really are looking at a "new window" onto the universe with just LIGO-type instruments (how much is there really to learn about stellar black-hole mergers anyway?), but if Penrose's test gets a pass, then we have a new window indeed-- the best possible window into dark matter.
Likes Auto-Didact
We have three now.
The Earth rotates the detectors daily. LISA will only rotate once per year.
Likes Auto-Didact
I'm pretty sure he knows we can't rotate LIGO, but he does clearly state in the paper that all it would take is "to point the detector in some direction". Locating sources without being able to voluntarily rotate the detector is a far less clean route, involving far more statistics than a theorist usually bargains for.
Don't get me wrong, I'm very enthusiastic about Penrose' proposal, but it's because of its potential magnitude that I want to make sure as certain as possible that we aren't fooling ourselves.
mfb said:
We have three now.
Of course, but the rotation of the Earth is involuntary motion, where we are being rotated for the test hopefully in such a way as to get a good signal of some point, instead of choosing and rotating a telescope towards some specific point. This doesn't make things impossible but significantly constrains us in our possibilities.
In any case, it is wonderful news to hear that VIRGO has finally gone online. The accurate localisation of sources should improve immensely using the ability to triangulate. Its too bad we can't retroactively locate any of the BH mergers though since their GWs have already passed. Now just to wait for another detection...
Related to Penrose: Noise in LIGO signal implies CCC
1. What is the CCC theory proposed by Roger Penrose?
The CCC (Conformal Cyclic Cosmology) theory is a cosmological model proposed by mathematician and physicist Roger Penrose. It suggests that the universe undergoes a series of cycles, with each cycle beginning with a big bang and ending with a big crunch. This theory challenges the traditional idea of a single, linearly expanding universe.
2. How does the noise in the LIGO signal relate to the CCC theory?
In a study published in 2016, Roger Penrose proposed that the noise in the LIGO (Laser Interferometer Gravitational-Wave Observatory) signal could be evidence of gravitational waves from a previous universe. This aligns with his CCC theory, as it suggests that the universe undergoes cycles of expansion and contraction, leaving behind traces of gravitational waves.
3. What implications does this have for our understanding of the universe?
If Penrose's theory is proven to be correct, it would challenge our current understanding of the universe and how it evolves. It would also open up new possibilities for studying the universe and its origins.
4. How has the scientific community responded to Penrose's theory?
Penrose's theory has sparked a lot of debate and discussion within the scientific community. Some scientists have expressed skepticism, while others see it as a promising new perspective that could potentially revolutionize our understanding of the universe. More research and evidence is needed to fully validate or disprove the CCC theory.
5. What further research is being done to investigate the connection between LIGO signals and the CCC theory?
Currently, there is ongoing research and analysis being done to further explore the possible connection between LIGO signals and the CCC theory. This includes studying other sources of gravitational waves, as well as refining and improving LIGO's detection capabilities. Additionally, theoretical work is being done to better understand the implications of Penrose's theory and how it could be tested through future observations and experiments.
  • Beyond the Standard Models
  • Astronomy and Astrophysics
12K
