Reliability question with exponential distribution
In summary, the probability of survival for a memory chip with an exponential life distribution and failure rate of 0.15*10^-5 is 0.822. The probability of failure after surviving 20,000 hours of operation is 0.176. By 25,764 hours, 10% of the chips are expected to fail, by 35,944 hours, 50% of the chips are expected to fail, and by 39,884 hours, 63.2% of the chips are expected to fail.
alextsipkis
Q. A certain type of memory chip is known to have an exponential life distribution with a failure rate of 0.15*10^-5.
a) What is the probability that a memory chip will survine 20,000 hours of use?
b) What is the probability it will fail in the next 35,000 hours if it has survived 20,000 hours of operation already??
c) By what time 10% of the chips , 50% of the chips, 63.2% of the chips be expected to fail??
I was wondering if somebody could help me with b OR c? Much appreciated. Please give some explanation , if possible, so easy for me to understand...
thanks.
a) The probability that a memory chip will survive 20,000 hours of use is 0.822.b) The probability it will fail in the next 35,000 hours if it has survived 20,000 hours of operation already is 0.176. This can be calculated by subtracting the probability of survival from 1, to get the probability of failure.c) By what time 10% of the chips, 50% of the chips, and 63.2% of the chips be expected to fail can be calculated using the formula for an exponential distribution: 10% failure rate: T = -ln(1-0.1)/0.000015 => T = 25,764 hours 50% failure rate: T = -ln(1-0.5)/0.000015 => T = 35,944 hours 63.2% failure rate: T = -ln(1-0.632)/0.000015 => T = 39,884 hours
Related to Reliability question with exponential distribution
What is the exponential distribution?
The exponential distribution is a probability distribution that describes the amount of time between events in a Poisson process, where events occur continuously and independently at a constant average rate.
How is the exponential distribution used in reliability analysis?
The exponential distribution is commonly used in reliability analysis to model the time to failure of a system or component. This allows for the calculation of important metrics such as the mean time to failure and the probability of failure within a certain time period.
What is the reliability function for the exponential distribution?
The reliability function for the exponential distribution is given by R(t) = e-λt, where λ is the rate parameter. This function represents the probability that a system or component will survive beyond time t without failing.
How is the failure rate related to the exponential distribution?
The failure rate for the exponential distribution is constant and is equal to λ, the rate parameter. This means that the probability of failure for a system or component remains the same over time, regardless of how long it has been in operation.
What are some common applications of the exponential distribution in reliability analysis?
The exponential distribution is commonly used in reliability analysis for various applications, including product testing, equipment maintenance planning, and predicting the lifespan of electronic components. It is also used in fields such as engineering, finance, and healthcare to model the time between events.
  • Other Physics Topics
