Weak measurement in double slit experiment gives which path
In summary, in 2012, experimenters demonstrated that when two entangled photons separate and one goes through a double slit, we can determine which slit it went through by observing its entangled partner, yet still see an interference pattern. This idea has been explored before, such as in Kim's delayed choice experiment, but without a specific source or citation, it is difficult to discuss the potential connection to weak measurements. Please provide a link to the paper for further discussion.
Nav
39
In 2012, experimenters showed that when two entangled photons separate and when one goes through the double slit, we can tell which slit it went through and see that they still created an interference pattern because the photon that it was entangled to tells us which slit it went through. What do you guys think of this?
The basic idea of using entanglement to generate which-path information has been around since well before 2012. For example, it's the basis for Kim's delayed choice experiment around the turn of the century: https://en.wikipedia.org/wiki/Delayed_choice_quantum_eraser#The_experiment_of_Kim_et_al._.282000.29.
It's not at all clear what this might have to do with weak measurements, but without a citation or link to the paper in which these results were published, it's impossible to say anything sensible about whatever experiment you're thinking of. That's why we have a rule requiring that sources be cited.
This thread is closed. PM me with a link to your source and if it meets the guidelines in the PF rules we can reopen the thread.
Related to Weak measurement in double slit experiment gives which path
1. What is the double slit experiment and how does it relate to weak measurement?
The double slit experiment is a classic experiment in physics that demonstrates the wave-particle duality of light and matter. It involves firing a beam of particles, such as electrons or photons, through two parallel slits and observing the resulting interference pattern on a screen. Weak measurement is a technique used to gather information about the particles' path without significantly affecting their behavior, and it has been applied to the double slit experiment to gain insight into the nature of quantum mechanics.
2. How does weak measurement affect the outcome of the double slit experiment?
Weak measurement does not affect the outcome of the double slit experiment in the same way that strong measurement does. Strong measurement involves directly observing the particles' path, which causes the interference pattern to disappear. Weak measurement, on the other hand, only provides partial information about the particles' path and allows the interference pattern to remain intact.
3. What does weak measurement reveal about the particles' behavior in the double slit experiment?
Weak measurement reveals that the particles exhibit a probabilistic behavior, meaning that their path cannot be determined with certainty. This is a key aspect of quantum mechanics and is often described using the concept of wavefunction collapse. Weak measurement also shows that the particles behave differently when they are observed versus when they are not observed, highlighting the role of the observer in quantum systems.
4. Are there any limitations to using weak measurement in the double slit experiment?
Yes, there are limitations to using weak measurement in the double slit experiment. One limitation is that the amount of information gathered through weak measurement is limited, so it cannot provide a complete understanding of the particles' behavior. Additionally, the technique is sensitive to external disturbances, so it must be carefully controlled in order to obtain accurate results.
5. How is weak measurement in the double slit experiment relevant to other areas of science?
The concept of weak measurement and its application in the double slit experiment has implications beyond quantum mechanics. It has been used in other areas of science, such as in biology to study the behavior of bacteria and in social sciences to understand decision-making processes. It also has potential applications in technology, such as in quantum computing and cryptography.
  • Quantum Physics
  • Quantum Physics
