What is a differentiable variety?
In summary, varieties are a type of mathematical object that generalize the concept of surfaces. They can be classified into different types, such as topological varieties and differentiable varieties. They are also known as manifolds and can be studied using analytical, topological, and algebraic methods. However, the concept of varieties can be confusing and it is recommended to seek further resources for a more in-depth understanding.
Opressor
In mathematics, variety is a generalization of the surface idea. There are several types of varieties, according to the properties they possess. The most usual are the topological varieties and the differentiable varieties. but I still do not know what it is!
To answer the title question: It is called a manifold and locally a Euclidean space such that we can apply analytical and topological methods.
Variety is usually called "algebraic variety" in algebraic geometry. They are defined as the zeros of multivariate polynomials, which lead to ideals in rings, so that ring theory is applicable to investigate the geometry of these surfaces. However, they are called manifolds, when similar is done with means of analysis and topology to investigate the (differential) geometry. I haven't seen these concept mixed, it's a bit of a stretch.
Opressor said:
... I still do not know what it is!
This isn't the place, neither for a lecture in algebraic geometry, nor in differential geometry. How could I answer such a question? They are surfaces as you have said, defined by equations. So this answers your question and probably simultaneously doesn't. Can you be more specific? Otherwise I have to recommend our Science and Math Textbooks forum, where you can find or ask for appropriate book recommendations.
Btw, if you add algorithm varieties to your list, you'll get a third kind and computer science as toolbox.
Likes Opressor
Related to What is a differentiable variety?
A differentiable variety is a mathematical object that combines the concepts of a variety and a differentiable manifold. It is a space that is locally described by polynomial equations and has a well-defined notion of differentiability.
How is a differentiable variety different from a regular variety?
A differentiable variety is a special type of variety that has the additional property of being differentiable. This means that in addition to being described by polynomial equations, it also has a smooth structure that allows for the calculation of derivatives and other differential operators.
What are some examples of differentiable varieties?
Some examples of differentiable varieties include algebraic curves and surfaces, as well as higher-dimensional algebraic varieties. These objects can be described by polynomial equations and also have a smooth structure that allows for the calculation of derivatives.
What are the applications of differentiable varieties?
Differentiable varieties have many applications in mathematics and physics. They are used in the study of algebraic geometry, differential geometry, and topology. They also have applications in fields such as robotics, computer graphics, and machine learning.
How are differentiable varieties studied?
Differentiable varieties are studied using a combination of algebraic and differential geometric techniques. This includes methods from commutative algebra, algebraic geometry, and differential topology. Computer algebra systems are also commonly used to study differentiable varieties.
  • Linear and Abstract Algebra
  • Differential Geometry
13K
