What is the energy of the alpha particle and recoiling nucleus?
In summary: And for the final answer, you might want to find the masses of the daughter and alpha particle in MeV.
says
594
The Q-value of alpha decay of Pu-239 is 5.244 MeV.
Calculate the energy of the alpha particle in MeV.
Calculate the energy of the recoil nucleus decay product in MeV.
(answer correct to 3 decimal places)
The Q value of a nuclear reaction is the difference between the sum of the masses of the initial reactants and the sum of the masses of the final products.
Neutron (Energy equivalent) = 939.57 MeV
Proton (Energy equivalent) = 938.28 MeV
Electron (Energy Equivalent) = 0.511 MeV
Pu-239 > U-235 + alpha particle
Q = Pu-239 - (U-235 + alpha particle) = 5.244 MeV
Pu-239 = (n=145, p=94, e=94)
U-235 = (n=143, p=92, e=92)
Q = (145 * 939.57 + 94 * 938.28 + 94 * 0.511) - ((143 * 939.57 + 92 * 938.28 + 92 * 0.511) - alpha particle = 5.244 MeV
Q = 3756.72 MeV - alpha particle = 5.244 MeV
Energy of Alpha Particle = 3751.476 MeV
I'm not sure how to calculate the energy of the recoil nucleus decay product though...
The mass of a nucleus is not the sum of its protons and neutrons (otherwise the decay wouldn't release energy!), and there are no electrons involved.
5.244 MeV is the sum of the kinetic energy of alpha particle and nucleus. Why do both move after the reaction? Think about conservation laws you know. One of them will tell you how the 5.244 MeV get distributed over the two particles.
So If I calculate the kinetic energy of the nucleus I can say 5.244 MeV - kinetic energy of nucleus = energy of the alpha particle?
That is right. It is one of the two equations you'll need to find the energies.
mass of a nucleus = (number of protons * atomic weight of protons) + (number of neutrons * atomic weight of neutrons) - binding energy of the nucleus.
Mass of alpha particle = (2 * 938.3084221246 + 2 * 939.5985407812) - 28.3 = 3727.51392581 MeV
Mass of U-235 = (92 * 938.3084221246 + 143 * 939.5985407812) - 1783.870285 = 218903.095882 MeV
Mass of Pu-239 = (94 * 938.3084221246 + 145 * 939.5985407812) - 1806.921509 = 222635.858584 MeV
Q = 222635.858584 - (218903.095882 + 3727.51392581) = 5.24877619001 MeV
So the energy of the alpha particle = 3727.51392581 MeV
I'll have to fix up the sig figs a little bit for the final answer because it's wanted to 3 decimal places...
That is the mass of it, not its energy, and not its kinetic energy (=what the answer wants) either.
You are not even close to the final answer, and the binding energy calculations do not help you here.
I'm a bit lost then...
The question says the Q-value of alpha decay of Pu-239 is 5.244 MeV.
Pu239 decays to U235 + alpha particle + 5.244 MeV
if the q-value = the difference between the sum of the masses of the initial reactants and the sum of the masses of the final products.
Q=Pu239-(U235+alpha particle)=5.244 MeV
I thought in asking for the energy they were asking for the mass but in terms of MeV...
I'd they were asking for kinetic energy I think they would have given more than just the Q value of the reaction
Ok, I tried a new approach. Can't believe I didn't use this from the start. Conservation of energy.
Energy of alpha particle = Q/(1+(mass of alpha particle / mass of daughter particle)
5.244/ (1+(4.001506179127 / 235.0439299) = 5.15621795008 MeV = 5.156 MeV (3 decimal places)
energy of recoil nucleus = Q/(1+(mass of daughter / mass alpha)
5.244 / (1 + (235.0439299 / 4.001506179127) = 0.08778204992 MeV = 0.088 MeV (3 decimal places)
Right.
Related to What is the energy of the alpha particle and recoiling nucleus?
1. What is the energy of an alpha particle?
The energy of an alpha particle can vary depending on the source and conditions, but it typically ranges from 4 to 9 million electron volts (MeV).
2. How is the energy of an alpha particle measured?
The energy of an alpha particle is usually measured using a device called a particle detector, which can detect and measure the ionizing particles released by the alpha particle as it travels through a material.
3. What is the energy of a recoiling nucleus?
The energy of a recoiling nucleus, also known as the recoil energy, can vary depending on the mass and velocity of the nucleus. It is usually in the range of a few hundred to a few thousand electron volts (eV).
4. How is the energy of a recoiling nucleus calculated?
The energy of a recoiling nucleus can be calculated using the equation E = 1/2 * M * V^2, where E is the energy, M is the mass of the nucleus, and V is the velocity of the recoil.
5. What is the relationship between the energy of the alpha particle and the recoiling nucleus?
The energy of the alpha particle and the recoiling nucleus are related by the conservation of energy and momentum. As the alpha particle loses energy, the recoiling nucleus gains an equivalent amount of energy in order to conserve the total energy of the system.
