Why does (-1)^n(sin(pi/n)) converge when (sin(p/n)) diverges
In summary, the original series diverges due to the comparison test with π/n, which approaches 0 as n approaches infinity. However, the alternating series with (-1)^n*sin(π/n) converges, which may seem counterintuitive since it consists of two diverging functions. This is because for large values of n, sin(π/n) is approximately π/n, causing the series to approach πΣ(1/π) which is known to diverge. Grouping pairs of successive terms in the alternating series can also show that it approximates π.ln(2). It is important to note that the fact that both the individual series of (-1)^n and sin(π/n) diverge does not
solour
I know that ∑n=1 to infinity (sin(p/n)) diverges due using comparison test with pi/n, despite it approaching 0 as n approaches infinity.
However, an alternating series with (-1)^n*sin(pi/n) converges. Which does not make sense because it consists of two diverging functions.
Is there any intuitive explanation for this? Or is it just a rule that I need to remember when treating alternating series
Thank you.
How about this: For large n, sin(π/n) is approximately π/n, so the series is approximately πΣ(1/π) which is known to diverge.
With alternating signs, the series approximates πΣ( (1/n) - 1/(n+1) ) which approaches π.ln(2). Actually I think I find it more persuasive to group pairs of successive terms:
(1/n) - 1/(n+1) = 1/(n(n+1)) = O(1/n2), but I gather that's not always a safe thing to do.
The fact that ##\sum (-1)^n## and##\sum \sin(\pi/n)## both diverge says absolutely nothing about the alternating series. If you don't believe that, you might consider ##a_n = b_n = 1/n##. Neither ##\sum a_n## nor ##\sum b_n## converge, but ##\sum a_nb_n = \sum 1/n^2## converges.
Likes Jamison Lahman
Related to Why does (-1)^n(sin(pi/n)) converge when (sin(p/n)) diverges
1. Why does (-1)^n(sin(pi/n)) converge when (sin(p/n)) diverges?
The reason for this is because (-1)^n is an alternating sequence, meaning that it alternates between positive and negative values as n increases. This causes the terms in the sequence to cancel each other out, resulting in convergence.
2. Can you provide a real-world example of this phenomenon?
One example is the alternating current (AC) in electronics. The current alternates between positive and negative values, resulting in a net flow of electricity despite the individual values diverging.
3. How does the value of n affect the convergence of (-1)^n(sin(pi/n))?
The value of n does not affect the convergence of (-1)^n(sin(pi/n)). As long as n is a positive integer, the sequence will continue to converge.
4. Is there a limit to how many terms can be added before the sequence converges?
Yes, there is a limit to how many terms can be added before the sequence converges. This limit is determined by the rate at which the terms are alternating and canceling each other out.
5. How does the convergence of (-1)^n(sin(pi/n)) compare to that of other alternating sequences?
The convergence of (-1)^n(sin(pi/n)) is similar to other alternating sequences, such as the alternating harmonic series. However, the specific value of n in this sequence results in a unique convergence pattern.
19K
