- #36
Ibix
- 13,789
The point, I think, is that the underlying problem you have with the atmosphere is that it's not nailed down, but rotates with the Earth anyway. The same is true of the oceans. So if you personally don't have the same problem with the oceans as with the air, there's a crack in your thinking that you might be able to lever open and gain insight.bo reddude said:could you expound this please?
The basic answer is friction. If the atmosphere were, in bulk, rotating at a different rate from the ground, each collision between an air atom and a ground atom would tend to result in the average rotation rates getting closer together. There would be a transfer of energy from the faster rotating part to the slower one. The same applies to the ocean.
As others have noted, a stationary atmosphere and a spinning Earth is not a realistic model of atmosphere formation. But this does explain why co-rotating Earth and atmosphere is stable. If some combination of events (billions upon billions of carefully coordinated and aimed micrometeorites burning up in the upper atmosphere, perhaps) made the atmosphere rotate a little faster, friction would slow it down again, passing some of its energy on to the Earth.
