Differential equation with power series help
In summary: It will involve a product of terms, each of which is a ratio of two double-factorials. I don't know if there's a simpler form for this or if you're expected to simplify it further. It would depend on what your class is doing with these power series.In summary, the conversation discusses finding the power series solutions of a given equation and determining the lower bounds for their radii of convergence. The participants work through the problem and identify a recurrence relation for the coefficients of the series. They also discuss using the ratio test to find a lower bound for the radius of convergence
pinkbabe02
(1+2x^2)y''+6xy'+2y=0
1. find the power series solutions of the equation near x0=0...show the recurrence relation for an, derive a formula for an in terms of a0 and a1, and show the solution in the form y=a0y1(x)+a1y2(x)
2.what is the lower bound for the radii convergence of the power series solutions in part 1
3.what is the lower bound for the power series solutions of the same equation near x0=-1
I attached the word doc I typed it up in because that will probably be easier to read.
(1+〖2x〗^2 ) y^''+6xy^'+2y=0
Let…
y=∑_(n=0)^∞▒〖a_n x^n 〗
y^'=∑_(n=1)^∞▒〖〖na〗_n x^(n-1) 〗
y^''=∑_(n=2)^∞▒〖n(n-1)a_n x^(n-2) 〗
(1+〖2x〗^2 ) ∑_(n=2)^∞▒〖n(n-1)a_n x^(n-2) 〗+6x∑_(n=1)^∞▒〖〖na〗_n x^(n-1) 〗+2∑_(n=0)^∞▒〖a_n x^n 〗=0
∑_(n=2)^∞▒〖2n(n-1) a_n x^n+∑_(n=2)^∞▒〖n(n-1)a_n x^(n-2) 〗〗+∑_(n=1)^∞▒〖〖6na〗_n x^n+∑_(n=0)^∞▒〖〖2a〗_n x^n 〗〗=0
∑_(n=2)^∞▒〖2n(n-1) a_n x^n+∑_(n=0)^∞▒〖(n+2)(n+1)a_(n+2) x^n 〗〗+∑_(n=1)^∞▒〖〖6na〗_n x^n+∑_(n=0)^∞▒〖〖2a〗_n x^n 〗〗=0
Since the first term is 0 for both n=0, 1, we can start the summation at n=0.
Since the third term is 0 for n=0, we can start the summation at n=0, also.
∑_(n=0)^∞▒〖2n(n-1) a_n x^n+∑_(n=0)^∞▒〖(n+2)(n+1)a_(n+2) x^n 〗〗+∑_(n=0)^∞▒〖〖6na〗_n x^n+∑_(n=0)^∞▒〖〖2a〗_n x^n 〗〗=0
∑_(n=0)^∞▒〖[2n(n+1) a_n+(n+2)(n+1) a_(n+2)+6na_n+2a_n ] x^n 〗=0
∑_(n=0)^∞▒〖[2(n^2+4n+1) a_n+(n+2)(n+1) a_(n+2) ] x^n 〗=0
2(n^2+4n+1) a_n+(n+2)(n+1) a_(n+2)=0 n=0,1,2,…
〖(a)recurrence relation→a〗_(n+2)=(-2(n^2+4n+1))/((n+2)(n+1)) a_n n=0,1,2,…
n=0 a_2=(-2)/2 a_0 a_2=-a_0
n=1 a_3=(-12)/6 a_1 a_3=-〖2a〗_1
n=2 a_4=(-13)/6 a_2 a_4=13/6 a_0
n=3 a_5=(-11)/5 a_3 a_5=22/5 a_1
I am having trouble creating a formula in terms of a_0 and a_1. More specifically, I don’t know how to create a general summation for this case because of the weird numbers in the numerator. I am pretty sure that the denominator for the odd case is (2k+1)! and the even case would be (2k)!
For part(c), I have y(x)=a_0 (-1+13/6 x^2+⋯)+a_1 (-2x+22/5 x^3+⋯)
As for the lower bound for radii convergence of the power series solutions from the last part, I tried to solve this but I`m not sure if I am approaching it correctly since I didn’t know how to find the power series from the last part. I found p(x) and q(x)…
p(x)=6x/(1+〖2x〗^2 ) and q(x)=2/(1+〖2x〗^2 )
My problem with this is that 1+〖2x〗^2 does not have any zeroes. Does that mean that the radius of convergence is infinity?
For the final part which asks for the lower bound for the power series solutions of the same equation near x_0=-1, I used the same p(x) and q(x) as I did in the last part. But since the denominator has no zeroes I feel like the lower bound is infinity also. The questions about radii of convergence really confuse me so any help would be greatly appreciated!
  • problem 2.doc
I didn't see an obvious mistake in your algebra, but I think the recurrence relation you found isn't correct. I used Mathematica to find the solution to the differential equation, and it found the following two solutions:
\begin{align*}
y_1(x) &= \frac{1}{\sqrt{1+2x^2}} \\
y_2(x) &= \frac{1}{\sqrt{1+2x^2}}\frac{\sinh^{-1}(\sqrt{2}x)}{\sqrt{2}}
\end{align*}
The first solution has the series expansion[tex]y_1(x) = 1-x^2+\frac{3x^4}{2}-\frac{5x^6}{2}+\frac{35x^8}{8} - \frac{63x^{10}}{8} + \cdots[/tex]The coefficients you found don't match up with those.
Thanks for your help! Do you know where I went wrong though? I did the problem multiple times and I get the same recurrence relation everytime
I just spotted the error. When you combined the individual sums and factored xn out, you changed the 2n(n-1) in the first term to 2n(n+1).
I got what I believe to be the correct recurrence relation...
an+2=[itex]\frac{-2(n+1)}{(n+2)}[/itex]an
could you help get me started in how to find the radii of convergence?
Did you find an expression for an yet?
I found
y1(x)=a0(1-x2+(3/2)x4-(5/2)x6...)+a1(x-(4/3)x3+(32/15)x5-(128/35)x7...)
How about applying the ratio test to the two series? I was thinking to do this, you'd need a closed form expression for an, which is why I asked the earlier question, but I don't think you actually do.
Do you have some theorems about a lower bound on the radius of convergence? I ask because typically you're asked what the radius of convergence actually is rather than to find some bound.
But don`t I need the solution in the form of a summation? this is where i am really struggling. I don`t understand how to do that
The problem did ask you to find a formula for an. I take it that's where you're stuck right now and you haven't gotten to trying to find the radius of convergence yet.
I usually write out the first few terms without simplifying much and look for a pattern. For example, you have
\begin{align*}
a_0 &= a_0 \\
a_2 &= -2\frac{1}{2}a_0 = (-2)^1\frac{1}{2} a_0 \\
a_4 &= -2\frac{3}{4}a_2 = (-2)^2\frac{1\cdot 3}{2 \cdot 4} a_0 \\
a_6 &= -2\frac{5}{6}a_4 = (-2)^3\frac{1\cdot 3 \cdot 5}{2 \cdot 4 \cdot 6} a_0
\end{align*}
How would you express a2k in a general form?
This helps a lot. I think I am trying to combine the numbers and simplify too quickly instead of letting it go so I can find a pattern.
a2k=(-2)k[itex]\frac{(2k+1)!}{(2k)!}[/itex]
That's not quite right. Neither the top nor bottom is a factorial since the top is missing the even factors and the bottom is missing the odd factors. Also, the last factor in the numerator is (2k-1), not (2k+1). Look at a6 for example. There you have 2k=6 but the last factor in the numerator is 5 = (2k-1).
Are you familiar with double-factorial notation? Or you could also use some tricks like
[tex]2 \cdot 4 \cdot 6 \cdots (2k) = (2 \times 1) \cdot (2 \times 2) \cdot (2 \times 3) \cdots (2 \times k) = 2^k k![/tex]
and
[tex]1 \cdot 3 \cdot 5 \cdots (2k-1) = \frac{1\cdot 2\cdot 3 \cdot 4 \cdots (2k-1)\cdot(2k)}{2\cdot 4\cdots (2k)} = \frac{(2k)!}{2^k k!}[/tex]
I didn`t even think about double factorials but yes my professor just went over them in class the other day. Using them I have...
a2k=((-2)k[itex]\frac{(2k-1)!}{(2k)!}[/itex])a0
and likewise...
a2k+1=((-2)k[itex]\frac{(2k)!}{(2k-1)!}[/itex])a1
so in power series form, I have...
(i attached the file with the form. i was struggling to type it into the forum with the latex formatting. I didn`t know how to do the summation symbol properly)
  • summation.doc
Related to Differential equation with power series help
1. What is a differential equation with power series?
A differential equation with power series is an equation that involves a function and its derivatives, where the function is represented as a power series. This means that the function is expressed as a sum of terms that contain powers of a variable.
2. Why are power series used in solving differential equations?
Power series are used in solving differential equations because they provide an efficient and accurate method for approximating solutions to differential equations. They also allow for the use of calculus techniques, such as integration and differentiation, in solving the equations.
3. How can I determine the convergence of a power series solution to a differential equation?
The convergence of a power series solution to a differential equation can be determined by using the ratio test or the root test. Both tests involve evaluating the limit of the ratio or root of consecutive terms in the power series. If the limit is less than 1, the series will converge and the solution is valid.
4. What are the limitations of using power series to solve differential equations?
One limitation of using power series to solve differential equations is that the method only works for certain types of equations, such as linear and homogeneous equations. Additionally, the convergence of the series may be difficult to determine for some equations, making it challenging to find a valid solution.
5. Are there any real-world applications of differential equations with power series?
Yes, there are many real-world applications of differential equations with power series. They are commonly used in physics and engineering to model and solve problems involving motion, heat transfer, and electrical circuits. They are also used in economics and finance to analyze growth and decay processes.
