What caused the sea to inundate Beijing within the past 80,000 years?
In summary: None of those 600 leading scientists discovered a fatal failure in the interpretation of the ice cores, which has led to demonstrated false interpretations, such as the hockeystick.
  • #36
sneez said:
Thanx Andre, i went through some of the discussion, but its 200+ pages :D
Try the find functions for key words. "Model" would be a good one, "positive feedback" may work as well.
Why do you put such an emphasis on BB computation of increasing some gass? It is important but the GW stuff is recognized comes from the coupling and potential positive feedbacks which is not well understood.
It's not understood because it's non existent. Try the find function. I also posted that here earlier in the thread I think, the Karner Non-persistency study and the high resolution isotope-CO2 proxies of the EPICA Dome C ice core:
http://home.wanadoo.nl/bijkerk/epica5.GIF
  • #37
<I also posted that here earlier in the thread I think, the Karner Non-persistency study ...>
Here's a related paper suggested to me from another forum. The authors model solar flare and temperature anomalies as related Levy processes. These are continuous time Markov processes that incorporate drift, Brownian motion, and jumps. They can also be considered as random walks with bigger jumps than Gaussian theory predicts. The important finding is that both solar flare activity and temperature anomalies might be related through a non-obvious process. The data is pretty limited though.
Solar turbulence in earth’s global and regional temperature anomalies
Nicola Scafetta, Paolo Grigolini, Timothy Imholt, Jim Roberts, and Bruce J. West
This apparent Lévy persistence of the temperature fluctuations is found, by using an appropriate model, to be equivalent to the Lévy scaling of the solar flare intermittency. The mean monthly temperature data sets cover the period from 1856 to 2002.
http://prola.aps.org/searchabstract/PRE/v69/i2/e026303?qid=e399f5dfccd56b56&qseq=2&show=25
  • #38
There is a lot ongoing about the sun. For instance:
http://www.lps.umontreal.ca/~paquetteh/Maunder_SP.pdf
Bottom line, the ~1,5 W/m2 difference in solar output between the Maunder minimum and the current maximum falls way short to explain the difference in global temperature, before put into the Stefan Boltzman equation you'd have to divide that by 4 (diameter area versus surface of the globe) and multiply by 0.3 to account for albedo/reflectivity. I don't have my stuff around here to calculate the delta right now. Won't be significant.
Yet there appears to be a significant correlation between solar activy (flares, solar particles, induced solar magnetism and apparent global temperatures) but many things remain to be seen.
  • #39
Using sun spot numbe as input and modeling evolution of magnetic flux ...
This is not something to subscribe to as a fact, Andre.., these processes are not even well understood as far as sun is concerned. The processes and relationship of sun-earth is being studied and many papers with conflicting opinions and inter-relationships are being presented.
As and researcher in this area I can tell you that far from any conclusions of long term changes are reached. Short term is more complicated than that. There is not know mechanism of long term change due to precipitation of solar particles. (In planetary science, it is being researched how the 'hot' plasma stays after the SPE event in the tail of the magnetic field of the earth, but that's a hard science on its own and its conclusion will depend on the theory that will be accepted and is not known as of now).
Upper atmosphere has a very efficient mechanism of getting rid of inputted energy from solar particles influx through NO, CO, CO2. There is no impact on surface temperature concluded. There is very delicate mechanism how this heating and cooling happens.
For CO2 issue, this is quote form Kerry Emanuel.
For example, doubling the concentration of CO2 would raise the average surface temperature by about 1.4°F, enough to detect but probably not enough to cause serious problems. Almost all the controversy arises from the fact that in reality, changing any single greenhouse gas will indirectly cause other components of the system to change as well, thus yielding additional changes. These knock-on effects are known as feedbacks, and the most important and uncertain of these involves water.
As far as this paper goes:"Solar turbulence in earth’s global and regional temperature anomalies"
Its missing the processes of the atmosphere specifically dynamics. Its concentrating on correlation, plus sun is not at its sol max but min. There are 11 and 22 year cycles of the sun. The current ideas about the amount of sunlight the Earth receives varies because of slight changes in the three parameters of the Earth's orbit, with periods of about 100,000, 41,000, and 23,000 years. But what causes the climate change over 1000,100, or 10? Many climatologists who study evidence of sun on our climate are not convinced that the connection exits. Its difficult to explain just how the sun might affect the Earth's atmos enough to make difference.
There are many ideas how these mechanisms happen, but no one dares to claim that we know it. The inherent NON-LINEARITY of the climate and contributing processes absolutely NEED to be included where they are not. The model of Wilson shows that non-linearity of sun's processes may cause the sun to switch into minimum activity (a Maunder effect). Correlation even for 400,000 years is nothing but guess work. (correlation does not imply causation). The mechanism is unknown, still. SO let's present it as it is, not as means to preconceived conclusion.
"Journey from the center of the sun', by jack b zirker, is nice book that explains what we know about sun and what are current ideas about how sun might/might not influence climate. (given on human scales the sun's output does not vary much for last 4 bilion years. Sol constant over 11 yrs cycle is 0.1% in change is too small for correlation. We need to know, if there is non-linear process which could drive this small change into climate change.)
  • #40
"NERC discussion " - very good reading. I am glad i get to read it. Recommend it to all .
  • #41
"We need to know, if there is non-linear process which could drive this small change into climate change."
From the point of view of chemistry it would require a chain reaction and these are usually initiated by ultraviolet light.And chain reactions need
a high concentration of reactants to sustain the chain.
  • #42
I am self-thought, self-interest in non-linear processes in geosciences. I do not know what processes could those be. If sol constant varies only by 0.1% over 11 year cycle, i cannot imagine any process that would make it into degrees of temp change on the surface. BUt I am not excluding the possibility.
  • #43
So did I? reread my post and see my judgement. Suggesting that I did is a strawman fallacy.
I have tried two times already in this thread to demonstrate that there is no trace of positive feedback.
This is an incredible error to me. Indeed you can read at virtually every site explaining Milankovitch that these are the correct numbers. Not your fault, But it aint. 100ka is NOT a Milankovitch cycle, it's just an incorrect oversimplification to avoid the discussion perhaps about the curious 100ka cycle. The major eccentricity cycle is 400ka with a much weaker 90 ka cycle superimposed. Richard Muller et al have tried to explain it as a inclination cycle, the Earth entering in a dust band every 100ka, obscuring the sun. But about every element of that idea has been falsified. It was a good try though.
So what is left is the suggestion that the 100ka cycle is some sort of superposition of the other cycles. But again major problems for that.
http://home.wanadoo.nl/bijkerk/41-100k-world-milankovitch.GIF
Showing the Milankovitch cycles for the last 5 million years with the 400ka cycle clearly visible. Also is visible the frequency shift of the Benthic foraminifera isotope stack that one million years ago something changed suddenly the major Earth cycle switching from 41ka to 100ka. If you explain that you hit the jackpot.
Also zooming in on the last half million years it is also clearly visible that the largest isotope spike some 430ka ago concurs with a minimum Milankovitch variation. It doesn't appear that this spike could have been caused by the insolation cycle. So why would any other?
http://home.wanadoo.nl/bijkerk/milanko3.GIF
Right, you need to find ALL the players. There is a biggy missing.
  • #44
...changing any single greenhouse gas will indirectly cause other components of the system to change as well, thus yielding additional changes. These knock-on effects are known as feedbacks, and the most important and uncertain of these involves water.
Do you think, Andre, that increasing of CO2 does not have effect on other components of the system? Or how do i understand your point?
  • #45
ANDRE said:
"Also is visible the frequency shift of the Benthic foraminifera isotope stack that one million years ago something changed suddenly the major Earth cycle switching from 41ka to 100ka"
What causes the axial tilt to change under normal circumstances?
  • #46
The difficult answer is in here.
The simple answer: different gravitation of sun and moon on the equatorial bulge creates a torque force which makes rotation bodies to perform a precession cycle, like the spin axis of an oblique spinning top slowly moving around in a circle. For Earth that is the precession of the equinoxes of 26,000 years, closely related to the precession of the perihelion, the Milankovitch cycle. The forces and torques involved are also causing the tilt of the axis to cycle with a 41,000 years cycle in a complicated way.
Talking about equatorial bulges and cycles, what, if the mysterious 100,000 years cycle was a http://www.space.com/scienceastronomy/equator_bulge_020801.html
  • #47
The pulsating equatorial bulge is thought to be caused by ocean currents bringing more sea water to the equator from higher latitudes.The cycle changes from 41000 to 100000 years - slowed by a factor of 2 and a half.There must have been material inside the Earth that had moved from the mantle to the core - a lot of it! What if the moon had developed a magnetic field that interacted with the Earth's? Would there be evidence in the
mid-atlantic ridge's magnetic record?
  • #48
Might differential torque between unevenly distributed land masses riding on liquid sections of the core cause migration of the tilt axis? Not the axis itself, but the angle of the axis in relation to the continents -- ie, a gentler and slower form of continental drift.
  • #49
Way to go, Nesp. That's it, the ability to step outside the thinking box and not considering anything outside ones own speciality for granted. The geophysicists know what Earth can do in terms of tectonic movements, mass balance, mantle core interaction, variation in spinning (length of day), etc etc but have no interest what that might do for climate. To paleo- climatologists Earth is a solid rock with fixed geography without any dynamics other than its orbit, spinning and known pertubations. You're one step short of inventing the True Polar Wander, if it wasn't for http://gsa.confex.com/gsa/2003AM/finalprogram/abstract_62207.htm.
The idea is that the uneven mass distribution on Earth may cause the inertia tensor to drift away from the spinining axis. Realignment is taken place by the inertia tensor moving back to the spin axis, which means that the whole Earth displaces in regards to the stabilized spin axis.
Does that make sense?
It is calculated however that this is a very very slow effect, assuming ice age mechanisms.
I'm thinking of more dynamic processes like this:
http://www.agu.org/pubs/crossref/2001/2000JC000235.shtml.
This clearly thrashes everything we think we know about sea-level ice sheet dynamics, you know, large ice heets, low sea level and vice versa.
The alternative angle is: what moved? Was it the sea level or the sea floor below it? Try and stretch the thinking box.
  • #50
NESP said:
"Might differential torque between unevenly distributed land masses riding on liquid sections of the core cause migration of the tilt axis"
How much would this affect the mass distribution in the mantle.
ANDRE said:
"The geophysicists know what Earth can do in terms of tectonic movements, mass balance, mantle core interaction,"
Some people think the core is a fast-breeder nuclear reactor,others don't.Can the core shift its position relative to the crust i.e can the core be off-centre? Could nuclear reactions be the cause of this?Also,how quickly does the cycle go from 410000 years to 100,000 years - is the change sudden or gradual? If the Earth's core gets hotter because of nuclear fission,does this mean that more magma comes out at the sea floor and that the magnetic strips on the sea floor are wider -perhaps in a 100,000 year cycle?
  • #51
Apologies but some people's conception of the Earth and timescales can often be surprisingly misgiven. Land masses don't ride on the core, there's this thing that some people call the mantle that kind of makes up the bulk of the Earth's volume that sits between the core and the crust!
Furthermore, global geophysicists often disregard the crust, it's just some kind of sluggish lid that nobody quite understands. The effects of mass distribution heterogeneities at the crust are completely negligible in terms of any gross moment of inertia effect on the earth.
  • #52
nesp said:
After reading several papers and seeing gore's movie on GW I'm still searching for solid scientific causal evidence (versus correlations or circumstancial) that anthropogenic greenhouse gases are the cause of global warming in the post-industrial age. I accept we are in a warm epoch, atmospheric CO2 is higher than average, humans have made CO2 levels higher, and natural CO2 levels correlate historically with temperatures. This may be enough for some, but it still does not prove human causality. I'm not rejecting the thesis of human causality for global warming, just would like to read a scientific argument that doesn't rely on correlation, circumstances, or simulations. Is that's all there is?
It is known that the concentration of CO2 in the atmosphere between 1800 and 2005 has increased from 280 to 380 parts per million. It is known without doubt that this increase is due to human burning of fossil fuels, and not
to natural sources such as the oceans or volcanoes. Here are three arguments. First of all, there was a parallel decline of the 14C/12C ratio. Second, there was a parallel decline of the 13C/12C ratio. Finally, there was a parallel decline of the oxygen concentration. All three measurements independently imply that the CO2 increase is due to the burning of
fuels, which are low in 14C and in 13C, and at the same time decrease the oxygen ratio.
Natural sources do not have these three effects. Since CO2 is amajor greenhouse gas, the data implies that humans are also responsible for a large part of the temperature increase during the same period.
Motion Mountain
The adventures of physics.
p.867-868
  • #53
Below a quote from a Physics Text book, claiming that human caused carbon-dioxide levels are proven
It is known that the concentration of CO2 in the atmosphere between 1800 and 2005 has increased from 280 to 380 parts per million. It is known without doubt that this increase is due to human burning of fossil fuels, and not to natural sources such as the oceans or volcanoes. Here are three arguments. First of all, there was a parallel decline of the 14C/12C ratio. Second, there was a parallel decline of the 13C/12C ratio. Finally, there was a parallel decline of the oxygen concentration. All three measurements independently imply that the CO2 increase is due to the burning of fuels, which are low in 14C and in 13C, and at the same time decrease the oxygen ratio.
Natural sources do not have these three effects. Since CO2 is a major greenhouse gas, the data implies that humans are also responsible for a large part of the temperature increase during the same period.
Motion Mountain
p.867-868
  • #54
<Below a quote from a Physics Text book, claiming that human caused carbon-dioxide levels are proven>
Please reread my original post. The question was how much those human caused CO2 levels impact global temperature. The answer appears to around 1K in steady state, as mentioned by Andre. Projections above or below that are the result of feedback factors not well understood.
  • #55
That 1K is a standard basic black body sensitivity for doubling CO2. in the real world things are more complex, it could be more but it's likely far less.
So if we assume 280ppmv preindustrial around 1850AD, and 380 now we are far from doubling yet the temp has already increased 0,6 degrees. Most of that happened however prior to 1940 after which some cycles came in more pronounced. So you cannot attribute that warming to dramatic increase of CO2. It's clear that natural factor play the dominant role at that time, so why not now?
  • #56
Andre said:
I disagree. Science is above all a matter of finding the truth.
Abusing it, to force the world upon changing its energy habits may be a most exemplary good cause corruption, but it kills the science and brings us back to the dark ages with devils and dragons at will of those who want to rule.
Recheck http://www.positiveatheism.org/hist/quotes/mencken.htm .
Science is practical.
And what is more practical as doing an experiment?
The scientific debate (is there a debate? the human-caused carbo levels and global warming effect is not in any doubt any more) can go forever, without resolvin anything.
By the way, so-called "scientists" are paid by oil companies to spread disinformation about the CO2 issue.
By the way... my post was a bit of cynism of course, as if what I suggested (stopping fossil fuel usage) could be done...
This does not prevent us however for inventing measures that can reduce the problem.
  • #57
Like Nesp, I'm just a guy trying to figure this out. Re the textbook quote:
"CO2 in the atmosphere between 1800 and 2005 has increased from 280 to 380 parts per million. It is known without doubt that this increase is due to human burning of fossil fuels, and not to natural sources such as the oceans or volcanoes."
If the increase is "without doubt" caused by human burning of fossil fuels, does that mean decreased carbon sink capacity from human deforestation is not a factor? If it is a factor, what's the relative contribution of deforestation vs anthropogenic CO2 emissions in increasing CO2 levels?
I often see increasing atmospheric CO2 levels described as a simple imbalance between emission and absorption capacity.
But I read all anthropogenic CO2 output is just about 3% of natural CO2 output. Is that number right? If so, why are atmospheric CO2 levels increasing so rapidly? That implies the biosphere has virtually no adaptability -- no excess carbon sink capacity. If bumping the total CO2 output (natural + anthropogenic) by 3% creates this, doesn't that imply the solution is to reduce it by an almost equal amount?
This may be naive, but if the Earth's carbon cycle is that delicate, it seems the required solution is far more drastic than cutting anthropogenic emissions by 20%. Atmospheric CO2 started increasing at the beginning of industrialization when anthropogenic emissions were a fraction of today. If global CO2 emissions were reduced by 70%, the historical graphs I've seen imply atmospheric levels would still be increasing, only slower.
Do we have any idea what reduction in global anthropogenic CO2 emissions is required to achieve equilibrium in atmospheric CO2 levels? If so, what's the basis for and confidence in that number?
I've looked through a bunch of GW stuff, and can't find clear answers to these. Would appreciate any explanations or pointers.
  • #58
A neat little http://earthobservatory.nasa.gov/Library/CarbonCycle/Images/carbon_cycle_diagram.jpg here.
The most important part of the carbon cycle is the balance at the sea surface. Changes in ocean - atmosphere fluxes, with an order of magnitude more substance than anthrpogenic CO2, would have a strong effect on the atmospheric CO2. But then again, even before the K/T boundary some more than 65 million years ago the atmospheric the pCO2 (of leaf stomata proxies)was between 300-500ppmv, where it is still today:
http://home.wanadoo.nl/bijkerk/CO2-KT-PETM.GIF
  • #59
The argument that increased atmospheric CO2 levels are anthropogenic based on C14/C12 ratios seems pretty good. I'd be interested if anyone has a contrary opinion to that argument.
Re amt of increase from anthropogenic emissions vs reduction in carbon sink capacity due to deforestation, the new IPCC report indirectly addresses this. http://www.ipcc.ch/SPM2feb07.pdf
It says annual anthropogenic emissions are about 7 GtC per year, whereas "land use changes" create about 1.6 GtC per year. Don't know if that's effective creation due to reduction of sink capacity or actual emissions from burning. Either way the % contribution of land use changes vs hydrocarbon emissions seems small.
However -- there may be a fundamental math error in the new IPCC report. Could someone please cross-check me on this?
On page 12, it says "model studies suggest that to stabilize at 450 ppm carbon dioxide, could require that cumulative emissions over the 21st century be reduced from an average of approximately 670 [630 to 710] GtC to approximately 490 [375 to 600] GtC."
I think they forgot to account for the annual increase in hydrocarbon consumption for the nominal "no change" case. Unless I'm mistaken, this is a fundamental error that greatly impacts the calculation of required emission reduction, and any related planning.
E.g, current world anthropogenic CO2 emissions are about 7 GtC per year. If it was capped at that level tomorrow, over the 21st century cumulative emissions would be about what IPCC says: 670 GtC. They apparently just multiplied 93 years by 7 GtC/yr.
However world energy use (of which hydrocarbons make about 85%) increases at about 1.5% to 2% per year, as it's keyed to economic output and development. Like compound interest on a bank account, that makes a vast difference over time.
Thus the baseline number is NOT 670 GtC cumulative emissions over the 21st century, but 7 GtC/yr increasing at a 1.5% to 2% compounded annual rate.
I don't know the formula, but it's the same one to calculate final balance of a non-interest-bearing bank account assuming annual contributions increase at x%. It doesn't matter whether annual growth rate in energy consumption is 1%, 1.5% or 2%. Over a century the difference is vast.
At 1.5% annual growth, the actual "no change" case would be thousands of cumulative GtC released over the 21st century, NOT 670 GtC.
My question is did IPCC model that, or just 670 GtC. This affects everything -- how bad the perceived problem is, amount of required reduction to achieve a given benefit, etc.
It can't be such a simple error. Have I missed something?
  • #60
OK I found the formula. It is:
FV = D * ((1+r)^T - 1) / r , where:
FV = Cumulative carbon emissions in GtC over 93 yrs (2007-2100)
D = 1st yr emissions (7.0 GtC)
r = annual % increase of emissions
T = time in yrs (93 yrs)
So rather than the baseline IPCC number of 670 GtC over the remaining 21st century, the actual baseline emissions would be:
1857 GtC @ 2% annual growth
1396 GtC @ 1.5% annual growth
The EIA projects about an approx. 2% annual growth in hydrocarbon energy consumption over the next quarter century. If that continued over the remainder of the 21st century, the baseline number is 1857 GtC.
Hence the reduction required is NOT from 670 GtC down to 490 GtC, but from 1857 GtC down to 490 GtC.
That is a big difference. I'd be very interested in knowing which input value was modeled -- 1857 GtC or 670 GtC.
This affects everything -- climate modeling, how achievable the needed reductions are, etc.
That superficially looks like a 74% reduction in hydrocarbon energy consumption is required. But it's worse than that. You'd have to virtually eliminate hydrocarbon energy. Why?
Because no matter what technology or how ambitious the plan, it takes time to implement. Hence the 1st few decades you're still burning hydrocarbons at the current rate (inc'l annual increase). All that counts against the IPCC 21st century cumulative limit of 490 GtC.
That means in later decades of the 21st century, much greater reductions are needed than 74%. The entire globe would have to mostly run on fusion or something like that, otherwise you'll go over 490 GtC cumulative emissions. And even that results in atmospheric CO2 increasing to 450 ppm, significantly above current levels.
  • #61
Bottom line is that you'dhave to believe that climate is so sensitive to CO2 radiattive forcing. But it's not. The numbers of IPCC require an amplification of the CO2 greenhouse effect known as positive feedback. Here is the sensitivity at thermal equilibrium, fora US standard atmosphere about 0,97 C increase per doubling with no feedbacks:
http://home.wanadoo.nl/bijkerk/modtran-rad-bal.GIF
but thermal equilibrium is a long lasting process. So you'd need a lot of positive feedback, which is non existent.
  • #62
Explanation Global Warming & Cooling
A) 20 th Century Global Warming
1) 20th Century Solar Changes & Global Cloud Cover
As the thread on clouds notes, the sun is at its highest activity in 8 kyrs, the solar large scale magnetic field has doubled in the last 100 yrs, and in the last 20 years solar coronal holes have began to move towards the solar equator (The solar coronal hole creates a high speed solar wind when it passes in the Earth's direction).
"Electroscavenging"
The cloud thread in this forum describes a mechanism where rapid increases in the solar wind, causes an increase in the Global Electric Circuit which causes a potential difference between equator and Polar regions. The potential difference it is hypothesized (and data supports) removes atmospheric ions which causes low level clouds to dissipate. As the GCR created ions are removed, electroscavenging makes it appear that the Earth's temperature is no longer correlated with the solar cycle and GCR level.
A doubling of the sun's large scale magnetic field will shield the Earth from Galactic Cosmic Rays (GCR). Satellite data (See cloud thread, Palle's paper) indicates that there is a 99.5% correlation with changes in GCR and low level cloud level (over a 20 year period). An increase in GCR causes an increase in low level clouds and a decrease in GCR causes a decrease in low level clouds. The correlation between clouds and GCR holds up until 1993 at which time the satellite data indicates that low level clouds start to be reduced, which is consistent with the 'electroscavenging' process.
Palle estimates the warming due to the reduction in cloud cover 1993 to 2001 is 7.5 W/m2 or roughly three times the estimated forcing for CO2 (2.5 W/m2).
Some scientists questioned whether Palle's interpretation of the satellite cloud data was correct. Palle et al, then measured the Earth's albedo using telescopes that measured the Earth'shine reflected off of the moon. The Earth'shine data supported the satellite data.
2. CO2 and Global Warming
Is it possible that solar changes caused the majority of the 20th century warming? Yes, if Palle's data and analysis is correct. A separate thread should be started to discuss what is know concerning CO2 and its affects on the planet's temperature. Recent data indicates that there have been times in the planets history when CO2 levels have been high and the planet has been cold and visa versa. The relationship between CO2 and planetary temperature is not linear and it appears that there may be a strong negative feedback affect of clouds which regulates planetary temperature (stops the planet from warming when CO2 levels are high) rather than the assumed very strong positive feedback of water vapour with increasing planetary temperature that was assumed by the IPCC and is currently used in the climate models.
B) 21th Century Global Cooling
The 20th century warming (sun at its highest level in 8kyrs, doubling of solar large scale magnetic field, and the coronal holes moving towards the solar equator), seems to be a Henrich event which is named after the climatologist that discovered the semi-periodic event. A Henrich event is a warming of the planet which is then followed by an abrupt cooling (3C drop in temperature, 2C in five years, Younger Dryas, and then roughly 1C drop over a hundred years as the oceans cool.)
There is not consensus as to what causes the observed warming and abrupt cooling, however, there is evidence that the Younger Dryas cooling event could have been caused by a solar event. (i.e. There is a very large increase in cosmogenic nucleons, in the sea sediment data and ice core data which indicates a large increase in GCR flux during the Younger Dryas period.)
Attached is a link to the paper: "Reduced solar activity as a trigger for the start of the Younger Dryas?" that discusses the Younger Dryas Cooling event.
http://scholar.google.com/url?q=http://dept.kent.edu/geography/GEC/Reduced_solar_activity_as_a_trig.pdf&sa=X&oi=unauthorizedredirect&ct=targetlink&ust=1173034345556434&usg=__FlOTD7nJVxYUBokLsjE8z6DrfAk=
It should be noted that the Younger Dryas paper was written in 2000 before Palle's paper and findings. The Younger Dryas paper assumes the solar event is only a change in solar irradiance, rather than a change in planetary cloud cover which would be consistent with Palle's findings.
All of the public discussion associated with climate change has been concerning global warming and strongly focused on CO2. Attached is a link to lecture material by Strong that shows how the climate has changed over the last 100,000 years. Based on the climatic record interglacial periods are brief and end abruptly.
John Stone, Climate Record Over the Last 100,000 years
http://www.washington.edu/research/or/symposium/stone.pdf
When you look at the above climatic record, what do think, is causing the abrupt changes in planetary temperature and the glacial/interglacial cycle?
  • #63
Might be an idea to check out
Svensmark, H. 2007. Cosmoclimatology: a new theory emerges. Astronomy & Geophysics 48: 1.18-1.24.
Changes in the intensity of galactic cosmic rays alter the Earth’s cloudiness. A recent experiment has shown how electrons liberated by cosmic rays assist in making aerosols, the building blocks of cloud condensation nuclei, while anomalous climatic trends in Antarctica confirm the role of clouds in helping to drive climate change. Variations in the cosmic-ray
influx due to solar magnetic activity account well for climatic fluctuations
on decadal, centennial and millennial timescales. Over longer intervals,
the changing galactic environment of the solar system has had dramatic
consequences, including Snowball Earth episodes. A new contribution to the faint young Sun paradox is also on offer.
PM me an email address for a copy.
Not really. Heinrich event:
http://en.wikipedia.org/wiki/Heinrich_event
Heinrich events are regarded as profound and catastrophic events, with likely armadas of icebergs launched from the Hudson Strait.
I seem to remember that there was no dramatic 10Be spike. There was a clear delta14C spike correlating with the last spike of the Allerod 12,800 years ago. But there were other 14C spikes not correlated with younger Dryas type of events.
Link is dead for me but I've read a few hundred papers on the Younger Dryas.
I think it's better to find out exactly WHAT the Younger Dryas was exactly before thinking about causes. The explanation of the Greenland Ice core appears completely at odds with other geologic evidence. take for instance:
http://www.geol.lu.se/personal/seb/Geology.pdf.pdf
You can take it from me that this was norm rather than anomalous, warm dry Younger Dryas summers. It should also be noted that sea surface temperatures dropped significantly during the preceding "warm" Bolling Allerod. Low SST inhibit cloud forming. The cause of that sequence may have been the Amazon fan clathrate destabilisation event:
http://tinyurl.com/2uqdan
That presentation is below standards, it contains a fraudulent graph on page 4. Other than that, more things are different than it seems
Cyclic variation of Earths Geoide shape. That's a tough one.
  • #64
  • #65
GCR Paper's Explanation for Polar See/Saw & Faint Sun
In response to Andre's Comment 63 concerning a request for recent GCR papers.
Attached is a link to Svensmark's December 2006 paper that provides an explanation for the polar sea/saw.
http://arxiv.org/pdf/physics/0612145
Svensmark's paper concerns the Antarctic anomaly, which is also called the polar see-saw. The Polar see-saw is the term used to describe the phenomena where when the Atlantic region warms the Antarctic cools and vice versa. While other hypothesis (such as ocean currents) have been proposed to explain the polar see-saw, they cannot explain why the change is simultaneous. (i.e. If the effect has due to ocean currents one would expect a delay from hemisphere to hemisphere, as the ocean currents take time to change) Svensmark's paper provides data (bore hole temperatures, see figure 1, and satellite data figure 2) to support his hypothesis that changes in global cloudiness is causing the polar see-saw.
From Svensmark's paper:
"Clouds warm the underlying surface by trapping the outgoing long-wave radiation and cool it by reflecting the short-wave radiation from the sun. In general the cooling affect is greater than the warming effect, (my comment: for low level clouds) and results in a net cooling of the Earth of 15 W/m2."
"The cooling effect is not evenly distributed. As shown in fig. 2 it is minimal around the Equator and increases towards mid-latitudes. In polar regions the clouds can have a warming effect if the re-radiation, of long-wave radiation downwards dominates over the loss of short wave radiation solar radiation (my comment: short wave radiation reflected back into space)"
In the Arctic the effect of an increase in low level clouds is about neutral. In the Antarctic due to the very high albedo of the Antarctic (more energy is reflected into space in the Antarctic than is received from the sun. i.e. Heat must move to the Antarctic region or the temperature there would drop further.), an increase in clouds causes warming.
B) Faint Sun
Attached is a link to Shaviv's paper that provides a GCR explanation as to why the Earth was warm (not covered in ice) when the sun was younger and fainter.
http://arxiv.org/pdf/astro-ph/0306477
  • #66
Milankovitch's Insolation Hypothesis. Cause of Ice Ages?
Hi Andre,
I am curious as to what you meant when you stated:
"Cyclic variation of Earths Geode shape. That's a tough one."
In response to my question what is causing the Glacial/Interglacial cycle and the abrupt climate changes.
I would assume you mean Milankovitch's insolation theory which hypothesizes that variation in the Earth's orbit (changes in orbital eccentricity and tilt of the Earth's axis which affect relative insolation levels and the relative temperature difference between the seasons) which affect whether summers are relatively warmer and winters relatively colder and visa versa, is the cause for the ice ages.
Based on that theory, the next ice age should be starting now, as the Earth is farthest from the sun June 20 and closest to the sun December 20 and the Earth's tilt is almost at its minimum. (The glacial period is hypothesized to start when summers are cool and winters are warm.) Insolation at the critical latitude 60N is the same as it was during the last glacial period maximum.
I do not see how changes in insolation could possibly result in Canada, North US States, Russia, and Northern Europe being covered with an ice sheet that is 2 miles thick. Have you read the thread what causes Ice Ages? In that thread there is data that shows an glacial period ending when insolation has close to minimum. What could have caused the planet to warm?
In response to your scepticism to my comments concerning the Younger Dryas: Please click twice on the link to the paper I referenced. You have not read the paper I referred to. The paper I referred to notes cosmogenic isotopes doubled during the Younger Dryas, it also notes that there was ice rafting during the Younger Dryas, the same as occurred during the Henrich events. Data and analysis is provided to substantiate those statements.
  • #67
William,
It's now 8 years ago that I decided to solve the riddle of the Mammoth extinction. I don't think that there are very many studies left with keys words like: "Pleistocene", "Younger Dryas", that I have not read. All those studies that seek to support / explain/ proof a certain part about the hypotheses pertaining the ice age are invariably based on limited information, projecting the unknown as being granted, but most of that unknown is not unknown but actually ïgnored because it completely contradicts the current paradigms. And then there are the studies that are completely unexplained, for instance:
Beijing inundated by the sea within the past 80 k.y.: Nannofossil evidence
Wuchang Wei
Scripps Institution of Oceanography, University of California, San Diego, California 92093, USA
Manuscript Received by the Society August 7, 2001
Revised Manuscript Received December 13, 2001
Manuscript Accepted December 14, 2001
ABSTRACT
Examination of published data reveals that a marine bed in Beijing can be dated as 80 ka or younger on the basis of abundant nannofossils. This age is 30 times younger than that published previously on the basis of magnetostratigraphic and biostratigraphic interpretations. The abundant nannofossils and foraminifers suggest that Beijing was inundated by the sea within the past 80 k.y. The very recent nature of this marine transgression has profound societal and geological implications and thus calls for new studies and thorough evaluation of all relevant data sets.
I'm trying to respond to that appeal. There must be a missing player, responsible for a lot unexplained and wrongly explained phenomena. It could be a pulsating equator. See this thread:
https://www.physicsforums.com/showthread.php?t=153634
  • Earth Sciences
  • Earth Sciences
44K
  • Earth Sciences
28K
11K
10K
  • General Discussion
