- #1
prs725
- 3
- 0
Local oscillators that is used in RF transmitters for AM modulation.Any help is appreciated. Thanks !
prs725 said:Local oscillators that is used in RF transmitters for AM modulation.Any help is appreciated. Thanks !
Thank you !carlgrace said:Look up oscillator on Wikipedia. 99% of the oscillators used for AM modulation would be the "relaxation oscillator" type.
Thank you !Antiphon said:A local oscillator is usually mixed (through a multiply circuit) with the baseband signal. This creates an intermediate frequency (IF) that is easier to work with.
davenn said:The term LOCAL OSCILLATOR is more correctly used in a receiver not a transmitter
its the freq of the LO that is mixed with the incoming signal from the antenna to produce an IF signal which depending onthe received frequency there may be more than one LO and several IF (Intermediate Frequencies) for example
a received freq of 550 MHz mixing with the first LO of 505MHz gives the first IF of 45 MHz,
it then may be mixed again with a second LO of 494.3MHz to give a second IF of 10.7MHz
and finally mixed again with another LO of 10.245 MHz to give a 3rd IF of 455kHz from which the audio is demodulated.
thats a common arrangement for VHF and UHF and up received frequencies
lower freqs such as AM broadcast bands 550 - 1620 kHz more commonly just used a single IF down to 455 kHz ( there are a number of variations around 455 kHz used + - a few kHz)
altho that does happen for the transmit side its not overly common. Its more common to use an oscillator either operating at the freq of interest or multiplying up from a lower freq
say a crystal based Colpitts or Hartly osc as VK6KRO indicated.
Also to the OP --- in an AM transmitter, the audio modulation is normally applied to the last amplifier stage of the transmitter. No Local Oscillators involved in that process. This is quite opposite to a FM transmitter, where the oscillator is modulated with the audio signal.
cheers
Dave
A local oscillator is an electronic circuit or component that generates a precise and stable radio frequency signal. It is commonly used in radio and communication systems to mix with an incoming signal in order to produce a new frequency for further processing.
A local oscillator is important in communication systems because it provides a stable reference frequency for the mixing process, allowing for the precise tuning and demodulation of incoming signals. Without a local oscillator, communication systems would not be able to accurately transmit and receive information.
A local oscillator works by using an electronic oscillator circuit, such as an LC circuit or a crystal oscillator, to generate a specific frequency. This frequency is then mixed with an incoming signal, resulting in the production of a new frequency that can be easily processed and transmitted.
There are several types of local oscillators, including voltage-controlled oscillators, phase-locked loop oscillators, and crystal oscillators. Each type has its own advantages and is used in different applications depending on the required frequency stability, tuning range, and other factors.
Local oscillators are commonly used in communication systems, such as radios, televisions, and cell phones. They are also used in radar systems, satellite communications, and other electronic devices that require precise frequency generation and control.
