Is This Reduction Reaction Equation Correct?
In summary, the conversation was about a reduction reaction involving the equation MnO4- + S2- -> MnO2 + S8. The individual seeking help went through the process of breaking down the reaction into two half-reactions and balancing them, ultimately arriving at the final balanced equation of 2MnO4- + 24S2- + 8H+ -> 2MnO2 + 3S8 + 8OH-. They also received assistance from others in a chemistry forum and were able to successfully solve the problem.
VinnyCee
489
Chemistry Reduction Reaction Help Needed: MnO4- + S2- --> MnO2 + S8
I was wondering if I had done this reduction reaction equation correctly:
[tex]MnO_4^-+S^{2-}\xrightarrow{}MnO_2+S_8[/tex]
After going through the reduction reaction problem solving process (I think) I get this equation as the final equation in the reaction:
[tex]2MnO_4^-+3S^{2-}+4H_2O\xrightarrow{}2MnO_2+3S_8+8OH^-[/tex]
Does this look correct? Can anyone check? Thanks.
Here is a more detailed explanation of the answer I have
Ok, starting with the original equation:
I then separate into two "half-reactions":
[tex]MnO_4^-\xrightarrow{}MnO_2[/tex]
[tex]S^{2-}\xrightarrow{}S_8[/tex]
Figureing the oxidation charge for the left side of the first "half-reaction":
[tex]X-8+1=0\xrightarrow{}X=7[/tex]
Therefore, the oxidation number of Mn on the left side is 7, right?
Then I do the right side of the first "half-reaction":
[tex]X-4=0\xrightarrow{}X=4[/tex]
This means that the oxidation number of Mn on the right side is 4. Meaning that I have to add 3 electrons to the left side of the first "half-reaction" equation, right?:
[tex]MnO_4^-+3e^-\xrightarrow{}MnO_2[/tex]
Now, I added H+ ions to the left side to bring it's overall charge down to zero, because the right side has an overall charge of zero:
[tex]MnO_4^-+3e^-+4H^+\xrightarrow{}MnO_2[/tex]
Finally, I add H2O to even out the oxygens in the first "half-reaction" equation:
[tex]MnO_4^-+3e^-+4H^+\xrightarrow{}MnO_2+2H_2O[/tex]
Going on to the second of the two "half-reaction" equations:
The oxidation number for the left hand side of the second "half-reaction" equation is -2 and for the right side it is 0, right? So then I added 2 electrons to the right side of the second "half-reaction" equation:
[tex]S^{2-}\xrightarrow{}S_8+2e^-[/tex]
I then multiply the two results from the "half-reaction" equations in order to eliminate the electrons:
[tex](MnO_4^-+3e^-+4H^+\xrightarrow{}MnO_2+2H_2O)*2=2MnO_4^-+6e^-+8H^+\xrightarrow{}2MnO_2+4H_2O[/tex]
[tex](S^{2-}\xrightarrow{}S_8+2e^-)*3=3S^{2-}\xrightarrow{}3S_8+6e^-[/tex]
Adding them together, I get:
[tex]2MnO_4^-+3S^{2-}+8H^+\xrightarrow{}2MnO_2+3S_8+4H_2O[/tex]
Finally, I add OH- to balance and eliminate the H2O's on the right side:
[tex]2MnO_4^-+3S^{2-}+8H^++8OH^-\xrightarrow{}2MnO_2+3S_8+4H_2O+8OH^-[/tex]
[tex]2MnO_4^-+3S^{2-}+8H_2O\xrightarrow{}2MnO_2+3S_8+4H_2O[/tex]
[tex]2MnO_4^-+3S^{2-}+4H_2O^+\xrightarrow{}2MnO_2+3S_8+8OH^-[/tex]
Does this seem reasonable?
your final line: [itex] ... 4H_2O^{+} [/itex] ?
and the sulfur is not balanced.
How do I balance the equation then? Did I do the "half-reaction" equations correctly?
Do you see where I made a mistake?
Thanks again.
Redoing the problem
I did it again by starting with an actual balanced equation:eek:
Ok, starting with the original equation (now balanced):
[tex]MnO_4^-+8S^{2-}\xrightarrow{}MnO_2+S_8[/tex]
[tex]8S^{2-}\xrightarrow{}S_8[/tex]
[tex]8S^{2-}\xrightarrow{}S_8+2e^-[/tex]
[tex](8S^{2-}\xrightarrow{}S_8+16e^-)*3=24S^{2-}\xrightarrow{}3S_8+48e^-[/tex]
[tex]2MnO_4^-+24S^{2-}+8H^+\xrightarrow{}2MnO_2+3S_8+4H_2O[/tex]
[tex]2MnO_4^-+24S^{2-}+8H^++8OH^-\xrightarrow{}2MnO_2+3S_8+4H_2O+8OH^-[/tex]
[tex]2MnO_4^-+24S^{2-}+8H_2O\xrightarrow{}2MnO_2+3S_8+4H_2O+8OH^-[/tex]
[tex]2MnO_4^-+24S^{2-}+4H_2O^+\xrightarrow{}2MnO_2+3S_8+8OH^-[/tex]
FAQ: Is This Reduction Reaction Equation Correct?
What is a reduction reaction?
A reduction reaction is a chemical reaction in which a molecule gains one or more electrons, resulting in a decrease in its overall charge. This process is typically accompanied by the oxidation of another molecule, which loses electrons.
How do reduction reactions occur?
Reduction reactions can occur through a variety of mechanisms, including the transfer of electrons from one molecule to another, the addition of hydrogen atoms, or the removal of oxygen atoms. These reactions can be triggered by heat, light, or the presence of a catalyst.
What is the importance of reduction reactions?
Reduction reactions play a crucial role in many biological processes, such as cellular respiration and photosynthesis. They are also essential in industrial processes, such as the production of metals and the synthesis of organic compounds.
How can I identify a reduction reaction?
One way to identify a reduction reaction is by examining the changes in oxidation numbers of the atoms involved. If an atom's oxidation number decreases, it has undergone reduction. Additionally, reduction reactions often involve the formation of new bonds or changes in the physical properties of the molecules.
What are some common examples of reduction reactions?
Some common examples of reduction reactions include the rusting of iron, the conversion of copper oxide to copper metal, and the reduction of carbon dioxide to produce methane in the production of natural gas. Another example is the reduction of silver ions to silver metal in silver plating processes.
