Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Ode Share It Thread Tools Search this Thread image
Old Nov2-09, 05:23 PM                  #1
jen81
jen81 is Offline:
Ode
Hi,
I have a second order differential equation but I do not know how to solve it.
LaTeX Code: \\frac{d^2Q}{dn^2} LaTeX Code: \\left  -A(B-n\\right)\\frac{dQ}{dn}+  LaTeX Code: \\left(A + \\frac{C}{n}\\right)Q = 0
Appreciate if anyone could help me on this.
Thank you
Old Nov2-09, 08:46 PM                  #2
LCKurtz
LCKurtz is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Ode
Probably you must solve with an infinite series. Maple gives a solution in terms of HeunB functions which are computed as a power series around the origin.
Old Nov3-09, 05:52 AM                  #3
HallsofIvy
PF Mentor
HallsofIvy is Online:
Re: Ode
Since that is a linear equation with constant coefficients, I see no reason to resort to power series. The characteristic equation is the quadratic
LaTeX Code: r^2- A(B-n)r+ A+ \\frac{C}{n}= 0
Solve that with the quadratic formula:
LaTeX Code: r= \\frac{A(B-n)\\pm\\sqrt{A^2(B-n)^2- 4A- 4\\frac{C}{n}}}{2}
Old Nov3-09, 11:54 AM                  #4
LCKurtz
LCKurtz is Offline:
Recognitions:
Re: Ode
??? The independent variable is n. Bad notation admittedly, but not constant coefficient.
Old Nov4-09, 05:04 AM                  #5
HallsofIvy
PF Mentor
Re: Ode
Ah- I missed that. Thanks.
Old Nov6-09, 07:16 AM                  #6
gato_
gato_ is Offline:
Re: Ode
The solution given by maple is not very helpful... I found it useful to make the following standard transformation, to get rid of the first derivative (I have changed the independent variable's name to x):
LaTeX Code: Q(x)=exp(-A(x-B)^{2}/4)y(x)
By doing that, the resulting equation is
LaTeX Code: ysingle-quotesingle-quote(x)+[C/x+A/2-A^{2}(x-B)^{2}/4]y(x)=0
So the full solution consists of a gaussian like envelope multiplying a carrier function with what we can consider a spatial dependent frequency (not so, as it turns negative at some point, and the wave becomes evanescent). Close to x=0, the equation:
LaTeX Code: ysingle-quotesingle-quote(x)+y(x)C/x=0
Has
LaTeX Code: y=C_{1}\\sqrt{2}J_{1}(2\\sqrt{Cx})
as solution, which goes as
LaTeX Code: y\\approx x^{1/4}Cos(2\\sqrt{Cx}-3\\pi/4)
as x increases. However, we know that the frequency can't increase indefinitely, because there is a turning point when the coefficient in front of y(x) approaches 0. The solution around that point can be expressed locally in terms of Airy functions (that is, it matches oscillation with pure decay). The full solution then looks like in the attached figure
I am sure there is a nicer solution... but I don't find a simple one.
image image
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
