Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Astronomy & Cosmology > Astrophysics
Reply
image Absence of dust on moon and material sciences Share It Thread Tools Search this Thread image
Old Nov3-09, 10:51 PM                  #1
zankaon
zankaon is Offline:
Might absence of dust on moon (such as for astronauts' experience) relate to importance of material sciences? That is, might surfaces interact electronically, seeking a more stable lowest energy configuration? Imaging it as if 2 grates rubbing together, seeking best fit? Air might then disrupt such surface interaction, such as for Martian dust. Hence then the ancillary idea of moving surfaces slightly intermittently, so as to disrupt such 'settling in', for joints of machines, such as Canadian arm on shuttle, and for space probes such as Huygens-Cassini.
Old Nov4-09, 12:07 AM                  #2
Integral
PF Mentor
Integral's Avatar
Integral is Offline:
Re: Absence of dust on moon and material sciences
Dust on the moon? What are you on about? There is plenty of dust on the moon. It does not hang in the air because there is no air for it to hang in. Any particle that is not on the surface will fall with NO air resistance, so it is a simply proplem of basic physics to find how long it will take to return to the moons surface.
Old Nov4-09, 11:27 PM                  #3
qraal
qraal is Offline:
I think s/he means "adherence" of dust on the Moon. Obviously talking about how "adhesively" the stuff stuck to the "Apollo" moonsuits and everything else.
Old Nov5-09, 02:02 AM                  #4
Phrak
Phrak is Offline:
Recognitions:
PF Contributor PF Contributor
I think you've got it. What role does an atmosphere play in discharging electrostatic charges, so that clinging dust particles may fall-away?
Old Nov5-09, 04:57 PM                  #5
qraal
qraal is Offline:
Well atmosphere allows electrostatic charges to slow leak away from a surface and obviously the Moon doesn't have that process to allow charge to escape. It does have some other weird electrostatic effects like levitating dust and dust fountains.
Old Nov5-09, 05:52 PM                  #6
mgb_phys
Physics Guru 2008
mgb_phys is Offline:
Recognitions:
Homework Helper Homework Helper
Also because of the lack of an atmosphere the dust on the moon is rough and jagged so tends to stick together, especially since there is nothing between adjacent atoms on different dust particles..
On Earth any dust has been weathered into a smoother rounded shape and is less likely to stick together because there is always a surface layer of air/moisture/chemicals on each particle.
image image
Reply
Thread Tools
Similar Threads for: Absence of dust on moon and material sciences
Thread Thread Starter Forum Replies Last Post
Absence of Jupiter.... BosonJaw Astrophysics 19 Oct19-07 02:19 PM
Automobile energy cost - Dust to Dust report Andrew Mason Mechanical Engineering 15 Aug22-07 12:05 AM
Material Science, Material Selection Question mathwurkz Engineering, Comp Sci, & Technology 1 Nov21-05 06:38 PM
absence hypnagogue General Discussion 4 Dec18-03 03:34 PM
Moon and tides (tide on the moon instead of earth) andytran General Physics 7 Oct5-03 04:32 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
