Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Quantum Physics
Reply
image No entropy/environment = no time flow? Share It Thread Tools Search this Thread image
Old Nov2-09, 08:40 PM                  #1
dmtr
dmtr is Offline:
Is that right, that it is only makes sense to talk about the time evolution (or particle paths) in the presence of the environment? That without the environment any closed system would simply stay in the superposition of states and there wouldn't be any time flow?
-- Dmtr
Old Nov3-09, 05:48 AM                  #2
xepma
xepma is Offline:
Re: No entropy/environment = no time flow?
Time evolution of the wavefunction is dictated by the Schroedinger equation. You don't need an environment from that.
Besides, you cannot really talk about a static state of a closed system anyway. There is always some internal stuff going on.
Old Nov4-09, 01:49 AM       Last edited by dmtr; Nov4-09 at 02:03 AM.. Reason: grammar            #3
dmtr
dmtr is Offline:
The Schroedinger equation doesn't say that the wave function have to evolve. True, it describes unitary transformation with the time flow, but it doesn't specify that the time has to flow! And to which direction the arrow of time should point.
-- Dmtr
Old Nov6-09, 03:58 AM                  #4
dmtr
dmtr is Offline:
Not even wrong?
-- Dmtr
Old Nov6-09, 06:45 AM                  #5
Haelfix
Haelfix is Offline:
Recognitions:
Their will be time flow (you are free to stick in your own time coordinates if you want, even with a vanishing hamiltonian -- the hamiltonian constraint will hold the dynamics), but without the 2nd law of thermodynamics each subsystem could in principle have their own arrow of time so macroscopic comparison would be difficult and bizarre.
Old Nov6-09, 02:26 PM                  #6
Atakor
Atakor is Offline:
I don't see how there wouldn't be any flow of time if there's a certain dynamics going on there..
Of course it does !
if we believe in the hypotheses that lead to its formulation, like the existence of time.
Old Nov6-09, 03:41 PM                  #7
dmtr
dmtr is Offline:
That would be the time flow from the point of view of some subsystem of that closed system (subjective time flow). And as you said (without the 2nd law) their own time arrows would not have a preferred direction.
Now, I'm not really interested in that subjective perspective from the inside of a closed system. I'm interested in the (normal in physics) objective perspective of an outside observer! And what I'm saying is that from that perspective it doesn't make sense to talk about the time flow/direction in the closed system. It could be anything (without the 2nd law).
-- Dmtr
Old Nov7-09, 05:24 AM                  #8
Fra
Fra's Avatar
Fra is Offline:
Recognitions:
PF Contributor PF Contributor
-- Dmtr
In physics a real observer, as opposed to some mathematical gedanken observsers, is always in contact/interacting with the system, or it isn't making any real observations.
Ie. if the system is really closed, then it also means no observations can be made on it, because the system is by definition isolated from the observer.
In such a case then it's IMHO not even a scientific question. It's a complete realist construct of what is going on inside a completely isolated closed system that noone can look into. And then sure, it could be anything. Because the system is closed and nonone could every verify anything.
OTOH, taken one step further, a properly isolated system would even be indistinguishable and invisible. Noone would see it.
The usual notions of closed and open systems in "normal physics" are idealisations, so that the systems are sort of isolated by a boundary of limited transmission for a short period of time etc. Or where the measurements performed are neglectable.
But from a fundamental point of view, the closed system idea with an outside observer is hard to make sense out from an operational perspective.
/Fredrik
Old Nov7-09, 08:24 AM                  #9
Fra
Fra's Avatar
Fra is Offline:
Recognitions:
I figure it's motivated to clarifiy how I interpret the normal "time evolution" of closed systems, given my view above.
One of the standard views is that the schrödinger equation describes the time evolution of an isolated system, or the time evolution of the system _in between_ measurements. So then, in what sense does that make sense in a more radical view?
IMO, I see the schrödinger equation, as the expected self-evolution of a system (ie. given information; hamiltonian, inital condistions etc), but in the more radical view this expectation is observer-dependent. Ie. to have such an expectation, the system can not have been isolated in the past, the observer must have some kind of interaction history with the system (part of the preparation of experiment). Thus the hamiltonian itself, beeing an expectation, must IMHO be encoded in the observers internal state too.
So then what is the point of an expected evolution of a system (when I called evolution of an isolated system a realist construct)? IMO, the point that makes a different is when you consider the action of the observer itself. The observers action will follow from it's expectations on it's environment.
I like to think of it so that the observers almost "simulates" his own environment, in between, or parallell to, if you think in continous terms, his interactions with the environment. So in a holographic sort of way, the observers evolution is in consistency with the expected evolution of the rest of the universe.
But the probability of expectations beeing in tune, should intutively decrease if the interaction is isolated for a long time.
Do you perhaps share C.Rovelli' and J.Barbours views on time in that it has no place in the fundamental laws of physics? (I don't, btw)
"The nature of time" but Julian Barbour
http://www.platonia.com/nature_of_time_essay.pdf
"Forget time" by Carlo Rovelli
http://www.fqxi.org/community/forum/topic/237
as a good CONTRAST to these ideas, check out smolins
"On the reality of time and the evolution of laws" but Lee Smolin
http://pirsa.org/08100049/
/Fredrik
Old Nov9-09, 04:38 AM                  #10
Atakor
Atakor is Offline:
the same could be said about the observer himself I think. In fact, in my opinion this leads to a global view where the observer becomes part of the system ie. not really an observer.
Or I didn't get your point.
I think that the quantum zeno effect is a good illustration of what you're saying.
Old Nov9-09, 11:15 AM                  #11
Fra
Fra's Avatar
Fra is Offline:
Recognitions:
I'm not sure,It doesn't sound like I was able to convey the point clearly. I reject a global view where the observers are internal subsystems, that are described globally.
It seems you suggest that the problem of the observers is to be solved by removing the observer (dismissing it to a subsystem) and instead replace the operational view with a global or birds view. This is _exactly_ what I reject. The operational perspective is fundamental IMO.
For sure the observer is a player, not just an inert observer. So in that respect you are right. However this does not in my reasoning at least imply that there is a global perspective.
The point is that all we have are subjective perspective, and these are interacting, and each observers witnesses an evolving world. But there is no global or external description of this evolution in my thinking. If there was one, it would certainly be nice, but unfortunately it's a realist picture that IMO lacks justification.
I instead suggests that there is always some residual undecidability at every physical scale. It's the lack of a global perspective to hang onto, that causes me to adpot the idea of evolving law.
/Fredrik
Old Nov9-09, 02:52 PM                  #12
dmtr
dmtr is Offline:
An example of a completely closed system would be a system going away from an observer with the speed of light. Interestingly this effectively stops the observed time evolution of such a system.
-- Dmtr
Old Nov10-09, 05:05 AM                  #13
Atakor
Atakor is Offline:
Quantum mechanics itself (as a theory) plays the role of the external description.. or does it ?
Special Relativity doesnt tell us the momenta and energies of all the particles, but gives invariant descriptions that we can use for each observer-dependent -subjective- case.
Finally I think your views are very statistical by nature, it seems you consider statistical (interacting) systems as more fundamental than individuals (whatever that means).
But as far as I see this, both are metaphisical prejudices.. at least for me.
Old Nov10-09, 06:50 AM                  #14
Fra
Fra's Avatar
Fra is Offline:
Recognitions:
This sounds pretty much like Carlo Rovelli's view (Relational QM).
I guess QM is "supposed to be this". But my view is that ts doesn't make sense. I think it's an approximation, and I've elaborate on before why I think it's a good approximation in many cases. But why it's not satisfactor in a fundamental sense.
But I reject Rovelli's otherwise nice reasoning because of this. He is simplifying things IMO, and he happens to simplify the most important things.
But Special realtivity only covers a very special set of observers, namely those related by poincare transformations.
Two such "sets" have invariant descriptions only for a constrained set of subjective observers, so when they suddently experience an strongly accelerating observer or strong gravitational fields, their invariants break down.
If you consider a more general set of observers, related by differmorphisms, you get a more complicated relation between observers.
But the question I ask, is how can a in inside observer infere these symmetries from interactions only? it's tempting to consider massive statistics, but there is a limit to how much statistics an observer can related to, and there are also choices on howto store and represent data.
Also, things are worse since GR and SR are classical realist models that isn't formulated operationally. I think the union of them and QM will require that we answers some of these questions.
/Fredrik
Old Nov10-09, 08:50 AM                  #15
Atakor
Atakor is Offline:
SR was just an example of course, I meant a theory that relates observables by certain invariant links or relations.
by essence those relations must involve more than one observer to be discovered (to get rid of subjectivity and extract the invariance) which leads us back to the conventional view of first principles (ie. outside observer) !
But one can argue that we ARE already insiders in a certain sens: we're inside the universe we're describing not outside of it.
For me the most fundamental question is not about the emergence/imposition or direction of description (top-down or bottom-up) but about the nature of the observer himself : consciousness.
Old Nov10-09, 10:18 AM                  #16
Fra
Fra's Avatar
Fra is Offline:
Recognitions:
Indeed! This is IMO a major key insight, it's not just a curiousity of no interest. IT's actually a difference between fundamental principle and effective principle.
What we call and most think of as "objective science" IS in fact highly conditional on a specific perspective, namely the earth/human based perspective.
If we are talking about atomic physics, our perspective is objective scientists in between, no doubt - and this is the important point in science. That there is a scientific concensus within the community.
But there is more to this than just this, it's when it comes to the foundational issues, then what is FAPP objective, must be seen for what it really is.
From a human perspective, no doubt the knowledge of laws of physics has evolved - and this knowledge determines how we humans act. But similarly (this subtle point is apparently hard to convey) the distinguishable laws of physics from the point of view of the subatomic observers, might actually be determine it's action as well.
I am not very into the discussion of conscioussness, since it often leads to absurd discussions. However, with some stretch of the associations here I find it possible to picture what conscioussness might mean for a subatomic system - it's the awareness of it's own actions, in the sense that the physical action of the system takes into account that it's not a passive observer, but that it's own actions actually make a difference to the future. This "basal" level is I think in all systems, and it's IMO nothing divine or religious about this, I just see it as a condition for constructivity.
Then the fact that there are different LEVELS of complexity and awareness, like animals with brains, and ultimately humans, is a somewhat different discussion. But I think some of the principles of self-organisation is similar.
/Fredrik
image image
Reply
Thread Tools
Similar Threads for: No entropy/environment = no time flow?
Thread Thread Starter Forum Replies Last Post
Time span or time flow Zman Special & General Relativity 3 Sep11-09 09:25 AM
Entropy over time Niles Advanced Physics 1 Feb27-08 03:27 PM
Time and entropy Phred101.2 Advanced Physics 5 Oct18-07 05:13 PM
The Flow Of Time ralphcalc Special & General Relativity 26 Dec14-05 03:54 AM
Time flow. wolram Special & General Relativity 1 Nov26-04 11:21 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
