Light-Cone Gauge: Benefits for Quantum Relativistic Particles & Strings
  • Context: Graduate
  • Thread starter Thread starter wam_mi
    Gauge
The light-cone gauge is crucial for simplifying calculations in quantum relativistic particles and strings by transforming momentum coordinates from (p0, p1, p2, ...) to (p+, p-, p2, ...). This transformation leads to a trivial Dirac sea, allowing for a unique solution for p+ given the light cone momentum p-, which prohibits mixing of quarks and anti-quarks. The gauge field A is set to A- = 0, eliminating one polarization and introducing a Coulomb potential through the inversion of the Gauss constraint. While beneficial for calculations, challenges such as non-dynamical fermionic degrees of freedom persist, particularly in 1+1 dimensions.
  • Understanding of light-cone coordinates in quantum field theory
  • Familiarity with Dirac sea and its implications in particle physics
  • Knowledge of gauge fields and the Gauss constraint
  • Basic principles of quantum chromodynamics (QCD)
  • Research the implications of light-cone gauge in quantum field theory
  • Study the works of F. Lenz and M. Thies on 1+1 dimensional QCD
  • Explore the relationship between light-cone gauge and string theory
  • Investigate the Hamiltonian framework and Poincare covariance in light-cone coordinates
Quantum physicists, theoretical physicists, and researchers focusing on quantum field theory, particularly those interested in the applications of light-cone gauge in particle and string theories.
wam_mi
Hi there,
How is the light-cone gauge useful for a quantum relativistic particle and for a quantum relativistic string? Why is it important that the light-cone gauge is used? Does it actually simplify the mathematics a lot?
Thanks
Our group studied 1+1 dim QCD in light cone coordinates 15 years ago; you should look for papers from "F. Lenz" and "M. Thies" - unfortunately not in arxiv.
The main difference in light cone coordinates is the following
p = (p0, p1, p2, ...) => (p+, p-, p2, ...)
The dispersion relation for massive particles reads:
p+ = (... + m²) / 2p-
where ... means the perpendicular components.
Due to this dispersion relation for the light cone energy p+ the Dirac sea becomes trivial; there is a unique solution for p+ for given light cone momentum p- ; that means that a sea-particle cannot be excited w/o violation of the light cone momentum. Therefore a "mixing" of quarks and anti-quarks is forbidden = the vacuum structure is trivial.
Nevertheless you can find non-vanishing condensates, but in a different formalism.
The light cone gauge for a gauge field A then means
A- = 0
It is comparable to the axial gauge, that means
- one polarization is eliminated completely
- a "Coulomb potential" arises due to invertion of the Gauss constraint
Usually one derives a Hamiltonian framework (one has to check for Poincare covariance)
In some sense the light cone frame is related to the infinite momentum frame.
As far as I know the light cone approach is not widely used in QCD; the trivial vacuum structure seems to be a benefit when one starts with the calculations, but there are other difficulties like non-dynamical fermionic degrees of freedom (in 1+1 dim. you can see that one component of the spinor is non-dynamical as there is no light cone time derivative) and the non-local light cone energy operator.
I have no idea how this relates to string theory.
  • · Replies 26 ·
  • · Replies 26 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 61 ·
11K
