Force Vectors and Dot Products
  • Context: Undergrad
  • Thread starter Thread starter ewan_71
    Dot Force Vectors
The discussion revolves around the application of force vectors and dot products in the context of atomic interactions. Participants explore the relationships between force vectors and their directional components, specifically regarding the forces acting on two atoms, A and B.
  • One participant, Ewan, questions whether the dot product of the force on atom A (Fa) and the position of atom B (Pb) indicates the magnitude of the force on A in the direction of B.
  • Another participant asserts that to find the component of Fa in a specific direction, one must use the dot product with the unit vector pointing from A to B, which is derived from the difference in their positions.
  • Ewan also asks if the dot product of Fa and Fb represents the attractive force between the atoms, to which a participant responds that this interpretation is incorrect as it does not yield a force unit.
  • A further clarification is provided that the attractive force towards atom B can be expressed as the dot product of Fa with the unit vector pointing from A to B, scaled by that unit vector.
Participants generally disagree on the interpretations of the dot products in relation to the forces and positions of the atoms. There is no consensus on Ewan's initial questions, as different viewpoints are presented regarding the correct application of the dot product.
Participants discuss the need for a directional vector to accurately compute the components of forces, highlighting the importance of unit vectors in these calculations. The discussion does not resolve the underlying assumptions about the nature of the forces involved.
This discussion may be useful for individuals interested in vector mathematics, atomic physics, and the application of dot products in force analysis.
ewan_71
Hello all :smile:,
I am interested in the following problem:
In an ensemble of atoms, the forces on atom A and atom B are given by the vectors Fa=Fax+Fay+Faz and Fb=Fbx+Fby+Fbz, respectively.
Their respective positions are given by,
Pa=Pax+Pay+Paz and Pb=Pbx+Pby+Pbz
I have two questions:
(1) Would I be right in thinking that the dot product of Fa and Pb will give the magnitude of the force on atom A in the direction of atom B?
(2) Also, is the dot product of Fa and Fb the attractive force between the atoms?
Any help would be greatly appreciated :smile::smile:!
Ewan.
No. To find the component of Fa in some direction, take its dot product with the unit vector in that direction. The direction from A to B will be parallel to Pb-Pa.
No. (That quantity would not even have units of force.)
No and no.
You would want the directional vector that points from A to B. So it would be:
[tex]\hat{R}_{ab} = \frac{\mathbf{P}_b-\mathbf{P}_a}{\left|\mathbf{P}_b-\mathbf{P}_a\right|}[/tex]
Then you would do the dot product of Fa and \hat{R_{ab}}.
I assume by attractive force you just mean the magnitude of the force in the direction towards the other atom (regardless of whether or not the atom's are causing the attraction since you do not specify how these forces arise). The force on A towards B is just Fa\cdot\hat{R_{ab}}\hat{R_{ab}}. That is, it is the dot product of Fa and R_{ab} scaling the vector R_{ab}. Likewise, for B, you use Fb and -R_{ab}.
Thanks guys that's extremely helpful! :)
