What is the Difference Between Delta and Differential in Calculus?
  • Context: Undergrad
  • Thread starter Thread starter gasavilu
    Delta Differential
The discussion revolves around the differences between the terms "delta" (\(\delta W\)) and "differential" (\(dW\)) in calculus, particularly in the context of scalar functions. Participants explore various interpretations and applications of these terms across different fields, including thermodynamics and calculus of variations.
  • Some participants suggest that \(\Delta W\) represents the exact change in a function \(W\) between two points, while \(dW\) approximates this change using the tangent line at a point.
  • One participant notes that \(\delta\) is often used in the context of inexact differentials, although they admit limited experience with them.
  • Another participant mentions that \(\delta\) can denote variations in calculus of variations, indicating small changes in a function.
  • A different viewpoint emphasizes that \(dX\) is a one-form in differential geometry, while \(\delta X\) can represent arbitrary changes or coordinate transformations, particularly in thermodynamics.
  • One participant shares their experience of using \(\delta\) as a precursor to differentiation, highlighting its role in illustrating the concept of limits in calculus.
Participants express various interpretations of the terms, with no clear consensus on their definitions or applications. Multiple competing views remain regarding the appropriate contexts for using \(\delta\) and \(d\).
Some discussions involve assumptions about the definitions and contexts of \(\delta\) and \(d\), which may not be universally agreed upon. The mathematical distinctions and implications in different fields remain unresolved.
This discussion may be of interest to students and professionals in mathematics, physics, and engineering, particularly those exploring calculus concepts and their applications in various fields.
gasavilu
Hi guys
Can anybody help me? What is the difference between a delta [tex]\delta W[/tex] and a differential [tex]dW[/tex]? ([tex]W[/tex] a scalar function, for example.) In other words, when shold be used a delta and when a differential? Thanks.
Suppose W is a differentiable function of x. Consider some value of x, say x = a and W(a). Now suppose we have a "nearby" point b = a + h, so h would be small. Then:
[itex]\Delta W = W(b) - W(a)[/itex] represents the [exact] change in W from a to b.
The differential of W is defined to be the change on the tangent line at a:
[itex]dW = W'(a)h[/itex].
For small h we have [itex]\Delta W \approx dW[/itex]
I'm assuming that your use of [itex]\delta[/itex] has the same meaning as the common usage of [itex]\Delta[/itex]. If I'm wrong about that, feel free to ignore this reply :rolleyes:
I've also seen [itex]\delta[/itex] used as the variation of a function (calculus of variations or differential geometry). Ie., [itex]W(x) + \delta W(x)[/itex] where [itex]\delta W(x)[/itex] is a function that is "small" in the neighborhood of interest.
gasavilu said:
Hi guys
dX is in mathematical terms something which is called a one-form. You can integrate it to obtain X. Physically, this X has to be well-defined then. In thermodynamics for instance the quantity X has to be a function of state. A counterexample would be the heat Q or the mechanical work W. You can't define a state with defnit heat or mechanical work; these quantities only have meaning if you go from one thermodynamical state to another. So if I would write dQ or dW for the changes, this would imply that I could obtain Q and W for a state by integrating, which is not well-defined. That's why people often choose to write [itex]\delta[/itex] instead of d for these quantities.
If you want to know the exact mathematical difference, the answer lies in differential geometry I think; like I said, a quantity dX is in diff.geometry a one-form which lives in a dual vector space called the dual tangent space, while [itex]\delta X[/itex] indicates either an arbitrary change (like in the variational principle; here the [itex]\delta[/itex] gets you from one field solution to another which can't be accomplished by a mere coordinate transformation), a coordinate change (if you want for instance to know the behaviour of X under a spacetime transformation; here X is in a representation of some group which describes coordinate transformations like the Lorentz group, the Poincare group or the Galilei group) or a change in some internal space (where X is then a gauge field in some representation of some gauge group and where you perform in infinitesimal gauge transformation).
I hope this helps a little :)
Hi all.
My original question had to do with a problem of electrodynamics. I have not yet a clear answer but the support received has given me a broader perspective about the problem. Thank you all for your help.
In my experience it was used as a precursor for differentiation, for example,
The gradient of the line connecting the points (f(x), x) and (f(x+δx), x+δx) is [f(x+δx)-f(x)]/δx, in the limit δx -> dx, we get the gradient to be df/dx.
Ie. δf = f(x+dx) - f(x), and df = f(x+dx) - f(x)
This seems to be how a lot of physics lecturers used calculus, although I can't say I'd ever seen this in my maths introduction.
Just seems to me to be a bit of a formalism to make the differentiation clear, without resorting to limits as something goes to zero.
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 22 ·
