Finding the eccentricity of Earth's orbit
In summary, the eccentricity of Earth's orbit is a measure of how elliptical or circular the orbit is, with 0 representing a perfectly circular orbit and 1 representing a highly elliptical orbit. It can be determined using Kepler's laws of planetary motion and the current eccentricity is approximately 0.0167, making Earth's orbit very close to being circular. The eccentricity does not have a significant effect on the seasons, as the tilt of Earth's axis and its orientation towards the sun is the primary factor. However, the eccentricity has changed over time and varies cyclically over a period of about 100,000 years due to the gravitational influence of other planets in the solar system.
dimensionless
462
Given the mass of the sun, the gravitational constant, the period of Earth's orbit, and the semi-major axis of Earth's orbit, is it possible to find the eccentricity of the orbit? If yes, how?
Kindly post your own thoughts on the matter, as per the Physics Forums Guidelines, which you agreed to.
I'm really not sure if it can be done. If it can I don't know how. I guess that maybe it can't be done, since there appears to be no way to find to foci.
This is not actually a homework question by the way.
FAQ: Finding the eccentricity of Earth's orbit
What is the eccentricity of Earth's orbit?
The eccentricity of Earth's orbit is a measure of how elliptical or circular the orbit is. It is a dimensionless number between 0 and 1, with 0 representing a perfectly circular orbit and 1 representing a highly elliptical orbit.
How is the eccentricity of Earth's orbit determined?
The eccentricity of Earth's orbit can be determined through the use of Kepler's laws of planetary motion, specifically the third law which relates the period of a planet's orbit to its distance from the sun. By measuring the distance between Earth and the sun and the time it takes for Earth to complete one orbit, the eccentricity can be calculated.
What is the current eccentricity of Earth's orbit?
The current eccentricity of Earth's orbit is approximately 0.0167, meaning that Earth's orbit is very close to being circular.
How does the eccentricity of Earth's orbit affect the seasons?
The eccentricity of Earth's orbit does not have a significant effect on the seasons. The tilt of Earth's axis and its orientation towards the sun is the primary factor that determines the changing of seasons.
Has the eccentricity of Earth's orbit changed over time?
Yes, the eccentricity of Earth's orbit has changed over time. It varies cyclically over a period of about 100,000 years. This is due to the gravitational influence of other planets in the solar system, primarily Jupiter and Saturn, causing slight variations in Earth's orbit.
