Circuit of a Scanning Tunneling Microscope (STM)
In summary, the conversation discusses the speaker's project of building a scanning tunnelling microscope (STM) for their integration class. They mention choosing the cheapest design, which uses a unimorph disk and op-amps. The speaker has some knowledge in electronics but not enough to understand all aspects of the circuits involved. They ask for clarification on the use of capacitors, op-amps, and tap points in the circuits, as well as the possibility of using a PC sound card for the oscilloscope output. The conversation also touches on the potential for improving the circuits by using DACs and a microcontroller. The potentiometers in the schematics are used to adjust the gain of the quantum tunneling amplifier. Finally, the
Logik
31
Hi, for my integration class I am building a scanning tunnelling microscope (STM). I found some interesting designs and I choose the cheapest one (students are poor) witch uses a unimorph disk. The circuits are not that hard to build but I also need to understand them. I have some knowledge in electronics but not enough to understand every aspect of the electronics involved.
Here are the circuits (sorry pdf): http://www.geocities.com/spm_stm/Simple_STM_Rev_C.PDF"
The circuits are mostly composed op-amp's which i understand basicly but not enough to understand these circuits.
So here are my questions:
What are the effects of using a capacitor coupled with an op-amp (only used them basically with resistors)?
On op-amp in D1-D2 what is connected to 1 and 5 and what is the use of 1-5?
What are the TP (TP1,2,5,6)?
Instead of using and BNC male connector output for the oscilloscope is it possible to use an audio like male connector and plug it into a computer sound card (analog2digital) and use a software oscilloscope?
What are the uses of the potentiometers and how do they work?
Can the circuits be improved?
If you have any other suggestions don't be shy, I am opened to anything. Also don't be scared of being too technical, I will figure it out or read around to understand it.
Thank you in advance.
P.S. I will also post in the engineering design section and in quantum physics one for other questions. So if you are interested about other part or have a lot of knowledge on STM's you can go to the two other threads.
https://www.physicsforums.com/showthread.php?t=109369"
https://www.physicsforums.com/showthread.php?t=109377"
This is a very neat project. I've always wanted to do it but never had time.
Here is another link:
http://www.geocities.com/spm_stm/Project.html
For your circuit you need 2 ramp signal generators which drive both the circuit to scan X and Y direction but also sweep a dot on the oscilloscope in X and Y direction, such that a pixel on the scope will correspond to an offset of the needle some micrometers away. Then the magnitute of the quantum tunneling will be amplified and applied to Z axis (brightness of pixel) on the scope. This should result in a nice scan.
Since a PC sound card contains one ADC (analog digial converter) It will not work without some kind of synchronization.
Mostly to kill any oscillation or act as low or high pass filter.
sorry can't find it.
Tap points which are easily accessable points of wire where you can stick a voltmeter.
Potentiometers are variable resistors when turned change resistance.
O yeah, but its too advanced. You could drive X and Y with 2 DAC's (digital analog converter) and a microcontoller.
Potentiometers are variable resistors when turned change resistance. ¨
I know that but I want to know more in debt to what i have to adjust them.
waht said:
Since a PC sound card contains one ADC (analog digial converter) It will not work without some kind of synchronization.¨
Are you shure it wouldn't work? It looks it would work by looking at this software site (http://polly.phys.msu.ru/~zeld/oscill.html" ) but I can't tell... I was more scared about amperage or frequency of the output current then the card not converting properly...
So while you are running the microscope you would adjust them for best possible picture.
As for the PC sound card, does it have it 2 channels? and a third for Z axis?
1. What is a Scanning Tunneling Microscope (STM)?
A Scanning Tunneling Microscope (STM) is a scientific instrument used to obtain high-resolution images of surfaces at the atomic level. It works by scanning a sharp probe over the surface of a material and measuring the flow of electrons between the probe and the surface.
2. How does a STM work?
A STM works by applying a small voltage between the probe tip and the sample surface. As the probe moves over the surface, electrons tunnel through the small gap between the probe and the surface. The resulting electric current is measured and used to create an image of the surface.
3. What is the circuit of a STM?
The circuit of a STM consists of a power supply, a feedback loop, and a computer. The power supply provides the voltage between the probe and the sample, while the feedback loop controls the distance between the probe and the surface to maintain a constant tunneling current. The computer processes the data and creates an image of the surface.
4. What are the components of a STM?
The main components of a STM include the probe tip, piezoelectric scanner, feedback loop, and computer. The probe tip is a sharp metal tip that scans the surface of the sample. The piezoelectric scanner moves the probe in small increments. The feedback loop controls the distance between the probe and the surface. The computer processes the data and creates an image of the surface.
5. What are the uses of a STM?
STM is widely used in nanoscience and nanotechnology research to study and manipulate materials at the atomic level. It has applications in fields such as material science, physics, chemistry, and biology. STM can also be used for surface analysis, surface modification, and nanofabrication.
  • Quantum Physics
  • Electrical Engineering
