Is .99 Repeating Truly Equal to 1?
  • Context: High School
  • Thread starter Thread starter raven1
    Beauty
The discussion centers around the mathematical assertion that 0.999... is equal to 1. Participants explore various arguments, proofs, and counterarguments regarding this concept, touching on topics such as infinite series, the nature of real numbers, and the understanding of infinity. The scope includes theoretical reasoning and mathematical proofs.
  • Some participants accept that 0.999... equals 1, citing various proofs and discussions as support.
  • Others argue that there must be a difference between 0.999... and 1, referencing the division of 1 by 3 and claiming that there is always something left over in repeating decimals.
  • A participant suggests that the understanding of real numbers and infinite series is crucial to grasping why 0.999... equals 1.
  • Another participant emphasizes that those who reject the equality often misunderstand the nature of numbers and their representations, viewing them strictly as their decimal forms.
  • Some participants propose specific mathematical proofs, such as manipulating infinite series and using algebraic methods to demonstrate the equality.
  • Concerns are raised about the lack of mathematical skill among some individuals, which may hinder their understanding of concepts like infinity.
  • Several participants express skepticism about the possibility of convincing those who do not accept that 0.999... equals 1, suggesting that their beliefs are deeply rooted.
Participants generally do not reach a consensus on the equality of 0.999... and 1. Multiple competing views remain, with some accepting the equality and others firmly rejecting it based on their interpretations of mathematical principles.
Limitations in understanding of infinite series and the nature of real numbers are noted as potential barriers to agreement. The discussion reflects a range of mathematical competencies among participants.
raven1
i accept that .99 repeating equals 1. I read a lot of posts as why it is true and I accept them. ii had a discussion with some people about this and their response is there must be a difference. the basic reason is based on what happens when you divide 1 by 3. they claim 1/3 dose not equal .33 repeating, that even if u go out to infinity there was always be something left over, and with any repeating decimal there will always be something left over . I am not sure how to respond. Part of the problem is they never went that far into math
because they chose never to go far into math, you should tell them not to bother about stuff they don't have the competence to discuss.
Alternatively, tell them that in the constuction of the real numbers (for example with the use of the equivalence class concept) it is a trivial, almost definitionally true statement that 0.99..=1
Ask them to define what Real Numbers are. When they can't blind them with the correct definition:
the completion of the rationals
Note there are other equivalent definitions. In anyone of them those two *different symbols* represent the same Real Number. I am capitalizing the 'r' of real to indicate that Real Numbers refers to a specific set of objects, not their hand wavy (understandably) ill informed idea. I don't understand how anyone can actually accept that there is such a thing as 0.9.. in the first place yet not accept this. I suspect it is because they do not get what infinite sums are.
Also ask them if they accept that symbols are just representations of these objects and that it is perfectly possible for two different symbols to represent the same thing, like 1/2 and 3/6.
In high school algebra, at some point, the concept of infinite series is introduced. If you understand it, then the idea that .999...=1 or that .333...=1/3 is trivial. Otherwise you can run into fundamental difficulties in undertanding.
Yeah , let x = .999... then 10 x = 9.999... Since the decimal part is the same infinite series for both x and 10x, it cancels by subtracting. Thus we have 9x = 9 which gives x = 1.
Similarly x = .333... gives 9x = 3 showing that x = 1/3.
Another example is the infinite geometric series
\frac{1}{2} \quad \frac{1}{4} \quad \frac{1}{8} \dots which can be shown to equal 1 by letting x equal the sum and subtracting x from 2x It is indeed trival if you understand infinite series.
Of course, people who claim 0.999... is not equal to 1 also will not accept that you can do arithmetic on infinite digits like that. There's probably no way of arguing with them- they think of numbers as being their decimal representations rather than just represented by them: 0.999... is a different representation than 1, therefore a different number!
I think that the lack of mathematical skill hinders most people from regarding "infinity" as anything else than a whopping big number.
That is, without mathematical expertise, the ideas of infinity (and many others) remain rough and naive (and useless).
Not a particularly revolutionary insight, I guess..
As soon as they say there's always something left you whip out "Oh ya, well one of the proofs is showing there's nothing left!" like so
<br /> 1 - .999... = 0.0000...1<br />
Now, I'm aware of how bad an idea it is to put "1" after an infinite series. But they'll accept this. You really don't want to use the summation sign going from 0 to infinity with non-math people. Anyways, continuing:
0.000...1 = 1*10^{-\infty}
It helps if you show that .1 = 10^-1, .01 = 10^-2 and so forth to backup this step.
Then explain how X^-Y = 1/x^y and do this:
1*10^{-\infty} = \frac{1}{10^\infty}
and how 10^infinity = infinity:
\frac{1}{10^\infty} = \frac{1}{\infty}
and anything divided by infinity is 0:
\frac{1}{\infty} = 0
so that means:
1 - .999... = 0
Then adding .999... to both sides you get:
1 = .999...
Alkatran, people who do not believe .9999=1 will not believe that 1/infinity = 0.
Well then there's no hope.
Then tell them how 1/9 = .111...11
10/9 =1.11...10 implies that
10/9 - 1/9 = 9/9 = 1 = 1.00...(-1) = 1 - 1/infinity and thus 0 = 1/infinity!
If they still don't acept that, say too bad since anyone having success in math accepts this and until you have faith that this is true you will not succeed in math.
There's nothing wrong with these latest posts... I just don't like necromancy of .999~ = 1 threads.
  • · Replies 33 ·
  • · Replies 41 ·
  • · Replies 33 ·
11K
