How Do You Calculate Projectile Motion in Physics?
  • Thread starter Thread starter frankfjf
The discussion revolves around calculating projectile motion, specifically focusing on a stone projected at a cliff with an initial speed and angle. Participants are exploring how to determine the height of the cliff, the speed just before impact, and the maximum height reached by the stone.
  • Participants discuss the relationship between the trajectory and maximum height, with some questioning how to find the vertical component of velocity at the highest point. There is also uncertainty about which variables to use in the motion equations.
The conversation is active, with participants providing hints and exploring different aspects of the problem. Some guidance has been offered regarding the vertical motion equation and the implications of velocity at the highest point, but there is still some confusion about applying these concepts correctly.
Participants are navigating the complexities of projectile motion, including the effects of initial conditions and the significance of time in determining maximum height. There is an acknowledgment that the initial and final positions are not at the same height, which affects the analysis.
frankfjf
n Fig. 4-33, a stone is projected at a cliff of height h with an initial speed of 40.0 m/s directed at an angle 0 = 56.0° above the horizontal. The stone strikes at A, 5.10 s after launching. Find (a) the height h of the cliff, (b) the speed of the stone just before impact at A, and (c) the maximum height H reached above the ground.
Part c is basically asking for the trajectory, right?
In a sense, yes, but only one aspect of it. How would you go about finding the maximum height?
To be honest I'm not sure.
Here's a hint: What's the vertical component of the velocity when the stone reaches its highest point?
That's just it, I have no idea what to plug in for determining the velocity at the highest point.
I think that the formula involved would be the vertical motion equation for velocity, Vy = Vi*sin(angle) - gt.
Well actually, if I took half of the time, wouldn't it be at its highest point then?
Think about it. Imagine throwing a ball straight up in the air. Initially it moves up (velocity = +); after reaching the highest point, it starts moving down (velocity = -). So what can you say about the speed at the highest point?
Good.
Only if the initial and final positions were at the same height, which is not true in this problem.
Well, at the highest point the speed would be zero, since it's going to start falling immediately after hitting the highest point.
Exactly right. Now make use of that fact.
But now I'm confused as to just where to plugin the zero.
If the formula Vy = Vi*sin(angle) - gt is used, does the zero replace Vy or Vi?
What do you think? (Does the initial velocity change?)
No, but if I put in zero for Vy, I'm left without any variables.
You can solve for the time; that's what you need.
Ahhh I got it now, thanks!
  • · Replies 53 ·
  • · Replies 38 ·
