Heat Loss in a Hot Water Pipe System
In summary, the homeowner wants to know how much energy is wasted along their run of copper pipe due to the slow flow of hot water. They have some information about the heat lost along the pipe from a previous source, but they need to plug in some numbers for the inside and outside pipe temperatures. They also want to know what simplifed convective heat transfer coefficients to use for the air on the outer pipe wall.
Ouabache
1,346
This was a question posed to me by a homeowner. I don't know very much thermodynamics and hope someone here might have a better understanding.
They have a run of 3/8in copper pipe leading from their water heater to various taps. On cold mornings, it takes a long time, for hot water to flow to the faucets and shower heads. Their idea is to do a rough cost analysis to try and justify the cost of replumbing (making shorter run) from water heater to taps.
I thought a reasonable place to start is to calculate the heat lost along their run of pipe (perhaps in BTU/ft-hr). I found some information about this ref a. The Heat Transfer calculation assumes you know the temperature on both the inside and outside surface of the pipe. I could plug in some numbers for inside temperature; such as 130 deg F at the heater and 120 deg F by the time it reaches the tap (with assumption that the hot water temperature deceases along the run of pipe). I don't have any figure to use for the outside pipe surface temperature.
There is also a parameter k , the thermal conductivity, which is puzzling. In Marks' Standard Handbook for Mechanical Engineering, there is a table of Thermal Conductivity of Metals. For copper between 7 and 700 deg F, [itex]k_{to}= 232[/itex] and [itex] a = 0.032 [/itex]. In caption it states [itex] kt = kt_o - a(t-t_o)[/itex] and k (Btu/hr/ft^2/deg F/ft). The units are different from the k in ref2 which are Btu/hr-ft-deg F. They differ by units of ft^2 in denominator. Now if [itex] kt = kt_o - a(t-t_o)[/itex] , with a little algebra, I find that [itex]k = -a[/itex]. But that doesn't seem right either, because this value of [itex]a = 0.032[/itex] is 4 orders of magnitude from the thermal conductivity (108 Btu/hr-ft-deg F) of stainless steel used in example in ref2.
Perhaps there is an easier approach to this part of the question. One online ref b, with some hand waving, state the heat losses from a couple different diameters of copper hot water pipe, with and w/o insulation. They assume a constant inside pipe temperature of 140 deg F and mention the ambient air temperature is 70 deg F. I don't know if there may be standard tables to obtain this sort of information for the heating and plumbing industry.
Your thoughts or suggestions are appreciated.
You may be able to do a simpler energy analysis. Since you know the input and output temperatures you know how much energy per gallon (l) of water it lost while flowing through the pipe.
You can compute the approximate volume of water in the pipes to get an idea for how much energy is wasted when the pipes are not flowing. This could be done best by taking some measurements on the water temperature after sitting for a measured amount of time.
Strictly speaking, you might include the convective heat transfer coefficient of the water on the inside of the pipe, and then the conduction of heat through the pipe wall in addition to the convective heat transfer from the pipe wall to the air, but this really isn't necessary in your case. The heat transfer from the water to the pipe, and through the pipe wall is very very high compared to the convection from the outer pipe wall to air. Thus you can neglect heat transfer from the water to the outer pipe wall and just assume the outer pipe wall is the same temperature as the water without loosing much accuracy.
Another thing you can do is use simplifed convective heat transfer coefficients for the air on the outer pipe wall if you're only looking for a ballpark estimate. For this situation I'd suggest using h = 1.0 to 1.5 Btu/hr/ft2/F.
Finally, you can assume the water has a large heat capacity and doesn't change in temperature much as it flows through the pipe so that the temperature at the end of the pipe only drops a few degrees at most.
First calculate the outer surface pipe area in square feet (A = pi * OD * L) then use this equation:
Q = A * h * (Tw - Ta)
where Q = heat lost (Btu/hr)
A = outer surface area (ft2)
Tw = water temp (F)
Ta = Air temp (F)
Note this only looks at the steady state heat loss and not the transient of having to warm a cold pipe. I think that can probably be neglected as well, though I'm less sure about that without doing the calculation.
Why don't they just go to Home Depot or someplace and by the foam insulation that wraps around pipes? The stuff works pretty good.
Before even running numbers I would like to point out how incredibly difficult it can be to rerough plumbing lines in existing homes. It is very labor intensive and takes quite a long time to do. Granted, there are new products that eliminate the need for copper, but even so, it's a lot of work. Just from gut feel, I would be very surprised if you broke even on the endeavor in 10 years. It does depend on the house of course, but the labor part still has to be considered.
I'd say you're better off spending a day insulating the water heater and the exposed piping first.
My advice is to take a look at the book "Fundamentals of Heat Transfer" of Incropera and see how they treat the flux of heat through pipelines with T=T(x). In general q''=q''(x) and h=h(x). I don't have the book here but I remind to have made this calculation several times some time ago.
Some really great comments!
Q_Goest, excellent input. You reminded me there are transient and steady-state parts to this process. To fully appreciate your comments, I'll need to read up a little on convective heat transfer coeficients and how they're applied. Doing a quick dimensional analysis, your Q appears to be in Btu/hr. I will be sure to include a calculation for the transient condition too.
Averagesupernova, they actually do have new foam insulation around all the exposed pipe, but there is also a significant run of pipe that is not insulated between floors. To more accurately calculate the heat loss, I would need to include the thermal conductivity (k) of the foam, in the calculation for that section of the run.
FredGarvin, good thought, however let me elaborate on their system. They have a relatively new water heater installation. With the old heater, the pipe went straight up to some taps and then across about 50 ft (through cooler ambient temperature room) to 3 more taps. The new water heater was installed in a different location of basement, actually directly below the 3 periferal taps. When they plumbed it, they just ran pipe across the basement to where the old heater was. If you follow me, the run of pipe now goes twice as far to reach the 3 periferal taps. The run across the basement is insulated with foam.
Clausius2, i will followup on your thoughts of Heat Flux. It sounds similar to the one described at the bottom of my reference
Integral said:
You may be able to do a simpler energy analysis. Since you know the input and output temperatures...
I appreciate your line of thought..The input and output temperatures are still unknown, I plugged in some typical values [url=[PLAIN]http://www.naturalhandyman.com/iip/infwaterheater/infwhadjust.shtm[/URL], for a residential system. They indicated 130 deg F in the tank and 120 deg at the tap.
According to the US Department of Energy, a temperature of 120 degrees at the tap is adequate for most household chores with a minimal danger of scalding and maximal energy efficiency. However, that is the temperature at the tap, not in the tank. Tank temperature should be no less than 130 degrees to prevent bacterial growth, such as Legionnaires disease.
Back to your discussion, your approach does simplify the analysis. As you point out, the input and output temperatures may be measured. As both Q_Goest and you assert (and something I hadn't considered), this process may be broken into parts.
(i) The *energy loss of the standing water in the pipes between usage (with ambient daytime temperature; nighttime 45 deg, daytime 60 deg). The temperature differential for this water volume, could be as much as 85 deg (130deg cooled to 45 deg F).
(ii) when tap is initially opened, there is energy loss during the transient period to warm up the pipes.
(iii) energy loss during the steady-state, where pipes are warmed up to a maximum temperature and hot water is flowing out the tap.
Parts (i) and (ii) will vary depending on how often hot water is drawn from the pipe. At the same time, there is a variance of ambient air temperature throughout the day. Some reasonable approximations may need to be made (for these variances), to make this calculation managable.
Summarizing my understanding of this approach; by measuring water temperature at the input and output over time, we can make a reasonable estimate for the following losses in an annual period: (a) determine the energy lost between usage of hot water, (b) energy lost in warming up the system (transient), (c) energy lost while the hot water is running (steady-state).
*here using energy and heat loosely. The actual relationship between the two is noted here.
Might I suggest using a plumbing heat tape for that initial run. (Assuming water temp was adequate for your friend before the new heater was installed.) This along with a timer could cost around $40 for 24' length of tape and ~$5 for a timer. I also will provide a link for energy cost calculation.
http://doityourself.com/shop/heattape.htm
http://www.saskpower.com/services/calculator/calculator.php?CatID=1&SubCatID=6
3E Plus from http://www.pipeinsulation.org/pages/home.html can be of great help to you. Check the heat loss data from insulated and bare piping.
Incropera and Dewitt's book is very good. I have two copies of it myself.
Ouabache, It does indeed sound like you wouldn't have too hard of a time replumbing that. If the new one is directly below the existing vertical run of piping, you could eliminate that new basement run in a half a day. I can now see why you are persuing this.
argh... and I only have one copy of that book... How can I keep up with you guys? Gonna have to go buy another copy now... <sigh>
I got a second copy by complete luck. I bought a house from a young guy who had just finished school. He left a bunch of his textbooks in the house after I had closed on it. I called him quite a few times to give them to him, but he never called me back. So...I kinda kept it.
Somebody told me some time ago that at the end of the game an engineer is a guy who knows how to find how to do something in some book. You know, now I am far away from home and away from my notes, instead of telling this guy how to calculate it, I only diffusely remind that this stuff is made in some book. That's all the reminder left in your brain after studying five years of engineering, guys.:smile:
As your problem seems to be a real life situation then forget fancy heat loss calculations. The heat loss in real life will be from the total amount of water in the pipe run between the heater and the tap.
Calculate the volume of water in the pipe and how much energy is required to bring it up to a useable heat level from a mean level.
Every time the tap is turned on will be the static heat loss if averaged out over time. So turning on the tap equates to the energy needed to heat that volume of water. Over a period of time, a few weeks, you will find that this can be a lot of energy lost. The solution is to have as short a run as possible. Instant heaters at the point of use can sometimes be a better long term cost effective solution.
DD
It only goes downhill from there my friend. It is very tough to be a master of all things in this business. I work at not forgetting everything, but just most everything.
Okay, i am looking at a library copy of the highly acclaimed Fundamentals of Heat Transfer by Incropera and DeWitt. :smile: Hmmmm I notice this was written at a fine institution (and my alma mater Purdue Univ.) :approve:
My forté is EE not ME, so I am only grasping rudimentary concepts here..:redface: This book reminds me of an Electromagnetics text (I have two copies of), by the late JD Kraus.
Anyhow, the examples I sought were the ones dealing with a cylindrical tube of some length. I see under steady state conduction of heat, they use the equation I previously posted here ref1 which i called "Heat Transfer Across Length of Cylindrical Tubing" (which is also equation 3.26 in Incropera).
I didn't notice anything applicable, for the transient conduction of heat.
Then under internal flow & convection (chap 8 Incropera), they calculate an average convection heat transfer coeffient [itex] \bar{h} [/itex] which I have just posted here ref2
There's a very nice table towards the end of the book, giving various thermophysical properties of metals. Under copper I found thermal conductivity k = 401 [W/(m-deg K)] and the conversion k=1 [W/(m-deg K) = 0.57782 [Btu/(hr-ft- deg F)]. So I have a useful value of [itex]k_{Cu} \approx [/itex] 231.71 [Btu/(hr-ft- deg F)]
So this reference has me off and running!
Ouch,
this problem looks hard because this is not a steady state analysis.
from what I get out of this problem, your concerned with the heat loss from a cold start until steady state value. So you can't use [tex]Q=\dot{m}C_{p,v}(\Delta T) [/tex] as a steady state senario.
You see, for your refrences, all the problems are steady state. Your problem is not steady state, your equations won't apply. You would need to have a function that gives you the change in temperature as a function of some properties, because your pipe will start at ambient temperature, and change until it reaches steady state.
cyrusabdollahi said:
Ouch,
thanks for thinking this through.. Well steady-state energy loss is a part of the whole calculation. In my earlier post I tried to group the 3 parts of this problem, that I've learned from our knowledgeable membership.
You see, for your references, all the problems are steady state. Your problem is not steady state, your equations won't apply. You would need to have a function that gives you the change in temperature as a function of some properties, because your pipe will start at ambient temperature, and change until it reaches steady state.
That's right. I need to bear that in mind after finding the other 2 parts, that for completeness, I should find the transient loss too.
If the fixtures are in a floor above the water heater, consider a thermosiphon type hot water return system. The fixtures have to be above the water heater and a pipe is then run from the last fixture back down to the water heater with a check valve in the direction of the water heater to keep water from going back to the fixture when the faucet is opened. The hot water will rise and as it sits in the pipe and cools, it will drop down in the pipe returning to the water heater. Requires no pumping energy and the water should always be hot at the last fixture.
To determine the the heat lost for estimating life cycle costs for a repiping project, you can use the following approximate figures based on 140 deg F starting water temperature and 70 deg F ambient air temperature.:
For uninsulated 3/4" copper = 30 btu/h*ft
For uninsulated 1" copper = 38 btu/h*ft
For uninsulated 1-1/4" copper = 45 btu/h*ft
For 1/2" fiberglass insulated 3/4" copper = 18 btu/h*ft
For 1/2" fiberglass insulated 1" copper = 21 btu/h*ft
For 1/2" fiberglass insulated 1-1/4" copper = 23 btu/h*ft
(figures are from ASHRAE 2003 Applications Handbook 49.4 table 1)
Multiply the length of each run of each size by the appropriate values above, then by the number of hours the system sits idle, add the figures together and you get a rough estimation of your lost heat. As the temperatures of water and air get closer together the heat lost is reduced, but this figure will be reasonable for estimating lost energy.
I recommend just using an estimated value because to actually do a life cycle cost based on say payback over 10 years of service will require you to guess at several figures anyway. You will have to guess the future value of money, fuel, maintenance, etc. So to be so precise with the energy lost is pretty much pointless (although you could come pretty close using some of the calculations given by others above). Or
I just reread the original post and saw that the home has 3/8" pipe. I would just use the smallest figure for the insulated and uninsulated values and cut them down by maybe a third. As I said, the cost of fuel in the future is such an unknown variable in your calculations that precise calculations are not too critical for this application.
Actually you could deal with this as steady state because the pipe achieves steady state while the system is at rest. You are not dealing with changing values you are just raising the 70 deg F water sitting in the pipes back up to 105 Deg F (or 140 in the heater). This is just a matter of calculating the capacity of water sitting in the pipe and the energy required to raise that temp back up to 140. The cost of wasted water could also be applied.
I think Artman offers a simple practical approach to the problem. Keep the analysis simple, and look at heat loss rate for insulated and non-insulated piping. The exposed lines can be insulated, but the lines in the wall likely cannot be insulated without breaking into the wall, so one would have to look at insulated length and non-insulated length. I think most lines are 3/4" or less. Then one could assume that heat loss rate for insulated is about half of non-insulated. One consideration is what will the water temperature be in the insulated line after say 12 hrs.
But basically, it is a matter of how much the homeowner wants to spend to reduce the time hot water appears at various facets.
Besides reducing the length of the runs, one could look at small local water heaters under each sink, but that is not usually practical for bathtubs or showers, where the plumbing is usually in the wall.
On a somewhat different topic which was brought up in this thread - I need to buy the latest Incropera and Dewitt. Mine is at least 25 years old. :wink:
Astro, check your PM.
I did. Thanks!
FredGarvin said:
It only goes downhill from there my friend. It is very tough to be a master of all things...
Not possible. And I would add that graduation is the beginning of learning. Nothing is more dangerous in the real world than a new graduate.
Yeah. By "very tough" I meant impossible.
I do think recent graduates do come in two flavors; Those that have spent 4 years learning that they know squat and those that think they learned everything in 4 years. The latter are the dangerous ones.
Fair enough. I still don't know squat but at least I know that...and I have forgotten half the squat that I used to think I knew...:biggrin:
I agree. The more I learn, the more I realize just how much I don't know.
Thanks Artman and Astronuc for your recent suggestions on this analysis. I will also try and find a recent ASHRAE Applications Handbook. It sounds like a useful reference for these sorts of questions.
It is.
Also, why don't you post the specifics of the project, such as the lengths of pipe of various sizes (such as 10' of 3/4" and insulated or not) and the amount of time the system stands idle, expected ambient temperature around the pipes. For life cycle costs you will also need the length of time for payback, the cost expected to do the project, and the type of water heater energy (natural gas, LPG, electric, oil, heatpump, etc) and, if you want to determine the cost of that energy we can all use the same information.
It would be a fun exercise for us and we could check your calculations.
  • #31
Hi
I hope you do not mind me joining this discussion, but I found this thread on a Google search. I have a related problem.
I am thinking of installing a set of Glass tube heat pipe solar pannels to help run my underfloor heating system. My only problem is that they can only be situated about 50 meters from the house, so the flow and return pipes will have to be burried underground. What I would like to know is how much heat loss I can expect in the pipes?
The pipes will be 30 - 40 mm diam Polyethylene water pipe, burried 0.75 m below ground. I am not sure how I could insulate these - I would need some type of waterproof foam plastic lagging as glass fibre would pass ground water. When the system is working (sun shining) the flow temperature will be 40-50 C with a return of 10-20 C lower. When it matters, in the winter, I assume a ground temperature of 2-10 C . This would effectively be a steady state system as the main issue is how much heat can I get during a winterday when the sun is shinning.
Any help or advice would be most welcome.
PJG
  • #32
pjgregory said:
Hi
PJG
Fill the trench around the pipes with perlite insulating concrete.
provides a k factor range of 0.58 to 0.66 Btu-inch/h-ft2-F (0.085 to 0.095 W/m-k).
  • #33
Hi Artman
Thank you for your response. Let me see if I understand this.
The heat loss in Watts is
Watts = k * Area * Temperature Differnce / Thickness Material (L)
So assume k for Perlite concrete is 0.09. Then simplifying for one pipe laid in a cylindrical tube of concrete radius 0.25m (L), the area per unit length would be 1.57 so for 50m of pipe and a 40 degree K temperature difference, the loss would be:
Loss = 0.09*1.57*50 *40/0.25 = 1130 watts.
So I will need to add about 1Kwatt to estimated load for the house to compensate for the heat loss in the underground pipes.
I have found a supplier of Perlite products in Italy. Now all I have to do is work out how to explain this to my builder in Italian.
Thanks again
PJG
  • #34
Here is another possibility to consider. Preinsulated pipe. I don't know which would be cheaper or easier.
http://www.maxx-r.com/?gclid=CP-Z4IiN3YQCFRs1Swod6jZ6Ww"
  • #35
copper water interface heat transfer
Hello,
Great discussion. Any references for a similar problem?
Copper pipe is bathed in a hot material.
Copper pipe has cooler water flowing through the pipe.
How to calculate heat flow through the copper pipe to moving water?
Non laminar flow is thought to improve heat transfer to water.
<h2> What causes heat loss in a hot water pipe system?</h2><p>Heat loss in a hot water pipe system occurs due to a combination of factors, including conduction, convection, and radiation. Conduction is the transfer of heat through the material of the pipe itself, while convection is the movement of heat through the surrounding air. Radiation is the transfer of heat through electromagnetic waves.</p><h2> How much heat is typically lost in a hot water pipe system?</h2><p>The amount of heat lost in a hot water pipe system can vary depending on factors such as the length and diameter of the pipes, the type of insulation used, and the temperature difference between the hot water inside the pipes and the surrounding air. On average, it is estimated that between 10-20% of heat can be lost in a hot water pipe system.</p><h2> What are the consequences of heat loss in a hot water pipe system?</h2><p>The consequences of heat loss in a hot water pipe system can include increased energy costs, longer wait times for hot water, and potential damage to the pipes due to freezing temperatures. In addition, heat loss can also lead to a decrease in the overall efficiency of the hot water system.</p><h2> How can heat loss be reduced in a hot water pipe system?</h2><p>One of the most effective ways to reduce heat loss in a hot water pipe system is by properly insulating the pipes. This can be done using materials such as foam, fiberglass, or rubber insulation. It is also important to regularly check for any leaks or gaps in the insulation and repair them promptly to prevent heat loss.</p><h2> Are there any other methods for preventing heat loss in a hot water pipe system?</h2><p>In addition to insulation, there are a few other methods for preventing heat loss in a hot water pipe system. These include using heat traps or heat exchangers, which can help to retain heat within the pipes. Another option is to install a recirculation system, which continuously circulates hot water through the pipes to prevent heat loss. However, these methods may require additional equipment and can increase energy costs.</p>
FAQ: Heat Loss in a Hot Water Pipe System
