Calculating Mass and Weight of a Planet
To calculate the total mass of the planet with a varying density D(r), integrate the density function over the volume using spherical coordinates, resulting in a straightforward radial integral after accounting for angular components. The total mass can then be used to determine the weight of a one-kilogram mass at the planet's surface using the universal law of gravitation, F = GmM/r². The integration approach requires careful consideration of the density function and the volume element. Clarification on the integration steps may be needed to resolve any issues encountered. Properly applying these methods will yield the desired results for both mass and weight calculations.
whereisccguys
2 part question
The density of a certain planet varies with radial distance as: D(r) = Do*[1-(a*r/Ro)], where Ro= 3.1623×106 m is the radius of the planet, Do = 3160 kg/m3 is its central density, and a = 0.160. Calculate the total mass of this planet.
Calculate the weight of a one kilogram mass located on the surface of the planet.
i tried integrating D(r) with and plugin in the radius of the planet but it doesn't work
i know this question has somethin to do with integrating through shell method but I'm not sure how to do it
can any1 help me?
Why doesn't it work?
~H
whereisccguys said:
2 part question
can any1 help me?
I am not sure what you integrated exactly but here are some thoughts:
First, you must determined the total massof the planet, right? This is given by the integral of D(r) dV = D(r) r^2 sin(\theta) dr d\theta d\phi. The angular integrals are trivial and give 4 \pi. The radial integral is straightforward.
Then, you must use this in the universal law of gravitation to determine the *weight* of 1 kg at the surface of the planet, F= {G m M \over r^2}.
Patrick
  • · Replies 62 ·
