How to reformat & partition the HDD ?
In summary: Once it's finished, you'll be able to restart your computer and it should boot fine from your new system partition.
varungreat
how to reformat & partition the HDD ??
hi,
My computer has become very slow & sluggish & fully crammed up!
So i want to reformat my HDD & make new partitions for proper management of data.
Please tell me how to do it through dos ( ie without using any additional softwares like partition magic...etc)
I want to install MS Windows XP pro in drive "C" while rest partitions will be uced for storing data.
PS : Being an amature, please send me instructions step by step.
my configuration is as follows :
Processor Intel(R) Pentium(R) 4 Processor 2.80 GHz
800 MHz. Socket 478
80 GB samsung HDD @7200 rpm
Intel(R) Desktop Board D865GBF based system
OS version Windows XP
Physical memory 768,744 KB RAM
Memory speed DDR400
Memory type DDR, Synchronous
Form factor DIMM
BIOS version P13 (BF86510A.86A.0053.P13.0401220953)
PLEASE HELP ME.
THANK YOU!
Computer science news on Phys.org
Okay, first things first - do you know how to boot from your CD drive, and do you still have your Windows XP CD?
If so, the first thing to do (assuming you've already backed up anything important on your hard drive, because once you format it, you're going to lose everything) is to boot from your Windows XP CD.
First, you'll get a blue screen with a message saying "Setup is inspecting your computer's hardware configuration". After the hardware inspection phase is complete, you'll get taken to a screen saying something like "Welcome to Setup" followed by a couple of dot points. The first one will tell you to "press ENTER to setup Windows now", which is what you want to do. So press ENTER.
The next screen is the Windows XP Licensing Agreement. Press F8 to agree to it.
The next screen should say "The following list shows the existing partitions
and unpartitioned space on this computer". This is followed by a few dot points telling you to
* To set up Windows on the selected item, press ENTER
* To create a partition in the unpartitioned space, press C
* To delete the selected partition, press D
Following that is a box listing your existing partitions. You can highlight (i.e. select) different partitions using the up and down arrow keys.
If you're wanting to change your partition sizes, what you want to do is first delete the existing partitions. So select the first partition and press D.
If this was your previous system partition, you'll get another screen with a dire warning to the effect of "The partition you are trying to delete is a system partition, BLAH BLAH BLAH". As long as you're comfortable that you've backed up everything that you need, press ENTER to delete the partition.
Next, you'll get a screen saying something like "You asked setup to delete the partition" followed by the partition you chose to delete. Press L to confirm the deletion.
After this you go back to the screen which lists your partitions. There should be an item listed as "Unpartitioned space", as well as any partitions you have not yet deleted. Repeat the above steps to delete the remaining partitions (if there are any - if you only had a C: partition before, then you should only have unpartitioned space left in the list).
Now, the only thing left in the list should be "Unpartitioned Space", with a listed size equal to the size of your hard drive (the actual size, which will be a couple of GB less than 80 GB). So now you want to create your new system partition - press C.
You will be prompted to enter in the desired size of the partition in MB. With an 80GB drive, you'll probably want to make it around 10GB at least. I prefer to use about 15GB or so, since I tend to use my Desktop as a temporary holding space for stuff, and you can run out of space quickly. But make it as big or small as you want (probably not smaller than 3GB though).
The next screen will say something like "A new partition for Windows XP has been created on BLAH BLAH BLAH" followed by four formatting options. Choose "Format the partition using the NTFS file system". Don't choose the "quick format" option - the non-quick format checks your disk for bad sectors, which are flagged so that Windows doesn't put any vital system files (or any other files for that matter) on a damaged sector.
Next, you'll get a screen saying "Please wait while Setup formats the partition...". Once the formatting is complete, you'll get another screen saying "Please wait while Setup copies files BLAH BLAH". Once this has completed, you'll get another screen saying "Please wait while Setup initializes your Windows XP configuration".
After this, you'll get another screen saying "This portion of Setup has been completed successfully", followed by "To restart your computer, press ENTER". There will be a red progress bar as setup waits 15 seconds or so, then it'll reboot itself if you haven't yet pressed ENTER.
At this point you should go into your BIOS and change the boot order again. It's not absolutely essential though, because if you leave it for long enough without pressing a key, it'll start to boot from the hard drive anyway.
After this you'll get to the Windows GUI setup, which is pretty easy to follow. Once that has completed, you'll have your new system ready to go. It would be a good idea to install your motherboard drivers before you install anything else. Then install your video card drivers, set the resolution and refresh rate to your liking, and install any other necessary drivers.
Once you've reached this stage, you can set up your remaining partitions by right-clicking on "My Computer" and selecting "Management". In the Computer Management window, look down the left pane for "Disk Management", which will appear under the heading "Storage". You may need to click on "Storage" to expand it so you can see the "Disk Management" option.
You can always ask again if you don't know how to use Disk Management to set up your partitions.
Hi,
Reformatting and partitioning your HDD can definitely help improve the speed and organization of your computer. Here are the steps for reformatting and partitioning your HDD in DOS:
1. First, you will need to back up all important data on your computer, as reformatting will erase all data on the HDD.
2. Restart your computer and enter the BIOS setup by pressing the key specified during startup (usually F2 or Del). Navigate to the "Boot" menu and change the boot priority to boot from your CD/DVD drive first.
3. Insert your Windows XP installation CD and restart your computer. Follow the prompts to begin the installation process.
4. When you reach the "Welcome to Setup" screen, press "Enter" to continue.
5. Press "F8" to agree to the license agreement.
6. Now, you will see a list of your existing partitions. Use the arrow keys to select the partition you want to reformat and press "D" to delete it. Repeat this for all partitions you want to reformat.
7. Once all partitions are deleted, you should see "Unpartitioned space." Select this option and press "C" to create a new partition.
8. Enter the desired size for the partition (in MB) and press "Enter." You can create multiple partitions by repeating this process.
9. Select the partition you want to install Windows on and press "Enter."
10. Now, you will be prompted to choose a file system for the partition. For Windows XP, choose "NTFS" and press "Enter."
11. Follow the remaining prompts to complete the Windows installation on the selected partition.
12. Once the installation is complete, your computer will restart. You can now use your newly reformatted and partitioned HDD.
Please keep in mind that reformatting and partitioning your HDD will erase all data, so make sure to back up any important files before proceeding. Best of luck!
FAQ: How to reformat & partition the HDD ?
1. How do I reformat my HDD?
To reformat your HDD, you will need to back up any important data and then access the Disk Management tool on your computer. From there, you can select your HDD, right-click and choose the "Format" option. Follow the prompts to complete the reformatting process.
2. What is the difference between reformatting and partitioning?
Reformatting refers to erasing all data on a hard drive and preparing it for use, while partitioning involves dividing a hard drive into separate sections or partitions for different purposes or operating systems.
3. Can I reformat and partition my HDD at the same time?
Yes, you can. Many disk management tools allow you to reformat and partition your HDD simultaneously by selecting the appropriate options during the process.
4. Will reformatting and partitioning my HDD affect my data?
Yes, reformatting and partitioning will erase all data on your HDD, so it is essential to back up any important files before proceeding with these actions.
5. How do I choose the right file system for my HDD?
The file system you choose depends on your operating system and personal preference. Windows computers typically use NTFS, while Mac computers use HFS+. Research the different file systems and their capabilities to determine which one is best for your needs.
16K
