Clarifying Electrodynamics: Relativity and the Faraday Tensor
  • Thread starter Arcon
  • Tags
    Phi
In summary, the conversation discusses the relationship between the 4-potential and the Faraday tensor in classical electrodynamics. It is stated that in a certain frame of reference, the equation \partial A/ \partial t = 0 holds true, leading to the simplification of the equation E = - \nabla \Phi. This relationship is shown to be in agreement with the equations presented in J.D. Jackson's book "Classical Electrodynamics - 2nd Ed." and is considered to be trivially correct. Some people have claimed that this is relativistically incorrect, but this is proven to be false.
Arcon
I would like your opinion regarding an explanation I gave elsewhere. I hold that the explanation below is straight forward. However it appears as if some were confused by it.
In a certain frame of referance, for a particular electromagnetic field, the relation [tex]\partial A/ \partial t = 0[/tex] holds true. Such a condition will hold in the case of a time independant magnetic field. The equation
[tex]E = - \nabla \Phi - \dfrac{\partial A}{\partial t} [/tex]
in this example and in this frame reduces to
[tex]E = - \nabla \Phi[/tex]
Does anyone think that this is relativistically incorrect?
I know this seems like a dumb question but some people claim that this is relativistically incorrect. Such a claim is obviously wrong. However I can't understand why they're having such a difficult time understanding this. Is it what I explained above confusing?
The 4-potential, [tex]A^{\alpha}[/tex], is defined in terms of the Coulomb potential, [tex]\Phi[/tex], and the magnetic vector potential, A as
[tex]A^{\alpha} = (\Phi/c, A) = (\Phi/c, A_x, A_y, A_z)[/tex]
The Faraday tensor, [tex]F^{\alpha \beta}[/tex], is defined as
[tex]F^{\alpha \beta} = \partial^{\alpha} A^{\beta} - \partial^{\beta} A^{\alpha} [/tex]
[See "Classical Electrodynamics - 2nd Ed.," J. D. Jackson, page 551, Eq. (11.136). I'm using different units]
The [tex]F^{0k}[/tex] components of this relationship for k = 1,2,3 are, respectively
[tex]\displaystyle{\frac{E_{x}}{c}} = \partial^{0} A^{1} - \partial^{1} A^{0} = - \displaystyle{\frac{1}{c}} \displaystyle{\frac{\partial A_{x}}{\partial t}} - \displaystyle{\frac{1}{c}} \displaystyle{\frac{\partial \Phi}{\partial x}}[/tex]
[tex]\displaystyle{\frac{E_{y}}{c}} = \partial^{0} A^{2} - \partial^{2} A^{0} = - \displaystyle{\frac{1}{c}} \displaystyle{\frac{\partial A_{y}}{\partial t}} - \displaystyle{\frac{1}{c}} \displaystyle{\frac{\partial \Phi}{\partial y}}[/tex]
[tex]\displaystyle{\frac{E_{z}}{c}} = \partial^{0} A^{3} - \partial^{3} A^{0} = - \displaystyle{\frac{1}{c}} \displaystyle{\frac{\partial A_{z}}{\partial t}} - \displaystyle{\frac{1}{c}} \displaystyle{\frac{\partial \Phi}{\partial z}}[/tex]
These can be expressed as the single equation
[tex]E = -\nabla \Phi - \displaystyle{\frac{\partial A}{\partial t}}[/tex]
This equation and the equation B = curl A are equation (11.134) in Jackson on page 551. In fact Jackson uses these two equations to define [tex]F^{\alpha \beta} = \partial^{\alpha} A^{\beta} - \partial^{\beta} A^{\alpha} [/tex]
In the example stated above [tex]\partial A/\partial t = 0[/tex] so that
[tex]E = -\nabla \Phi [/tex]
Does anyone find that confusing?
Likes Delta2
That's trivially correct.
Likes Delta2
FAQ: Clarifying Electrodynamics: Relativity and the Faraday Tensor
What is the Faraday tensor and how does it relate to electrodynamics?
The Faraday tensor, also known as the electromagnetic tensor, is a mathematical object used to describe the electromagnetic field in three-dimensional space. It contains information about the electric and magnetic fields, as well as their interdependence. In electrodynamics, the equations that govern the behavior of electric and magnetic fields can be written in terms of the Faraday tensor.
How does the concept of relativity play a role in electrodynamics?
The theory of relativity, specifically Einstein's special theory of relativity, has a significant impact on electrodynamics. It provides a framework for understanding the behavior of electric and magnetic fields in different reference frames and helps explain phenomena such as length contraction and time dilation in moving frames of reference.
What are the main differences between classical electrodynamics and relativistic electrodynamics?
Classical electrodynamics, also known as Maxwell's equations, describes the behavior of electric and magnetic fields in a non-relativistic framework. It does not take into account the effects of relativity on the behavior of these fields. On the other hand, relativistic electrodynamics incorporates the principles of relativity into the equations, allowing for a more accurate description of the electromagnetic field in different reference frames.
How does the Faraday tensor help to reconcile the concept of electromagnetism with the principles of relativity?
The Faraday tensor is a key component in the equations of relativistic electrodynamics. It allows for the unification of electric and magnetic fields into a single entity, making it easier to apply the principles of relativity to their behavior. The tensor also allows for a more elegant and consistent formulation of the equations, which is in line with the principles of relativity.
What are some real-world applications of understanding the Faraday tensor and its relationship to electrodynamics?
Understanding the Faraday tensor and its role in electrodynamics has many practical applications. It is essential for understanding and developing technologies such as electromagnetic radiation, wireless communication, and particle accelerators. Additionally, it plays a crucial role in modern physics, including the theory of general relativity and the search for a unified theory of physics.
