matthew77ask
- 45
This questions puzzles me:
Which has a larger specific heat capacity (shc) : solid, liquid or gas.
We can assume that it is of the same matter. Why?
I have checked the numbers. Only water has it on all three states. Liq water has the highest, while that of ice and steam is about the same.
We are not talking about thermal conductivity here. If we are then kinetic particle theory will point to solid > Liq> Gas in thermal conductivity because of the closer solid particles can "pass" on the heat fastest compared to the further gas particles.
Can the same theory applies when it comes to shc? the amount of heat needed to raised the temp by 1 degree C? if it can then the order would be shc of gas > liq > solid. But this is not the case for water...
Is SHC of a matter a function of the matter itself rather than the closeness of the particle.
Sorry, fired up a lot of questions... hope someone can enlighten me and take some heat away
Cheers!
Matthew
Cheers!
Matthew
