A question on Hilbert space theory
The discussion revolves around the properties of a self-adjoint, densely defined closed linear operator acting on a separable Hilbert space. Participants explore the relationship between the domain of the operator and the image of its eigenvalue, particularly focusing on proving a specific orthogonality condition involving the operator's domain and its associated image set.
  • Daniel introduces the operator and the notation for the image set associated with an eigenvalue, seeking to prove an orthogonality condition.
  • Some participants question the definition of the domain \( D_A \), with varying interpretations of its relationship to the Hilbert space \( H \).
  • Hurkyl argues that if the domain \( D_A \) were the entire space \( H \), the operator would be bounded, which contradicts the assumption of it being unbounded.
  • Another participant suggests that the operator's definition might be a convention, raising concerns about clarity in the discussion.
  • Daniel acknowledges a misunderstanding regarding the nature of the eigenvector \( f \) and its implications for the orthogonality condition.
  • Participants discuss the implications of the Hellinger-Toeplitz theorem on the properties of self-adjoint operators and their domains.
  • Daniel later clarifies that the initial assertion about the orthogonality condition may not hold in general, particularly when considering specific cases.
  • There is a discussion about the continuity of the inner product and its implications for the relationship between the domain and the image set.
  • Daniel presents a reasoning process to demonstrate that if the closure of the image set is equal to \( H \), it leads to a contradiction regarding the domain.
  • Another participant elaborates on the implications of density and continuity in the context of the proof, emphasizing the role of eigenvectors.
Participants express differing views on the definitions and implications of the operator's domain and its relationship to the image set. There is no consensus on the correctness of the initial claims, and the discussion remains unresolved regarding the proof of the orthogonality condition.
There are limitations in the assumptions made about the operator and its domain, particularly regarding the nature of self-adjoint operators and the implications of the Hellinger-Toeplitz theorem. The discussion also highlights the need for clarity in definitions and the conditions under which the statements are made.
dextercioby
Insights Author
Let's say we have a self-adjoint, densly defined closed linear operator acting on a separable Hilbert space [itex]H[/itex]
[tex]A:D_{A}\rightarrow H[/tex]
Let [itex]\lambda[/itex] be an eigenvalue of A and let
[tex]\Delta_{A}\left(\lambda\right) = \{\left(A-\lambda \hat{1}_{H}\right)f, \ f\in D_{A}\}[/tex]
How do i prove that
[tex]D_{A}\perp \Delta_{A}(\lambda) \Leftrightarrow \bar{\Delta_{A}(\lambda)} \neq H[/tex].
Daniel.
Unless you define D_A I don't think we can do the question.
I presume D_A is the domain of A.
The domain of A is H.
No, Hurkyl is right. By the Hellinger-Toeplitz theorem, any self-adjoint operator whose domain is all of H is bounded. So, the best that one can expect for an unbounded self-adjoint operator A is that its domain D_A is a dense subset of H, as Daniel says.
Then why did the OP say we had an operator acting on H, if H is not the domain? Must just be a convention thing, but seems odd to me.
It's not that much different from talking about meromorphic functions on C, or rational functions on an an algebraic variety, is it?
As in they have poles? No, I think that is different, slightly, since we implicitly extend the codomain to have a point at infinity thus the functions are defined at all points of the domain. I get the impression here that there is no possible extension to an operator defined on the whole of H, though I may be mistaken in this assumption.
George Jones nailed it on the head. It's assumed unbounded, so by Hellinger-Toeplitz theorem
[tex]D_{A}\neq H[/tex]
but in order to be self-adjoint one must have that the closure of [itex]D_{A}[/itex] is H.
I guess the question still remains open. :rolleyes:
Daniel.
That can't be right.
Let A be any projection operator. So [itex]D_A = H[/itex]. Then, [itex]\Delta_A(0)[/itex] is the image of A. For most such operators, [itex]D_A[/itex] is clearly not orthogonal to [itex]\Delta_A(0)[/itex]... and yet [itex]\Delta_A(0)[/itex] is not dense in H.
Or, did you mean to only consider unbounded operators?
Yes, that operator is meant to be unbounded. Look at it this way, if it were bounded, why would one consider [itex]D_{A}[/itex] (the domain of A) dense in H but yet different from H ? It would have been simply H, as a bounded operator could be extended by continuity on all H...
Daniel.
But the case Hurkyl gave is a special case of what you wrote and it breaks down in the special case so why should it be true if we exclude the special case above? I think you should taken that post as a hint as to what you need to do. (Not that I know what the proof is, before you ask.) There are a lot of hypotheses on A up there, and H, so how are you attempting to use them?
Perhaps the problem that i stated is not quite correct. It would be fair to post the whole context. Here's a scanned version of page #89 of Ahiezer & Glazman's book. It's part of the 43-rd section which I'm trying to fully understand.
The thing i didn't understand is the argument he uses in the proof of theorem #2 namely that under the assumptions i stated in my first post (which appear on page 88).
He asserts that if [itex]Af=\lambda f[/itex] for an "f" both in the domain and in the range of A (closed, densly-defined self-adjoint linear operator) then
[tex]f\perp \Delta_{A}\left(\lambda\right) \Leftrightarrow \Delta_{A} \ \mbox{ is not everywhere dense in H}[/tex].
Huh? :confused:
Daniel.
So i was basically wrong in the first post, since "f" is not arbitrary in D_{A} so i can't assert that generally D_{A} \perp \Delta_{A}\left(\lambda\right)
Daniel.
Let me write [itex]D = D_A[/itex] and [itex]\Delta = \Delta_A(\lambda)[/itex] for simplicity.
Incidentally, it's easy to see that you can't have both [itex]D \perp \Delta[/itex] and [itex]\bar{\Delta} = H[/itex]: the inner product is continuous, and this implies that it's identically zero.
So let me see why you think it's trivial. If i assume
[tex]\bar{\Delta} =H[/tex]
, then
[tex]\bar{\Delta}\supset H \supset D[/itex]<br /> <br /> But [itex]D\perp \Delta[/itex] , so considering a sequence [itex]g_{n}[/itex] from [itex]\Delta[/itex] convergent to "g" in [itex]\bar{\Delta}[/itex], then from<br /> <br /> [tex]\langle f,g_{n}\rangle =0[/tex]<br /> <br /> it follows that<br /> <br /> [tex]\langle f,g\rangle =0[/tex]<br /> <br /> ,using continuity of the scalar product. <br /> <br /> So i proved that [itex]D \perp \bar{\Delta}[/itex]. Since above i assumed that [itex]D\subset \bar{\Delta}[/itex], it follows that [itex]D={0}_{H}[/itex] which is false. Ergo, the initial assumption is false.<br /> <br /> Daniel.[/tex]
Let my try and elaborate a bit on Hurky's last post.
Let [itex]U[/itex] be any any dense subset of [itex]H[/itex], and let [itex]v \in H[/itex] be such that [itex]\left< v , u \right> = 0[/itex] for every [itex]u \in U[/itex]. Then, by continuity and density (insert small analysis argument), [itex]v = 0[/itex].
Now, in the first half of the proof, one has [itex]\left< f , u \right> =0[/itex] for every [itex]u \in \Delta[/itex]. Therefore, if [itex]\Delta[/itex] were dense in [itex]H[/itex], then [itex]f[/itex] would have to be zero. But this can't be, since [itex]f[/itex] is an eigenvector.
Oops, I didn't see Daniel's last post.
I see, and there's no reverse of that statement. So I'm supposed to get that
[tex]\bar{\Delta}\neq H \nRightarrow D\perp \Delta[/tex]
, but instead one can find a nonzero vector from D which is orthogonal to [itex]\Delta[/itex].
Daniel.
  • · Replies 59 ·
  • · Replies 43 ·
