How many watts does the human body use
In summary: How do you think people would feel if they were told their daily routines in terms of exercise and calorie intake were actually using the same units of measure?
Chaos' lil bro Order
683
how many watts does the human body use
i guess 500w
Biology news on Phys.org
i guess 500w
I once read, in connection with crew in a space habitat, that an adult human radiates like a 100 watt light bulb. You could figure the other from that, assuming eqquilibrium. Your guess looks to be in the ball park.
You can work it out from knowing kCal of food metabolized that results in equilibrium - it's called basal metabolic rate (BMR). It's the rate of oxygen consumption (or CO2 production) per Kg of body weight when the bodyy is at rest.
play with this applet:
http://www.bmi-calculator.net/bmr-calculator/
Hey thanks for that. I got my BMR to be 1554 (ignoring the decimals) which is a number I have been trying tofind.
My BMR is 1888, so what's that mean my wattage is?
Watts measure power, Kcal measures energy. If you're willing to go with Watt-hours to get everything in the same units of measure:
1 KCal = 1.163 watt-hour, if I remember correctly.
So, 1888 * 1.163 = 2915 Watt-hours
The recommended UK Male Calorie intake is 2550 Calories/ Day
1 Calorie (Nutritional) = 4186.8 Joules
So assuming zero weight gain, and waste having no nutritional value you must dissipate 123.6 J/s or Watts, or the heat generated by burning 12.5oz of coal.
What the proportion of heat/motion is depends on how warm your personality is...
BMR has units of power. The website given in the link above is using kcal/day, although units aren't given there, so to convert to watts
1888 kcal/day * 4.18 kJ/kcal * 1 day / 8.64e4 sec = 91.3 Watts
BMR depends on body weight and percentage body fat, since muscles generate heat, age, sex, and other factors including individual variability.
Most of the energy is consumed by the brain I think .
:smile:
Nice replies fellas.
So ~100W seems to be a good ballpark figure for a human body's power output. Funny that a 100W light bulb is on par with the human body!
SelfAdjoint says 'he heard' the brain uses 25% of this, so 25W, I wonder how true this is.
Very interesting thread so far, what else can we think of that's on topic?
So what you could do now is reexpress your calories of food (which are really kilocalories, you know) as watt-hours, and see what your energy balance is. Or different kinds of excercise, what are their wattage requirements? Getting away from the dietician's calorie seems to be a refreshing way to think about our daily regimen.
Years ago I visited the precision metrology lab at HP Labs, which was temperature controlled to keep the instruments, meter bars and such constant. At the entrance to the room was a panel of light switches that controlled 100W bulbs inside. Each person entering turned off 100W, and turned it back on when they left, so the heat load inside stayed approximately constant.
The brain uses 25% of the body's oxygen, so that seems about right. Unless there are anaerobic prcoesses at work in the body?
I couldn't agree with you more self. Calories and kilojoules are like pints and quarts to me. I much prefer terms like eV and Watts since batteries and machines and such all label their power usages in these terms. It makes comparisons easy and much more interesting.
@Marcus
Now there's a real-life application that really solidifies and roots this thread in the practical. Its very interesting to hear your example.
Look around and imagine how we remain.
We do not radiate all the energy we consume, so if we radiate like a 100 Watt light bulb we actually require a higher wattage since the human body is a very very ordered thing indeed. Just look at your eye ball in the mirror and try to imagine all the meticulous planning and processes that are occurring, the structure it possess. Now think how is all this kept ordered? Energy of course, energy input is required. So eating food is needed to keep our high entropy state going the way its going. To recap in a line: energy inputed is outputted through various radiations and is used to maintain order.
Careful about mixing up energy and power units. In fact, the energy content of food is ubiquitously quoted in Calories, so there isn't much getting away from it. That's why treadmills and exercise bikes display the energy you have burned in units of Calories instead of joules--you can directly compare input and output.
Another commonly used unit is Mets (metabolic equivalents). 1 met is the same as your BMR; you expend about 4 mets mowing the lawn, while 12 mets is about as hard as you can exercise for any length of time. It's a useful gauge of relative effort.
@Marcus
Thanks!
quasi426 said:
We do not radiate all the energy we consume, so if we radiate like a 100 Watt light bulb we actually require a higher wattage since the human body is a very very ordered thing indeed. Just look at your eye ball in the mirror and try to imagine all the meticulous planning and processes that are occurring, the structure it possess. Now think how is all this kept ordered? Energy of course, energy input is required. So eating food is needed to keep our high entropy state going the way its going. To capitulate in a line: energy inputed is outputted through various radiations and is used to maintain order.
Energy balance is conceptually pretty simple: whatever doesn't come out as mechanical work is dissipated as heat. There is some entropy content to thoughts that might be calculated by Shannon's theorem but I think it's completely negligible compared to the rest.
Thanks!
Ya I know calories/joules are energy. Did you see I mentioned eV? Calories = joules = eV, you just need to use simple conversion formulas. Watts is power, which is simply energy/time. I'm not confusing anything here.
btw, I don't know what country you are in, but most nutritional info in Canada is in both kCal and kJ, so its not as ubiquitous as you think.
I'm with li'l bro. If we go to Joules and Watts, people might even start to understand energy vs. power. The idea of using the same units in your regimen as you see on your electric bill might be really liberating. And I like mets too. If you could get mets ratings for different activities the way you can find the calorie rating of almost any food, you could plan so much better.
That's cool! In the US food packaging gives only Calories.
Charts are readily available online. See, for instance,
http://www.hsph.harvard.edu/nutritionsource/Exercise.htm"
i guess 500w
500 watts = 7.17 food calories (kilocalories) per minute
http://www.google.com/search?hs=Xf7...=500+watts+to+Calories+per+minute&btnG=Search
The average person needs between 1000-2000 food calories per day.
500 watts is about the amount of power an average person can put into the cranks of a bicycle for a few seconds. World class cyclists can deliver 500 watts to the cranks for more than 30 minutes and burn 4,000-8,000 food calories in a race.
Incidentally, 500 watts into the cranks of a standard racing bicycle will push it to a speed of about 30 mph on flat ground.
Wow! I guess that's why pro cyclists are always used for human powered aircraft trials.
Ya self, I agree, MET is a good unit to put human power usage in various activities in perspective. I've never heard of it before, so I am happy to learn a new thing that will further my understanding of life.
you have all overlooked something. generating power for a bike to put out 500 w. at the wheels would take a lot more overall energy. heat lost through body, body's usual working load? i recon someone generating 500 w is actually consuming about 2k. give or take a few watts. that got you thinkin eh! here check this 'How efficient is the human body at producing power on a bike generator?
Typically the average person is able to run about 25% efficiency. This means that for every Watt produced by a bike generator, the person doing the pedaling is putting out 4 Watts. So if you are pedaling to provide to your laptop computer at 80 Watts, you body is really running at 240 Watts'.
Hello Friend
Watts are not "in" the human body. Watts are a unit of power, and the human body in very good shape, can put out about 300 watts of power.
At rest a human body puts out perhaps 100 watts of power as heat.
Thank for sharing your thread.
mariajones said:
Hello Friend
ok on cross trainer i do 600 cals in 30 mins-can you tell me how many watts i would be using overall?
i have problems logging in here sometimes are you on facebook?
2000 Kcal is a average human nutitional intake so that is 8368000 J per day divided by the number of seconds in one day that gives a rough 96.85 W.
The amount of lost heat varies during day and nighttime but mostly we give about the same heat as a 100 W light bulb.
Having had a few severe asthma attacks in the past (resulting in trips to emergency rooms), I found that my need for oxygen increased significantly when required to understand human speech.
For what it's worth, don't talk to you kids anymore than absolutely necessary if they have an asthma attack.
I imagine whether parsing speech or not might change your power calculations significantly.
Interestingly I saw something on TV a while ago which was talking about why human aren't furry, and it has mostly to do with being able to dump heat from our bodies. They did a simple experiment to see how much heat the body could get rid of by sweating, and it managed well over 1kW. It seems reasonable that if we're capable of dumping that much heat, we're probably able to produce that much by various metabolic processes.
I also went for a run this morning. I log my time on runkeeper.com, which tells you an estimate of how many calories you've burnt (burnt, not the amount of mechanical work you've done). A 30min run of about 4.5km burnt 400kcal, which is about 1.6MJ, which works out at about 860W. Assuming runkeeper is right about the number of calories burnt, that's not a bad power output - mostly in the form of waste heat judging by my state at the end of the run ;-).
FAQ: How many watts does the human body use
How many watts does the human body use on average?
The average human body uses approximately 100 watts of power at rest. This energy is used for basic bodily functions such as breathing, circulation, and brain activity.
Does the amount of watts used by the human body vary based on age or gender?
Yes, the amount of watts used by the human body can vary based on factors such as age, gender, weight, and level of physical activity. Generally, younger individuals and males tend to have a higher resting metabolic rate and therefore use more watts.
How much energy is used by the brain compared to the rest of the body?
The brain uses a significant amount of energy, consuming about 20% of the body's total energy at rest. This is due to the constant activity and processing that occurs in the brain.
Can the human body produce more watts through physical exercise?
Yes, the human body can produce more watts through physical exercise. The muscles in the body use more energy during physical activity, resulting in an increase in watts used by the body.
Is there a limit to the amount of watts the human body can produce?
Yes, there is a limit to the amount of watts the human body can produce. This limit varies for each individual and is influenced by factors such as genetics, physical fitness, and overall health.
