How Does a Mist Maker Create Mist?
  • Thread starter Micko
  • Tags
    Work
In summary, the conversation discusses the functionality of a mist maker, which is a product that uses ultrasound to create mist. The mist maker is made by highly trained monkeys from Brazil, and there is currently only one functioning one in the world. The conversation also mentions that the mist maker operates by beating a submerged ceramic diaphragm at ultrasonic frequencies, but it is unclear why this works. Some suggest that it could be due to the surface tension of the water. Others mention that dry ice may also be used in creating mist, but this is a different process. Overall, the mist maker is known for producing a large volume of tiny droplets that can get things wet if not properly contained.
Micko
43
Hello people,
please, can someone explain how mist maker work?
I heard it use ultrasound, but don't know how works.
Thanks
I've never heard of a "mist maker" - do you have a link to a product?
It's made by highly trained monkeys from brazil.
It is said that there is currently only one functioning socalled "mist-maker" left in the world, although it's location remains unknown...
I think these operate by beating a submerged ceramic diaphragm at ultrasonic frequencies, but no idea why that works (nor whether the effect occurs at the diaphragm itself or at where the ultrasound is directed on the water/air surface).
I thought they just had dry ice in them!
They use a submerged piezoelectric crystal somewhat underneath the surface of the water to broadcast an ultrasonic beam upwards. This puts high frequency waves on the surface, where surface tension causes some of the wave crests to pinch off into microscopic droplets that are propelled into the air, where they float around as mist. It doesn't heat the water, and it doesn't produce water vapor, which is transparent. They make lots of teeny tiny droplets which, if the sides of your container aren't high enough, will float outside the bowl and get everything around them very wet. They don't work well if submerged too deeply in the water, and they don't usually put out a large volume of mist like you'd see in a theatrical production (for that I think they use dry ice and it's a completely different process).
Hope that helps.
FAQ: How Does a Mist Maker Create Mist?
How does a mist maker create mist?
A mist maker works by using a high-frequency ultrasonic vibration to agitate the surface of water, breaking it into tiny droplets that are then released into the air as mist.
What is the power source for a mist maker?
The power source for a mist maker is typically electricity. It can be powered by plugging it into a wall outlet or by using batteries.
How does a mist maker differ from a humidifier?
A mist maker and a humidifier both add moisture to the air, but they work in different ways. A mist maker produces a fine mist using ultrasonic vibrations, while a humidifier releases water vapor into the air through evaporation or a heating element.
Can a mist maker be used with essential oils?
Yes, some mist makers are designed to be used with essential oils. These mist makers have a separate compartment where essential oils can be added, and the mist produced will carry the scent of the oils into the air.
Are there any safety concerns with using a mist maker?
As with any electronic device, it is important to follow the manufacturer's instructions and safety precautions when using a mist maker. It is also important to use clean water and to regularly clean and maintain the mist maker to prevent the growth of bacteria or mold.
15K
