abhijitlohiya
- 14
is centripetal force present in inertial and non-inertial frames?
abhijitlohiya said:is centripetal force present in inertial and non-inertial frames?
Centripetal force is a force that acts towards the center of a circular motion. It is responsible for keeping an object moving in a circular path.
Yes, centripetal force is present in both inertial and non-inertial frames. In an inertial frame, the centripetal force is balanced by the object's inertia, while in a non-inertial frame, it is balanced by a fictitious force known as the centrifugal force.
Inertial frames are frames of reference in which Newton's laws of motion hold true. This means that an object at rest will remain at rest and an object in motion will continue to move at a constant velocity unless acted upon by an external force. Non-inertial frames, on the other hand, are accelerating frames of reference where Newton's laws do not hold true.
Centripetal force is responsible for changing the direction of an object's velocity, causing it to move in a circular path. Without centripetal force, an object would continue to move in a straight line.
No, an object cannot experience centripetal force without being in circular motion. Centripetal force is defined as a force that acts towards the center of a circular motion. If an object is not moving in a circular path, there is no centripetal force acting on it.
